How to get logs?
Option 1: To get debug logs in a GUI installation, open deCONZ and click Help. After that, click Debug View. The following debug levels need to be enabled for proper logging: INFO, INFO_L2, ERROR, ERROR_L2, APS, APS_L2.
Please note that in the HA Addon and Docker webVNC you can’t copy paste. You need to use a Native VNC Client. HA Addon How-To, Docker Environment Vars.
Option 2: To get debug logs in a headless installation / ssh session, use the following commands:
      /usr/bin/deCONZ -platform minimal --dbg-aps=2 --dbg-info=2 --dbg-error=2 | tee debug.txt
When done, exit the process with CTRL+C. You can now start the systemctl service again. Your logs will be printed in the console, as well as saved to a file named debug.txt in the current directory. Be sure to capture at least a few minutes worth of logs. When sharing these logs, DO NOT attempt to paste them into a channel. Instead use a pastebin service such as this or this. Afterwards, don’t forget to disable logging. This is especially important when running off an SD card, as the debug logging will cause unnessecary writes, and might shorten the life of your media.
Command .debuglogs was invoked by Mimiix#13
Can't pair Xiaomi / Aqara Temperature and Humidity Sensors
Aqara Wireless Remote Switch H1 loosing connection every two days
Lights Randomly Turning On
IKEA SYMFONISK paired with IKEA Range Extender does not work
Ubisys J1 - sensors not reachable after update to 2.13.04 / 18.12.2021 (26720700)
Partial lose of connections
Kein Kontakt zu RaspBee
Unable to connect Raspbee II to Pi 3b+
Can not add Aqara Window and Door Sensor to Phoscon
Weird devices beahaviour after power loss
Help - Xiaomi Switch doesn't show up as light/plug (only as sensor) = uncontrollable via API, lost control of multiple switches operating 1 light
Batterie Problem
Sonoff Disconnect
All Ikea Tradfri control outlets are loosing connection
Raspbee II - not found in Phoscon Web App
Zigbee devices on Conbee 2 with Phoscon in Home Assistant not responding
Devices not connected after Deconz and Raspbee2 Update
Sonoff device not working
Devices becoming unreachable, why?
deCONZ / Phoscon don't work anymore
Conbee III does not find revolt NX-5276
Pairing not enabling RFDL-ZB-MS motion sensing, did before just fine
Sonoff ZBMINIL2 reliability
Current deconz (2.24.3 & 2.25.1) slow in response after time
Router gave new IP to host, devices are not controllable anymore
All Zigbee devices not working
Stop working after 3years
Deconz almost uncontrollable, but works
Loosing new devices after reboot
[Solved] HUE Lightstrip Plus V4 on PhosconAPP 2.24.2 cannot integrate into the system
Xiaomi Mi Light Detection Sensor stops updating
Sensor status stops working after a short time
Devices not reachable
HEX-Sensor Names after Pi update in deconz
SmaBit AV2010/21C Door Sensor does not connect to DeConz
deCONZ looses connection on a frequent basis
Constantly losing connection to Ikea Switches and Ledvance Smat+ Plugs
Cannot find Ikea lights
Conbee 2 Can't pair IKEA lights and dimmer
Raspbee 2 not recognized on Pi Zero W 2
Constant disconnecting sounds trying to set up CONBEE II
Philips Hue Lightstripe don't work
A post was merged into an existing topic: SmaBit AV2010/21C Door Sensor does not connect to DeConz
