Hi there,
I am a new User here (so only 2 links). I recently bought a Raspberry 4B and a Waveshare UPS-HAT as well as a Raspbee II.
After seemingly failing to install the drivers for the HATs properly on an openHABIAN-System, I decided to take a step back and flashed the Raspian Buster headless Image according to the official manual. Naturally I removed all HATs except the Raspbee II.
Although connecting via SSH is no problem at all I am still unable to connect to the Pi or rather the deconz-Service via the phoscon web-App.
I already searched for “Raspbee II”, “deconz app” and “phoscon app” and checked the following topics but could not find a solution for my problem. I checked the following topics:
- Failing to flash Raspbee 2
- Raspbee II and deconz - connection issue
- Phoscon App does not detect Conbee ii
The other found topics did not seem to match my problem.
It is my understanding, that I need to get access over the phoscon-App before starting to integrate the system/raspbeeII into openhabian or similiar systems.
After studying the other topics I also captured logs according to this manual(logs). However I am unsure what would be the proper command to disable logging since it is not written in the topic.
Would
/usr/bin/deCONZ -platform minimal --dbg-aps=0 --dbg-info=0 --dbg-error=0
be the proper command?
