Aqara Wireless Remote Switch H1 loosing connection every two days
I am using a Aqara Wireless Remote Switch H1 and after one or two days it just does not respond any more. It does not what I want it to (e.g. turn my lights on; consequently I don’t get any deconz_event in Homeassistant either) but the switch also does not even flash it’s LEDs at me when I press a button. Pairing the switch with the ConBee fixes everything tho (temporarily).
The device in question is “Bett Schalter”:
Environment
  • Host system: Raspberry
  • Running method: Home Assistent deCONZ Add-on
  • Firmware version: 26660700
  • deCONZ version: 2.12.06
  • Device: ConBee II
  • Do you use an USB extension cable: no
  • Is there any other USB or serial devices connected to the host system? no
Can you share some logs?
What kind of logs are you looking for?
Or rather logs of what?
Nothing happens if I press the button of my switch. That is the problem :smiley:
I don’t see a reaction to my button presses in the deconz debug levels for example.
I literally get nothing when pressing the button. @Mimiix
:slight_smile:
