Here is some log data for a window sensor SNS-TF-HT when it was ok:
16:41:19:036 [INFO] - No button map for: lumi.sensor_magnet.aq2, unicast to: 0x0000, endpoint: 0x01, cluster: BASIC (0x0000), command: 0x0A, payload: 01FF421D0121DB0B03281B0421A84305213100062405000000000A21A769641000, zclSeq: 193
16:41:19:036 ZCL attribute report 0x00158D00042D1A7F for cluster: 0x0000, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
16:41:19:036 payload: 01ff421d0121db0b03281b0421a84305213100062405000000000a21a769641000
16:41:19:036 Websocket 172.16.1.1:46070 send message: {“attr”:{“id”:“19”,“lastannounced”:null,“lastseen”:“2024-08-23T15:41Z”,“manufacturername”:“LUMI”,“mode”:1,“modelid”:“lumi.sensor_magnet.aq2”,“name”:“SNS-TF-HT”,“swversion”:“0.0.0_0003”,“type”:“ZHAOpenClose”,“uniqueid”:“00:15:8d:00:04:2d:1a:7f-01-0006”},“e”:“changed”,“id”:“19”,“r”:“sensors”,“t”:“event”,“uniqueid”:“00:15:8d:00:04:2d:1a:7f-01-0006”} (ret = 348)
16:41:19:036 Websocket 172.16.1.2:49157 send message: {“attr”:{“id”:“19”,“lastannounced”:null,“lastseen”:“2024-08-23T15:41Z”,“manufacturername”:“LUMI”,“mode”:1,“modelid”:“lumi.sensor_magnet.aq2”,“name”:“SNS-TF-HT”,“swversion”:“0.0.0_0003”,“type”:“ZHAOpenClose”,“uniqueid”:“00:15:8d:00:04:2d:1a:7f-01-0006”},“e”:“changed”,“id”:“19”,“r”:“sensors”,“t”:“event”,“uniqueid”:“00:15:8d:00:04:2d:1a:7f-01-0006”} (ret = 348)
16:41:19:037 Websocket 172.16.1.1:46070 send message: {“config”:{“battery”:100,“on”:true,“reachable”:true,“temperature”:2700},“e”:“changed”,“id”:“19”,“r”:“sensors”,“t”:“event”,“uniqueid”:“00:15:8d:00:04:2d:1a:7f-01-0006”} (ret = 167)
16:41:19:037 Websocket 172.16.1.2:49157 send message: {“config”:{“battery”:100,“on”:true,“reachable”:true,“temperature”:2700},“e”:“changed”,“id”:“19”,“r”:“sensors”,“t”:“event”,“uniqueid”:“00:15:8d:00:04:2d:1a:7f-01-0006”} (ret = 167)
16:41:19:037 Websocket 172.16.1.1:46070 send message: {“e”:“changed”,“id”:“19”,“r”:“sensors”,“state”:{“lastupdated”:“2024-08-23T15:41:18.995”,“open”:false},“t”:“event”,“uniqueid”:“00:15:8d:00:04:2d:1a:7f-01-0006”} (ret = 159)
16:41:19:037 Websocket 172.16.1.2:49157 send message: {“e”:“changed”,“id”:“19”,“r”:“sensors”,“state”:{“lastupdated”:“2024-08-23T15:41:18.995”,“open”:false},“t”:“event”,“uniqueid”:“00:15:8d:00:04:2d:1a:7f-01-0006”} (ret = 159)
16:41:19:038 APS-DATA.request id: 127, addrmode: 0x03, addr: 0x00158D00042D1A7F, profile: 0x0104, cluster: 0x0000, ep: 0x01 → 0x01 queue: 0 len: 5 tx.options 0x00
16:41:19:038 asdu (length: 5): 10C1000100
16:41:19:038 APS-DATA.request id: 128, addrmode: 0x03, addr: 0x00158D00042D1A7F, profile: 0x0000, cluster: 0x0033, ep: 0x00 → 0x00 queue: 1 len: 2 tx.options 0x04
16:41:19:038 asdu (length: 2): 9B00
16:41:19:063 APS-DATA.confirm id: 127, status: 0x00 SUCCESS
16:41:19:063 APS-DATA.confirm request id: 127 → erase from queue
16:41:19:126 aps request id: 127 finished, erase from queue
16:41:19:229 APS-DATA.indication srcAddr: 0x0EF2, srcEp: 0x02 dstAddrMode: 2, profile: 0x0104, cluster: 0x0406, lqi: 255, rssi: -73
16:41:19:229 asdu: 08000a00001800
16:41:19:230 0x001788010213CFD2: update ZCL value 0x02/0x0406/0x0000 after 0 s
16:41:19:231 [INFO] - No button map for: SML001, unicast to: 0x0000, endpoint: 0x02, cluster: 0x0406, command: 0x0A, payload: 00001800, zclSeq: 0
16:41:19:231 ZCL attribute report 0x001788010213CFD2 for cluster: 0x0406, ep: 0x02, frame control: 0x08, mfcode: 0x0000
16:41:19:231 payload: 00001800
16:41:19:231 Websocket 172.16.1.1:46070 send message: {“e”:“changed”,“id”:“150”,“r”:“sensors”,“state”:{“lastupdated”:“2024-08-23T15:41:19.230”,“presence”:false},“t”:“event”,“uniqueid”:“00:17:88:01:02:13:cf:d2-02-0406”} (ret = 164)
16:41:19:231 Websocket 172.16.1.2:49157 send message: {“e”:“changed”,“id”:“150”,“r”:“sensors”,“state”:{“lastupdated”:“2024-08-23T15:41:19.230”,“presence”:false},“t”:“event”,“uniqueid”:“00:17:88:01:02:13:cf:d2-02-0406”} (ret = 164)
16:41:19:231 APS-DATA.request id: 131, addrmode: 0x02, addr: 0x0EF2, profile: 0x0104, cluster: 0x0406, ep: 0x01 → 0x02 queue: 1 len: 5 tx.options 0x04
16:41:19:231 asdu (length: 5): 10000B0A00
16:41:19:244 APS-DATA.confirm id: 131, status: 0x00 SUCCESS
16:41:19:244 APS-DATA.confirm request id: 131 → erase from queue
16:41:19:287 aps request id: 131 finished, erase from queue
16:41:19:357 APS-DATA.indication srcAddr: 0xD8B7, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0400, lqi: 255, rssi: -73
16:41:19:357 asdu: 18940a00002180b7
16:41:19:359 [INFO] - No button map for: lumi.sen_ill.mgl01, unicast to: 0x0000, endpoint: 0x01, cluster: 0x0400, command: 0x0A, payload: 00002180B7, zclSeq: 148
16:41:19:359 ZCL attribute report 0x54EF4410000C2BF2 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
16:41:19:359 payload: 00002180b7
16:41:19:359 Websocket 172.16.1.1:46070 send message: {“e”:“changed”,“id”:“37”,“r”:“sensors”,“state”:{“dark”:false,“daylight”:true,“lastupdated”:“2024-08-23T15:41:19.359”,“lightlevel”:46976,“lux”:49831},“t”:“event”,“uniqueid”:“54:ef:44:10:00:0c:2b:f2-01-0400”} (ret = 206)
16:41:19:360 Websocket 172.16.1.2:49157 send message: {“e”:“changed”,“id”:“37”,“r”:“sensors”,“state”:{“dark”:false,“daylight”:true,“lastupdated”:“2024-08-23T15:41:19.359”,“lightlevel”:46976,“lux”:49831},“t”:“event”,“uniqueid”:“54:ef:44:10:00:0c:2b:f2-01-0400”} (ret = 206)
16:41:19:911 rule event /config/localtime: 16:41:18.911 → 16:41:19.910 (999ms)
