This application is temporarily over its serving quota. Please try again tomorrow
Hi all,
What does “This application is temporarily over its serving quota. Please try again tomorrow” mean?
This is not funny since we can’t control our lamps anymore! :frowning:
And, another question, when using scenes, the lamps does not fade to on / off, only when turning on or off a group.
i have setup fading to 20 seconds, but this is also not working :frowning:
Where do you get this? Can you share a screenshot?
In domoticz, i have rebooted both and now its working again, but give me an error about some api maximum… i have clean the api list. now this error is gone also.
why so many errors :frowning:
i was really happy with deconz at the beginning, but everytime we added more lamps (in the garden) its getting more and more faulty
31 devices now, and i think there will be many more to come.
for this i used an philips hue gateway, and does never had any troubles, but since i want to have more control about the zigbee lamps / switches, etc its getting more annoying
Can you please share where you got the error? A screen?
yes, the error about the serving quota was a popup in domoticz, the api was in the log.
i can’t reproduce both again as i have rebooted the gateway and domoticz and cleaned the api list, after that both errors disappeared
@Smanar can you reply here?
Heu, yes, but I m curious to see the error log.
For me this message is from the meteo service (limited request by the API) not the deconz plugin, so I hope more information with the complete message.
About the Fade problem
i buyed an 10 inch tablet and now i can make scenes, so… I have set all scenes IN deconz…
so far so good, and i can control them in domoticz.
But… why does a group on/off fade dim to the value, and does the scene not?
i have setup in all scenes that i want to fade in all lamps in that scene for 10 seconds, but the fading is not working?
when turning on or off a group the fade is working great, why is this?
I never use Scene, only Group. Group is a Zigbee feature, Scenes are software stuff.
And on my side I never use scenes. So idk how it work on deconz and what do phoscon when you use it to make the scene.
You have same stuff in the scene ? perhaps there is a bulb that don’t support the dim feature inside ?
Can you show the scene JSON ? You can find it in phoscon / help / API Information / groups
Have you tried the scene in domoticz and phoscon too (If it s possible on phoson) ?
Hi Smanar,
thanks for answering this topic.
I must use a scene, because:
  1. Loss of signal? - #20 by Sjonnie
  2. i need different colors on some lamps, so turning them on is not only what i need.
    "8": {
        "action": {
            "alert": "none",
            "bri": 71,
            "colormode": "ct",
            "ct": 588,
            "effect": "none",
            "hue": 0,
            "sat": 127,
            "scene": "1",
            "xy": [
                0.526894,
                0.446311
        "devicemembership": [],
        "etag": "4cfc1ff2252e4aaf59ddbee56eb0a353",
        "hidden": false,
        "id": "8",
        "lights": [
            "7",
            "5",
            "9",
            "4",
            "10",
            "8",
            "6",
            "1"
        "lightsequence": [],
        "multideviceids": [],
        "name": "GroepTuin&Veranda",
        "scenes": [
                "id": "1",
                "lightcount": 6,
                "name": "Scene-Tuin&Veranda-AAN",
                "transitiontime": 200
            "all_on": true,
            "any_on": true
        "type": "LightGroup"
    "9": {
        "action": {
            "alert": "none",
            "bri": 127,
            "colormode": "hs",
            "ct": 0,
            "effect": "none",
            "hue": 0,
            "sat": 127,
            "scene": "1",
            "xy": [
                0,
                0
        "etag": "77d123c3d567ec503ed1978a3b579017",
        "hidden": false,
        "id": "9",
        "lights": [
            "7",
            "27",
            "5",
            "9",
            "22",
            "4",
            "15",
            "28",
            "18",
            "29",
            "24",
            "25",
            "26",
            "12",
            "10",
            "19",
            "8",
            "23",
            "14",
            "16",
            "11",
            "17",
            "6",
            "20",
            "1",
            "21",
            "13"
        "name": "GroepAlles",
        "scenes": [
                "id": "1",
                "lightcount": 25,
                "name": "Scene-AlleLampenUIT",
                "transitiontime": 50
            "all_on": true,
            "any_on": true
    "11": {
        "action": {
            "alert": "none",
            "bri": 127,
            "colormode": "hs",
            "ct": 0,
            "effect": "none",
            "hue": 0,
            "sat": 127,
            "scene": "1",
            "xy": [
                0,
                0
        "etag": "5b23f89eba08c0444a6a6c11268dc47f",
        "hidden": false,
        "id": "11",
        "lights": [
            "12",
            "11",
            "13"
        "name": "GroepWoonkamer",
        "scenes": [
                "id": "1",
                "lightcount": 3,
                "name": "Scene-Woonkamer-AAN",
                "transitiontime": 100
            "all_on": true,
            "any_on": true
    "12": {
        "action": {
            "alert": "none",
            "bri": 127,
            "colormode": "hs",
            "ct": 0,
            "effect": "none",
            "hue": 0,
            "sat": 127,
            "scene": "1",
            "xy": [
                0,
                0
        "etag": "b66b4cace9795208cf674fe3b11d5e17",
        "hidden": false,
        "id": "12",
        "lights": [
            "15",
            "18",
            "19",
            "14",
            "16",
            "17"
        "name": "GroepKeuken",
        "scenes": [
                "id": "1",
                "lightcount": 6,
                "name": "Scene-Keuken-AAN",
            "all_on": true,
            "any_on": true
    "13": {
        "action": {
            "alert": "none",
            "bri": 127,
            "colormode": "hs",
            "ct": 0,
            "effect": "none",
            "hue": 0,
            "sat": 127,
            "scene": "1",
            "xy": [
                0,
                0
        "etag": "a8877d181d914a91ad0b663ecd4b75fb",
        "hidden": false,
        "id": "13",
        "lights": [
            "22",
            "23",
            "20",
            "21"
        "name": "GroepEettafel",
        "scenes": [
                "id": "1",
                "lightcount": 4,
                "name": "Scene-Eettafel-AAN",
            "all_on": true,
            "any_on": true
    "14": {
        "action": {
            "alert": "none",
            "bri": 127,
            "colormode": "hs",
            "ct": 0,
            "effect": "none",
            "hue": 0,
            "sat": 127,
            "scene": null,
            "xy": [
                0,
                0
        "hidden": false,
        "id": "14",
        "lights": [
            "27",
            "28",
            "29",
            "24",
            "25",
            "26"
        "name": "GroepKantoor",
        "scenes": [],
            "all_on": true,
            "any_on": true
Yep but for me using domoticz scene is easier than using deconz scene.
Deconz scenes/rules are more for advanced user (or using phoscon) but the working mode is not as easy.
And they don’t decrease the zigbee request nedeed, only group make that (but they can decrease API request)
Seriously I don’t know enought scene to see something bad on your json, for me all is good.
If someone have a better look ?
Domoticz scenes will use simple API request, and from my memory only 1 request for all values (for 1 bulb, if you have 2 bulbs in the scene, you will have 2 requests). So thoses one will works for sure.
Just need to make a script to run domoticz scenes 1 by 1 delayed by X ms. (need to make test to find the better value)
If you realy want to use deconz scene, start with scene with few bulbs (and add them after), don’t start with too much of them, almost if you have different hardware.
I have the feeling this topic and the other topic are ending up on the same subject. Is that correct?
Ah, pardon me… You’re right.
i will stay ontopic and wait if i get these error about the servering quota again, i will let you know…
We still haven’t seen where it came from. For what I know phoscon would never give this message as it’s local hosted.
I found out that its coming from the plugin of domoticz (deCONZ.js) itself, but i don’t know the reason… >
    function checkDeCONZsetup() {
        return onInit.then(function() {
            var deferred = $q.defer();
            console.log('Checking DeCONZdsetup')
            url = 'https://dresden-light.appspot.com/discover'
            $http({
                method: 'GET',
                url: url,
            }).then(function successCallback(response) {
                // console.log('deCONZ: Discover Recieved')
                // console.log('response Data:' + angular.toJson(response.data, true))
                deferred.resolve(response.data)
                },function errorCallback(response) {
                console.error('Error getting deCONZ Discover data:' + angular.toJson(response, true) )
                bootbox.alert('<h2>' + $.t('Likely 503 Over Quota Error') + '</h2><br><p>' +
                $.t('This application is temporarily over its serving quota. Please try again tomorrow.') +
                '</p><a target="_blank" href="https://dresden-light.appspot.com/discover">https://dresden-light.appspot.com/discover</a>')
                deferred.reject(response)
Ha yes ^^.
Sorry this code part was not from me, so I haven’t thinked to this one.
Some days ago the phoscon server was HS Phoscon discover doesn't work
And another time more rencently.
When using the front end (so no impact on the domoticz plugin), I m using the discover url to retreive informations.
But it s strange, I have no result on my side, but still a 200 code message.
By curiosity, you don’t have a complete capture of the error message, from the code we can have some more information on it
And the url is bad, better to use https://phoscon.de/discover, I will update the code immediatly.
But I think all is working now ?
The https as well the http does both working without issues.
It gives correctly an output of the ID, Internal IP, MAC, etc so that is not the issue about the serving quota i guess…
I wish i had more information, but it was just an popup IN domoticz with an OKAY button with the message about this serving quota.
After rebooting both (Phoscon and Domoticz) the error went away and did not seen it since then.
No, from the code, you have only 2 possibilities
  • It work
  • It don’t work, and it’s the same error message, but different informations in the description.
The code don’t check if the error is 503 or 404.
I will edit the error message to something more “generic”.
Ah i see, okay…
Didnt see the error since then not anymore, only one time.
But i’m using the HUE bridge as temporarily zigbee controller now.
For now its working better for us, none troubles, but when deconz is updated with an “buffer” like said on other topic, i will use deconz again!
I’m using deconz in test environment atm, with a clean domoticz to doing some testing with NEON led.
If i cando something for you, just let me know.
