Phoscon.de/pwa/login.html does not work anymore
I have been using deCONZ GUI + Phoscon with a Conbee II on my local network for several years now. It has been running on a Raspberry Pi 3B.
I have always accessed Phoscon from a browser from other computers on my network by the Pi’s local IP address or hostname, http://192.168.1.91/pwa/login.html or http://rpi-3b.local/pwa/login.html.
However, I recently learned about http://phoscon.de/app and it doesnt appear to work for me. It shows a single gateway with the correct local IP address, but when I click on it, it displays a page:
# This is not the page you are looking for
The file /login2.html couldn't be found.
Looking at the URL, it is something like http://192.168.1.91/login2.html?.../login
If I change login2.html to login.html, it redirects me to the legacy deCONZ WebApp. Is it supposed to be login2? I saw the reference in the source code: https://github.com/dresden-elektronik/deconz-rest-plugin/blob/master/rest_configuration.cpp
since 2.23.01 the access over Phoscon App - Login does not work anymore.
No login screen will shown. Can any confirm that?
See:
2.24.0 the same.
With macOS Monterey I can connect via Browser to Phoscon.
With iPad OS no Login Screen / Gateway to choose.
I can confirm this. Phoscon show blank screen when you start Phoscon on IOS. I also tried Safari for IOS and same problem.
It fails both with Phoscon App url and with local phoscon 2.24.0 beta which I just upgraded to in the hope it would fix the problem. It is really annoying that you have to grab a Windows machine to access Phoscon and cannot run on an iPad anymore.
Hey,
same Problem here.
Under IOS Phoscon Login doesn’t work anymore.
Hope for fixing, by next release.
Greets
We are aware of this problem and have already fixed it. The fix will be released in the next deCONZ beta release. I’ll bump the release builder that it gets out as soon as possible.
I apologize for the circumstances.
I want to clarify 2 things:
  1. We have changed the login page. When you call phoscon.de/pwa you will be redirected to phoscon.de/pwa/login2.html (before it was /login.html)
When you click at your Gateway you will be redirected to <your-ip>/login2.html
And there something went wrong and the browser will tell you “the page could not be found”.
You can add “pwa” like in <your-ip>/pwa/login2.html to open the correct page.
This will be fixed from us directly at the Phoscon App page. So no need to update deCONZ. The Update will be online this weekend or beginning next week.
And 2. is the iPhone / IPad bug when you call the Phoscon app in the browser on that devices.
This will also be fixed at the same time. You need to install the next deCONZ beta release.
I have just made tries on my side.
http://phoscon.de/app > http://phoscon.de/pwa > http://phoscon.de/pwa/ > http://phoscon.de/pwa/login2.html?1694733854304 > http://phoscon.de/pwa/login2.html?1694733854304#OVERVIEW
(Yeah a 301 redirection just for the missing /)
But I think it can depend of cache.
Ok so I haven’t finished the procedure, I have same issue. Even on other brower
Phoscon is broken in several ways recently. On my windows I had to change bookmarks
On my iPad it stopped working totally. And that is with local IP address links
Sorry there is a bug in the recent deCONZ version regarding using the Phoscon App in a browser on iOS. This has already been fixed and will be rolled out with the next version. Sorry for the inconvience.
I was running into the original issue on Google Chrome on a laptop, not on iOS. Is it the same issue?
To clarify 2 things:
I’ve migrated the 2 topics.
Manually adding pwa to <your-ip>/pwa/login2.html did redirect me to the correct login page for my gateway, but it did not accept my password.
Same issue here. I noticed that I have one switch that doesn’t work anymore. When I try to access the page : http://192.168.1.4/pwa/devices-switches.html it says
The file /pwa/devices-switches.html couldn’t be found.
  • the login2 page does not accept my password.
If the Login does not accept the password go back to the start page and start a new gateway scan.
It seems missing data in the browsers session storage is the problem and it needs to be re-filled with a gateway search.
the new Phoscon App version is available tomorrow at phoscon.de/pwa that will fix the missing /pwa in the link when you click at a gateway. and the new deCONZ beta version will be released thursday. It also includes the bugfix for iOS users.
@ChrisHae will this fix also the HA+deconz plugin setup? I am experiencing the same problem in this setup, and from my (probably too premature) understanding it won’t.
It’s being discussed here: Bump deCONZ to v2.23.1 by francescopeloi · Pull Request #3226 · home-assistant/addons · GitHub
This is where the login entry point is defined in the plugin: https://github.com/home-assistant/addons/blob/master/deconz/rootfs/usr/share/www/ingress.html#L289
Note that only non-beta deconz releases are usually released as deconz HA plugin.
Me to, and the gateway scan is really slow and redoing the scan does nothing for me. But if I exit deconz for node red or something like that and then back to deconz I get in to phoscon, but it’s empty. I can see a new blinds menu and some layout changes. But I can’t login.
