I removed all light sensors except for 2 essential ones. But it looks like they are generating a lot of reports somehow? It’s currently dark, so I would not expect them to keep reporting the same value of 0 Lux every few seconds or so? How is reporting frequency and change configured for these sensors, or is that hardcoded in the device? Could this be flooding deconz to the point of becoming unresponsive or does that look normal?Argh… deconz just hung again.
19:18:38:772 0a Parent NWK 0 (0x0000)
19:18:40:051 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:40:065 ZCL attribute report 0x84FD27FFFECE979C for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:40:870 Skip idle timer callback, too early: elapsed 814 msec
19:18:40:886 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:40:932 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:42:528 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:42:536 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:46:012 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:46:022 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:46:075 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:46:870 Skip idle timer callback, too early: elapsed 852 msec
19:18:47:341 ZCL attribute report 0x84FD27FFFECE979C for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:47:517 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:49:130 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:49:871 Skip idle timer callback, too early: elapsed 736 msec
19:18:50:825 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:50:844 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:51:870 Skip idle timer callback, too early: elapsed 463 msec
19:18:52:508 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:52:532 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:54:271 ZCL attribute report 0x84FD27FFFECE979C for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:54:870 Skip idle timer callback, too early: elapsed 593 msec
19:18:55:327 ZCL read attr 0x84FD27FFFECE979C, ep: 0x01, cl: 0x0006, attr: 0x0000, mfcode: 0x0000, aps.id: 144, zcl.seq: 214
19:18:55:365 ZCL read attr 0x84FD27FFFECE979C, ep: 0x01, cl: 0x0000, attr: 0x4000, mfcode: 0x0000, aps.id: 147, zcl.seq: 215
19:18:55:420 ZCL read attr 0x84FD27FFFECE979C, ep: 0x01, cl: 0x0000, attr: 0x4000, mfcode: 0x0000, aps.id: 149, zcl.seq: 216
19:18:55:816 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:57:372 ZCL read attr 0x84FD27FFFED24544, ep: 0x01, cl: 0x0006, attr: 0x0000, mfcode: 0x0000, aps.id: 164, zcl.seq: 219
19:18:57:396 ZCL read attr 0x84FD27FFFED24544, ep: 0x01, cl: 0x0000, attr: 0x4000, mfcode: 0x0000, aps.id: 166, zcl.seq: 220
19:18:57:425 ZCL read attr 0x84FD27FFFED24544, ep: 0x01, cl: 0x0000, attr: 0x4000, mfcode: 0x0000, aps.id: 168, zcl.seq: 221
19:18:57:516 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:57:524 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:18:58:571 sensor 117 (lumi.sensor_motion): disable presence
19:19:01:244 ZCL attribute report 0x84FD27FFFECE979C for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:01:258 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:01:530 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:01:536 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:01:954 Set sensor check interval to 1000 milliseconds
19:19:02:515 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:02:524 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:04:677 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:04:901 Device TTL 1505 s flags: 0x7
19:19:05:371 Skip idle timer callback, too early: elapsed 688 msec
19:19:05:743 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:05:751 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:07:184 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:07:510 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:09:599 ZCL attribute report 0x84FD27FFFECE979C for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:10:212 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:10:705 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:12:520 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:12:530 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:12:947 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:15:702 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:16:242 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:16:249 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:17:522 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:17:534 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:20:662 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:20:671 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:22:695 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:22:718 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:23:370 Skip idle timer callback, too early: elapsed 668 msec
19:19:25:022 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:25:634 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:27:490 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:27:504 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:28:178 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:28:876 ZCL attribute report 0x588E81FFFEFF604D for cluster: 0x0702, ep: 0x01, frame control: 0x08, mfcode: 0x0000
19:19:30:595 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:30:611 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:32:487 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:32:498 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:34:089 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:35:569 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:35:594 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:37:089 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:37:473 ZCL attribute report 0x04CF8CDF3C78B5DC for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:39:608 ZCL attribute report 0x84FD27FFFECE979C for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:40:813 ZCL attribute report 0x84FD27FFFED24544 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:40:824 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:19:40:847 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
Another update: when I choose “Edit DDF” on the sensor and pick “Hot reload”, the session becomes unresponsive right away. So that again indicates that it is related to DDF (note that the built-in Silver DDF was not loaded when I started deconz initially). Hopefully someone can reproduce this issue.
Update: Resetting these existing 2 devices (press pairing button 10s) and re-adding them seems to solve the excessive reporting issue for them. Again: not sure what caused them to report that frequently, this was never an issue in the past. So far no hangs.
