Use the tip of @Mimiix that can help you: Aqara TVOC ZHAAirQuality data - #2 by Mimiix to identity your sensor.
Can you see like name “AirQuality 240” or have you a other name?
If the device need it, it can’t work, it’sd probably missing in the DDF.
It this one https://github.com/dresden-elektronik/deconz-rest-plugin/blob/master/devices/xiaomi/xiaomi_airmonitor_acn01.json ?
If yes, the DDF is probably incomplete, it s for that @sirinveen have made the bind itself using the Mimixx tips.
Do you know how to add them in the DDF ? DDF cheat sheet · dresden-elektronik/deconz-rest-plugin Wiki · GitHub
Hi @jan666
I think you must delete and renew your sensor because some cluster are missing like Temperature and Analog Input (basic).
And after use the tips from @Mimiix I tell you before (push reset button of the sensor and quickly after Read node descriptor and/or Read simple descriptors) → do this 1-3 times and show after if you have all clusters see below).
Here my screenshot of AirQuality:
Can you also provide screenshots of air quality and airqualityppb?
For example air quality:
Ok, I deleted the sensor, re-added it and read the descriptors. Now I have:
…and I only have “ZHAHumidity” and “ZHATemperature” sensors - no more ZHAAirQuality
That’s the issue with the Xiaomi’s: Its a bit hard to get everything properly paired.
I paired again w/o deleting first. now I have all 3 sensors. It still looks like on the screenshots
Now be patient 1-2 hours or more and you will see he update temperature humidity and air quality.
And also the battery will be updated at 100%. Begin always with null or zero.
time age_secs airquality airqualityppb battery id name source type
2022-03-03T02:55:14.076352126Z 0 excellent 32 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-02T20:59:02.841057587Z 0 excellent 63 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-02T15:00:53.999103509Z 0 good 94 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-02T14:05:57.115774591Z 0 good 126 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-02T13:14:59.748674597Z 0 good 174 32 60 AirQuality 60 websocket ZHAAirQuality
2022-03-02T13:14:29.781129757Z 0 good 142 32 60 AirQuality 60 websocket ZHAAirQuality
2022-03-02T13:13:59.952462607Z 0 good 106 32 60 AirQuality 60 websocket ZHAAirQuality
2022-03-02T13:12:54.516076922Z 0 good 71 32 60 AirQuality 60 websocket ZHAAirQuality
2022-03-02T13:12:21.155112894Z 0 excellent 39 32 60 AirQuality 60 websocket ZHAAirQuality
2022-03-02T13:10:41.235452774Z 0 excellent 7 32 60 AirQuality 60 websocket ZHAAirQuality
Not really a success
What is the issue ?
Value are updated when you read them using the GUI, but not in normal use ? No periodic report ?
Yes, no updates. Temperature (last update: 2022-03-04 07:29:21
) and humidity (last update 2022-03-04 07:23:09
) is updated. Airqualits is not (still last update at 2022-03-03 03:55:14)
From my experience, it only updates TVOC when there is a significant change. I created an automation to push the changes read from HA to telegram and I receive the most 1 notification per day.
If I move the sensor to a different place with very different values it updates right away.
For me it can just be an issue because the binding are missing in the DDF.
You can try to set them yourself using deconz Device Support immax Keyfob-ZB3.0 · Issue #2196 · dresden-elektronik/deconz-rest-plugin · GitHub
Or add them in the DDF.
Just to try you can set one for the temperature
Cluster 0x0402
attribute 0x0000
Value
min = 10; rmax = 300; change = 20;
It reports all the time now. Is this good or bad? is it too often?
2022-03-08T12:57:32.199188188Z 0 excellent 57 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:56:51.180549108Z 0 excellent 55 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:56:30.212738199Z 0 excellent 56 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:55:00.333152963Z 0 excellent 55 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:54:30.302050964Z 0 excellent 56 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:54:00.419621671Z 0 excellent 55 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:53:30.388922761Z 0 excellent 56 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:53:00.480589691Z 0 excellent 55 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:52:30.512151039Z 0 excellent 57 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:51:30.653686596Z 0 excellent 55 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:50:30.656761488Z 0 excellent 56 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:50:00.824349153Z 0 excellent 55 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:48:30.924822228Z 0 excellent 56 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:48:00.929227916Z 0 excellent 54 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:47:01.06072491Z 0 excellent 55 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:46:01.106574057Z 0 excellent 56 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:45:31.195672416Z 0 excellent 57 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:45:01.230551374Z 0 excellent 55 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:44:01.327744909Z 0 excellent 56 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:43:31.326759019Z 0 excellent 55 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:41:01.552403773Z 0 excellent 56 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:40:31.641788497Z 0 excellent 55 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:40:01.667589394Z 0 excellent 56 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:39:01.772443559Z 0 excellent 54 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:37:31.877068266Z 0 excellent 55 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:37:02.007319036Z 0 excellent 56 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:36:02.049775282Z 0 excellent 55 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:35:32.082361896Z 0 excellent 54 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:35:02.140094285Z 0 excellent 56 100 60 AirQuality 60 websocket ZHAAirQuality
2022-03-08T12:33:32.299752048Z 0 excellent 55 100 60 AirQuality 60 websocket ZHAAirQuality
How did you achieve that?
I did what @Smanar said: Aqara TVOC ZHAAirQuality data - #53 by Smanar / Aqara TVOC ZHAAirQuality data - #54 by jan666
Depend of what you want, but for me it’s bad, realy bad for battery sensor. It’s a temperature sensor, a report every 30mn is enought for me, but it’s personnal.
Min is the minium delay without report.
Max is the maximum delay without report.
Change is the minimum value to trigger a report.
On my side I would use bigger values than the ones used on the test.
And if it work like that, it mean, I m right, it’s just because you miss the bind configuration on the DDF.
Do you have tried to set them using the DDF editor ? To improve the DDF ?
I feel a little bit supid asking. But whats the correct min/max/change Setting for “every 30 minutes”?
I just tried but saving failes:
the files are owned by “root”:
drwxr-xr-x 2 root root 4.0K Feb 7 06:45 .
drwxr-xr-x 19 root root 4.0K Feb 7 06:45 ..
-rw-r--r-- 1 root root 5.0K Feb 6 20:46 aq1_vibration_sensor.json
-rw-r--r-- 1 root root 610 Feb 6 20:46 aq1_vibration_sensor_orientation.js
-rw-r--r-- 1 root root 5.1K Feb 6 20:46 xiaomi_airmonitor_acn01.json
-rw-r--r-- 1 root root 268 Feb 6 20:46 xiaomi_battery.js
-rw-r--r-- 1 root root 3.3K Feb 6 20:46 xiaomi_gzcgq01lm_light_sensor.json
-rw-r--r-- 1 root root 599 Feb 6 20:46 xiaomi_known_issues1.md
-rw-r--r-- 1 root root 1.7K Feb 6 20:46 xiaomi_mccgq14lm_openclose_sensor.json
-rw-r--r-- 1 root root 5.9K Feb 6 20:46 xiaomi_zncz04lm_smart_plug.json
I run the GUI as “pi”. Should I really run the gui as root?
