How to get rid of these (You have 11 API keys memorised, some of them are probably useless, can use the API_KEY.py tool or the Front end to clean them) messages in Domoticz?
It drives me crazy!
Thanks…
It drives me crazy!
Thanks…
You should ask the Domoticz folks, deconz doesn’t have anything like that.
Yep, it s a domoticz error message.
You can just ignore it, or delete the useless api key in domoticz / custom / deconz / tools / Clean api key list.
To prevent that, bookmark the phoscon page after the login (it s the login procedure that generate a new api key)
Thanks… but how do i bookmark that page from inside domoticz?
It s not domoticz that provoke that ^^. Domoticz don’t create API key, you need to create one at startup yourself (and you already have do that if I m right)
It’s the login procedure on phoscon (on the browser), if you bookmark the page after, you can access to phoscon without login (only 1 time to generate the cookie), it s the workaround I m using on my side.
But this message is just an information, you can ignore it, deconz can work even you have 200 api key in the database.
I changed the script and removed the line with that message, okay now.
You can too use the clean feature to remove all useless entries, you just have a button to press.
That button is not working anymore…
Since last updates (domoticz) i’m getting a lot of zigbee errors as wel like “unknown device/group” while there is no device at all that is not working/not seen…
error that we seen is: “Zigbee: Websocket error, unknown device > 65520 (groups)”
also when looking at the conbee config (in domoticz) i see a lot of older stuff that is not used anymore, i think this have to do with these errors:
"1DDB2C00E9": {
"create date": "2021-06-07T23:16:38",
"last use date": "2021-11-04T17:21:09",
"name": "Hue Essentials#SM-G986B"
"1E2D9C91CE": {
"create date": "2022-06-22T21:35:40",
"last use date": "2022-06-22T21:54:50",
"24D20F3319": {
"create date": "2022-06-22T22:08:08",
"last use date": "2022-06-22T22:09:39",
"36565C7401": {
"create date": "2022-05-26T21:14:37",
"last use date": "2022-06-13T20:02:09",
"name": "Domoticz"
"3EF03E2B1E": {
"create date": "2022-06-22T21:20:31",
"last use date": "2022-06-22T21:20:31",
"516845F770": {
"create date": "2022-06-22T20:20:17",
"last use date": "2022-06-22T20:20:17",
"5C5BDC39E6": {
"create date": "2021-09-22T21:57:07",
"last use date": "2021-09-22T21:57:07",
"name": "domoticz_deconz"
"754BEFF79B": {
"create date": "2022-06-13T20:02:40",
"last use date": "2022-07-08T18:05:31",
"96DAA2F2CB": {
"create date": "2020-07-22T09:54:31",
"last use date": "2022-05-26T21:09:30",
"name": "Domoticz"
"B0C96BB140": {
"create date": "2021-11-11T09:57:14",
"last use date": "2021-11-11T09:57:14",
"D02C589D08": {
"create date": "2021-01-04T19:20:59",
"last use date": "2021-01-27T21:29:45",
"name": "Hue Essentials#S62 Pro"
"E3D5E57F53": {
"create date": "2022-06-22T21:21:38",
"last use date": "2022-06-22T21:21:38",
"E4291AEF9E": {
"create date": "2022-06-22T20:15:23",
"last use date": "2022-06-22T20:16:34",
"EC421E6E51": {
"create date": "2021-11-11T09:58:47",
"last use date": "2021-11-11T09:58:47",
"ED4F9B4F48": {
"create date": "2022-06-22T21:21:05",
"last use date": "2022-06-22T21:21:05",
"ED7B6CB0EC": {
"create date": "2022-06-22T20:22:36",
"last use date": "2022-06-22T20:31:03",
"zigbeechannel": 15
but i don’t find out the way to delete this config to start empty again…
Ha Hue essential make useless key too ?
Can try this code to remove them too Update deCONZ.js · Smanar/Domoticz-deCONZ@15ce6f7 · GitHub
The button will remove too key like “Hue Essentials#SM-G986B” but not the “domoticz_deconz”
Can you be more explicit ? Do you have the full error message ? to know if its from domoticz, the plugin or deconz ?
its inside domoticz, every day a couple errors…
So this is a plugin issue, can use plugin github or domoticz forum.
But you can have this error 1 time every time the plugin restart.
It’s the hidden group, so the plugin can’t guess it when it start, but when it detect it in websocket, it make a request to retreive information and add it in the plugin.
So on normal way you have this error only 1 time
Try to clear cache after the JS code edition, on my side I haven’t hue essential, but it have worked for other key.
the error is coming in when activating every scene / switch in zigbee from domoticz…
can i remove that “hidden” group?
why is it for? i do not need any hidden group?
also, i cannot clean the api keys anymore…
at every reboot of domoticz its counting a new api key?
2022-07-08 20:35:33.223 Status: Zigbee: You have 68 API keys memorised, some of them are probably useless, can use the API_KEY.py tool or the Front end to clean them
front end cleaning is not working…
I will make a test tommorow, not logic you have it more than 1 time.
To reproduce it, I just need to create a domoticz scene or a deconz scene (using phoscon) ?
Nope, this group is the “all device” group, not deletable.
Nope, domoticz always use the same key, the one called “domoticz”, I need to check where are from the one called “domoticz_deconz”, probably the front end, but I haven’t them on my side, I need to check what you are doing differently.
Can you check the “dev tools panel” when using this button to check JS error on the browser ?
@BarryT I have made some tries.
If you have problem, tell me your browser I will explain how to do, but if you have access on them, pls use one domoticz forum or the plugin gthub.
I will share some debug, hold on…
i have disabled info, so only status and errors are seen.
Ofcourse, after some testing in debugging mode no errors are seen…
Will reply as soon there is something changing.
The only thing it keep saying at the moment is: “Status: Zigbee: ### Device GROUP_All(Zigbee - All) Not in deCONZ ATM, the device is deleted or not ready.”
It doesnt matter if i add the device, this message keeps coming.
