Is there a way to use a SLZB-06M as a routeur with deconz ? I have one for a test.
Thanks,
Thanks,
There is a post about this device:
Yes indeed, but the people who bought it say they use it in controller mode with Z2MQTT. My question concerns the router mode of this stick with Deconz.
I don’t read that. desyco says to use deCONZ in home assistant and to use SLZB-06M for a month without problem.
not explicitly, but clearly :
The setup took me some time, but once setup and working, it is worth the change (for me).
Adding a router doesn’t take long. and he didn’t reconnect or post on the forum after that.
At no point does he mention router mode, but “After a month of working with this adapter”. He uses it in coordinator mode, which is impossible with deconz.
But you already have one ?
Why you don’t make a try ? Just configure it as router in its embeded web page, them include it.
Changes will be visible in the GUI, I don’t see a reason for it will not work.
Yes why not but I don t want to do something wrong with my network. Will try this week end.
If you can configure as router and perhaps the same static configuration as found in the deCONZ network settings (pan id, channel, etc.) you might be able to join the device.
