### Does the issue really belong here?
- [X] I definitively want to report a …bug within deCONZ or its REST-API
### Is there already an existing issue for this?
- [X] I have searched the existing issues and there is none for the bug at hand
### Describe the bug
I am using Home Assistant OS on a Raspberry Pi 4 with deCONZ integration, deCONZ Addon and a RaspBee II Gateway. All worked fine for some years.
Suddenly all the Aqara temperature and humidty sensor didn't refresh anymore and kept a static state. They were not shown as unavailable but the state has not changed for hours.
The zigbee temperature sensors (integrated via deCONZ and raspbee II) are not refreshed. I don't have an explanation for this.
All connected temperature sensors stay at a static value at the same time. Shutting down Home Assistant and power cycle the hardware helps for a certain time but the problem is occurring again.
I have other devices in the network that are working fine. LIDL window sensor, LIDL switches, Philips Hue Dimmers, IKEA Styrbar Dimmers, IKEA blinds. --> The only issue is with the Aqara Multisensors and motion sensors.
### Steps to reproduce the behavior
1. Checked HA version --> Home Assistant OS latest stable version (2024.10.1) - Addon up to date.
2. I realized that the firmware of the RaspBee II was not up to date. I decided to migrate to a ConBee III and use the RaspBee II for another network and make the firmware update later.
3. I've flashed the latest firmware (26530900) to the ConBee III and uploaded the backup to it. I had to manually connect the sensors again. It worked for some minutes or hours and then I observed the same behavior -> static values.
4. After monitoring this for 1 day, I changed the Zigbee channel from 15 to 20 and monitored it for another day. I did not notice any improvement.
### Expected behavior
Regularly refreshed values like usually at least after firmware update.
### Screenshots
### Environment
- Host system: (Raspberry Pi )
- Running method: Home Assistant OS, deCONZ Integration and Addon
- Firmware version: (26530900)
- deCONZ version: (2.28.1)
- Device: ConBee III / RaspBee II (both with same issue)
- Is there any other USB or serial devices connected to the host system? If so: Which? - SSD hard drive
### deCONZ Logs
00:14:32:517 ZCL attribute report 0x00158D000802B149 for cluster: 0x0000, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:14:42:665 ZCL attribute report 0x0C4314FFFE53A42D for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:15:01:951 ZCL attribute report 0x00158D0007E0B655 for cluster: 0x0000, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:15:02:268 ZCL attribute report 0x001788010C2AA81D for cluster: 0x0001, ep: 0x01, frame control: 0x08, mfcode: 0x0000
00:15:22:503 ZCL attribute report 0x0017880108F48347 for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
00:15:30:661 ZCL attribute report 0x84FD27FFFECF6AFA for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:15:43:448 ZCL attribute report 0x60A423FFFE053761 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:16:02:252 ZCL attribute report 0x00158D0008378574 for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:16:02:332 ZCL attribute report 0x00158D0008378574 for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:16:02:411 ZCL attribute report 0x00158D0008378574 for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:16:05:148 ZCL attribute report 0x00158D000AF04E2E for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:16:05:276 ZCL attribute report 0x00158D000AF04E2E for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:16:05:323 ZCL attribute report 0x00158D000AF04E2E for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:16:31:350 ZCL attribute report 0x00158D000AF04630 for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:16:31:396 ZCL attribute report 0x00158D000AF04630 for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:16:31:411 ZCL attribute report 0x00158D000AF04630 for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:16:49:908 ZCL attribute report 0x84FD27FFFED0DFCE for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:16:52:397 ZCL attribute report 0x00158D0007DF8A99 for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:16:52:445 ZCL attribute report 0x00158D0007DF8A99 for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:16:52:461 ZCL attribute report 0x00158D0007DF8A99 for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
127.0.0.1: new handler Process
127.0.0.1 - - [11/Oct/2024 00:21:45] "GET //websockify HTTP/1.1" 101 -
127.0.0.1 - - [11/Oct/2024 00:21:45] 127.0.0.1: Plain non-SSL (ws://) WebSocket connection
127.0.0.1 - - [11/Oct/2024 00:21:45] 127.0.0.1: Path: '/websockify'
127.0.0.1 - - [11/Oct/2024 00:21:45] connecting to: 127.0.0.1:5900
127.0.0.1 - - [11/Oct/2024 00:28:07] 127.0.0.1:5900: Client closed connection
127.0.0.1 - - [11/Oct/2024 00:28:07] 127.0.0.1:5900: Closed target
00:17:16:296 ZCL attribute report 0xB4E3F9FFFE786606 for cluster: 0x0006, ep172.30.32.2 - - [11/Oct/2024:00:28:07 +0200] "GET /novnc/websockify HTTP/1.1" 101 1457179 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:131.0) Gecko/20100101 Firefox/131.0"
00:17:33:820 0x84FD27FFFED0DFCE found group 0xFFF0
00:17:33:820 0x84FD27FFFED0DFCE found group 0x001D
00:17:35:180 ZCL attribute report 0x00158D000AF008E3 for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:17:35:245 ZCL attribute report 0x00158D000AF008E3 for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:17:35:277 ZCL attribute report 0x00158D000AF008E3 for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:17:36:172 0x84FD27FFFECF6AFA found group 0xFFF0
00:18:47:750 ZCL attribute report 0x60A423FFFE050416 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:18:51:350 ZCL attribute report 0x842E14FFFEE1BDD2 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:18:52:550 ZCL attribute report 0x60A423FFFE0040D1 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:19:45:599 ZCL attribute report 0x0C4314FFFE53A42D for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:19:47:279 ZCL attribute report 0x0C4314FFFE53A42D for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:20:01:255 ZCL attribute report 0x001788010C2AA81D for cluster: 0x0001, ep: 0x01, frame control: 0x08, mfcode: 0x0000
00:20:23:646 ZCL attribute report 0x0017880108F48347 for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
00:20:34:300 ZCL attribute report 0x84FD27FFFECF6AFA for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:20:46:139 ZCL attribute report 0x60A423FFFE053761 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:21:49:754 ZCL attribute report 0x50325FFFFE243327 for cluster: 0x0001, ep: 0x01, frame control: 0x08, mfcode: 0x0000
00:21:53:177 ZCL attribute report 0x84FD27FFFED0DFCE for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:22:00:125 ZCL attribute report 0x00158D000AF04664 for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:22:00:173 ZCL attribute report 0x00158D000AF04664 for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:22:00:188 ZCL attribute report 0x00158D000AF04664 for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:22:18:917 ZCL attribute report 0xB4E3F9FFFE786606 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:23:07:156 binding for cluster 0x0006 of 0x84FD27FFFED0DFCE exists (verified by reporting)
00:23:07:156 skip configure report for cluster: 0x0006 attr: 0x0000 of node 0x84FD27FFFED0DFCE (seems to be active)
00:23:50:211 ZCL attribute report 0x60A423FFFE050416 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:23:55:660 ZCL attribute report 0x60A423FFFE0040D1 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:23:56:237 ZCL attribute report 0x842E14FFFEE1BDD2 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:24:48:614 ZCL attribute report 0x0C4314FFFE53A42D for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:24:50:165 ZCL attribute report 0x0C4314FFFE53A42D for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:25:00:227 ZCL attribute report 0x001788010C2AA81D for cluster: 0x0001, ep: 0x01, frame control: 0x08, mfcode: 0x0000
00:25:23:900 ZCL attribute report 0x0017880108F48347 for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
00:25:37:866 ZCL attribute report 0x84FD27FFFECF6AFA for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:25:48:937 ZCL attribute report 0x60A423FFFE053761 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:26:56:018 ZCL attribute report 0x84FD27FFFED0DFCE for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:27:21:557 ZCL attribute report 0xB4E3F9FFFE786606 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:28:52:708 ZCL attribute report 0x60A423FFFE050416 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:28:57:893 ZCL attribute report 0x842E14FFFEE1BDD2 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:28:58:964 ZCL attribute report 0x60A423FFFE0040D1 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:29:16:635 ZCL attribute report 0x00158D000802B149 for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:29:16:666 ZCL attribute report 0x00158D000802B149 for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:29:16:746 ZCL attribute report 0x00158D000802B149 for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:29:26:785 ZCL attribute report 0x00158D0007DF8A99 for cluster: 0x0000, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:29:51:593 ZCL attribute report 0x0C4314FFFE53A42D for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:29:59:132 ZCL attribute report 0x001788010C2AA81D for cluster: 0x0001, ep: 0x01, frame control: 0x08, mfcode: 0x0000
00:30:24:405 ZCL attribute report 0x0017880108F48347 for cluster: 0x0001, ep: 0x02, frame control: 0x08, mfcode: 0x0000
00:30:41:555 ZCL attribute report 0x84FD27FFFECF6AFA for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:30:51:630 ZCL attribute report 0x60A423FFFE053761 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:31:08:188 remove dead link for (4F7, 7EBF)
00:31:09:157 binding for cluster 0x0006 of 0x60A423FFFE053761 exists (verified by reporting)
00:31:09:157 skip configure report for cluster: 0x0006 attr: 0x0000 of node 0x60A423FFFE053761 (seems to be active)
00:31:11:156 binding for cluster 0x0006 of 0x842E14FFFEE1BDD2 exists (verified by reporting)
00:31:11:156 skip configure report for cluster: 0x0006 attr: 0x0000 of node 0x842E14FFFEE1BDD2 (seems to be active)
00:31:11:295 0x60A423FFFE053761 found group 0xFFF0
00:31:59:078 ZCL attribute report 0x84FD27FFFED0DFCE for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:32:24:237 ZCL attribute report 0xB4E3F9FFFE786606 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:32:38:929 ZCL attribute report 0x00158D000AF008E3 for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:32:39:137 ZCL attribute report 0x00158D000AF008E3 for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:32:57:895 ZCL attribute report 0x00158D000AF045FA for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:32:57:926 ZCL attribute report 0x00158D000AF045FA for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:32:57:958 ZCL attribute report 0x00158D000AF045FA for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:33:45:079 0x842E14FFFEE1BDD2 found group 0xFFF0
00:33:45:079 0x842E14FFFEE1BDD2 found group 0x0014
00:33:45:156 binding for cluster 0x0006 of 0x84FD27FFFECF6AFA exists (verified by reporting)
00:33:45:156 skip configure report for cluster: 0x0006 attr: 0x0000 of node 0x84FD27FFFECF6AFA (seems to be active)
00:33:56:864 ZCL attribute report 0x60A423FFFE050416 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:34:01:232 ZCL attribute report 0x842E14FFFEE1BDD2 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:34:03:882 ZCL attribute report 0x60A423FFFE0040D1 for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:34:36:724 ZCL attribute report 0x00158D000AF04630 for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:34:36:740 ZCL attribute report 0x00158D000AF04630 for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:34:54:604 ZCL attribute report 0x0C4314FFFE53A42D for cluster: 0x0006, ep: 0x0B, frame control: 0x18, mfcode: 0x0000
00:34:58:023 ZCL attribute report 0x001788010C2AA81D for cluster: 0x0001, ep: 0x01, frame control: 0x08, mfcode: 0x0000
00:35:01:143 ZCL attribute report 0x00158D0008378574 for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
00:35:01:207 ZCL attribute report 0x00158D0008378574 for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
### Additional context
Network size: 59 devices
Gateway: 1
Brands: Aqara, LIDL, Philips Hue, IKEA
