Update conbee II to conbee III in docker Container unsucessfull
I am trying to replace my Conbee II with the new Conbee III. Deconz is running on a Synology NAS in a Docker container.
When I follow the instructions and close the container, swap the Conbee II for the Conbee III, I get the following error message:
“error gathering device information while adding custom device “/dev/ttyACM0”: no such file or directory”
and the container no longer starts.
What can I do?
The Conbee III is /dev/ttyUSB0, try using this as device
That doesn’t work either. I did a new install with this.
How to change this in a running container?
Did you add this?
- DECONZ_BAUDRATE=115200
Yes, i did. Nothing changed.
Did you update your deCONZ to 2.24.2? The Conbee III is not supported in 2.23 and smaller.
Yes, i did.
The container is starting now, but the conbee III ist not found by deconz.
Its listed as Conbee and i am not able to connect.
Wich device name ist correct for the conbee III?
Conbee II = /dev/ttyACM0
Conbee III = /dev/ttyUSB0???
ConbeeIII is now working with /dev/ttyUSB0 and DECONZ_BAUDRATE=115200
it´detected as “normal” Conbee I in the Phoscon App but ist working.
Hi @Spy ,
I have the same problem, see here:
Greetings
Indeed inside Docker it’s not possible to query various USB descriptor information like product string.
The baudrate is the most important factor here to have it working.
The ConBee I vs. III text is only cosmetics, however I think we can also derive that info from the firmware once connected I’ll add a small fix for the upcoming version.
For me configuration
serial:
  port: /dev/ttyUSB0
  adapter: deconz
  baudrate: 115200
works !
Hi @azyzynski ,
Where do you enter this configuration?
Greetings
In configuration.yaml, I was running a new instance , and the gui was not available yet.
