I tryed to connect a SONOFF SNZB-02D but it don’t shows up.
Does it show in deconz?
It’s as if he can’t find it at all
Can you share some logs while pairing?
Where i see that?
And The Firmware Version is 2.19.01 / 19.9.2022
Here you can find it ![]()
Also, looks like you should update:
Support was added in 2.21.0
I don’t think that will help, as it won’t find the device at all. It doesn’t give a hint or anything. Could it be due to the outdated firmware?
ah ok
Did you know how to update the docker container?
I have no idea. I dont run docker ![]()
Ok i Updated the Docker Container now it works thanks.
