Yes, If you read them you can see the device use the window cvering cluster, so it 's a good new (else the code have nothing to see with the device)
But can’t be sure for the model id as the code is for many device and nothing to see with 3A manufacture.
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0102", outClusters: "0019", model: "E2B0-KR000Z0-HA", deviceJoinName: "SOMFY Blind Controller/eZEX" // SY-IoT201-BD
fingerprint profileId: "0104", inClusters: "0000, 0202, 0003, 0004, 0005, 0008, 0102", outClusters: "000A, 0019", manufacturer: "Feibit Co.Ltd", model: "FB56+CUR17SB2.2", deviceJoinName: "Nue Smart Blind Switch"
fingerprint profileId: "0104", inClusters: "0000, 0202, 0003, 0004, 0005, 0008, 0102", outClusters: "000A, 0019", manufacturer: "Feibit Co.Ltd", model: "FB56+CUR17SB1.9", deviceJoinName: "Nue Smart Blinds"
I understood that a blind can only be completely opened or closed, nothing in between
It’s normal, by defaut on the wall you just have 2 switches, that can be or off, to have a position you need another hardware, generaly it s included in the motor, not the remote.
Some remote use “artificial set level”, using a timer for exemple, but you will have issue with it, covering take more time to open than to close, so using a timer …
The motor is connected with 4 wires, neutral, line, up and down (and earth) nothing to get position. To have a correct set position, the hardware need to be in the motor.
