Unsure if this is an issue with my light or not, so starting here before raising an Issue over at GitHub.
Ref
2.28.1
Have tried restarting deConz and replugging Conbee I
I have one light refusing to turn off when turning a group off.
Light in question:
//192.168.1.6:80/api/0DA1F3999E/lights/60
"capabilities": {
"alerts": [
"none",
"select",
"lselect"
"groups": [
"0",
"5",
"20",
"24116",
"20014",
"4"
"etag": "916f18313fa6cc1a8d3ec54748361b82",
"hascolor": false,
"lastannounced": "2024-09-29T13:59:31Z",
"lastseen": "2024-09-29T14:53Z",
"manufacturername": "IKEA of Sweden",
"modelid": "STOFTMOLN ceiling/wall lamp WW37",
"name": "Dimmable light Tak Sov Oppe 60",
"alert": "none",
"bri": 184,
"reachable": true
"swversion": "20210520",
"type": "Dimmable light",
"uniqueid": "38:5c:fb:ff:fe:84:8f:01-01"
Testing with group 4:
When I click on the bulb icon for Dimmable light Tak Sov Oppe 60 I can control the light just fine.
Clicking on the All light (group 4) Turns the Icon off, but not the light IRL.
After half a minute or so, it is polled and icons light up again.
Group 4:
"action": {
"alert": "none",
"bri": 127,
"colormode": "hs",
"ct": 0,
"effect": "none",
"hue": 0,
"on": false,
"sat": 127,
"scene": null,
"xy": [
0,
0
"devicemembership": [],
"etag": "4e43827ff00b284f75f185a02f9fadd5",
"hidden": false,
"id": "4",
"lights": [
"48",
"1",
"61",
"42",
"43",
"33",
"52",
"8",
"60",
"46",
"45",
"59",
"47",
"49",
"53",
"56",
"2",
"55",
"3",
"44",
"40",
"9",
"17",
"15",
"26",
"25",
"13",
"14",
"29",
"54",
"24",
"23",
"18",
"30",
"19",
"11",
"16"
"lightsequence": [],
"multideviceids": [],
"name": "All lights",
"scenes": [],
"all_on": false,
"any_on": true
"type": "LightGroup"
Log:
16:33:05:713 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
16:33:06:137 poll node 00:17:88:01:08:3a:43:5e-0b
16:33:06:137 Poll light node Sov Tak 2
16:33:06:189 read attributes of 0x00178801083A435E cluster: 0x0006: [
16:33:06:189 0x0000
16:33:06:189 ]
16:33:06:190 add task 1979 type 19 to 0x00178801083A435E cluster 0x0006 req.id 134
16:33:06:190 Poll APS request 134 to 0x00178801083A435E cluster: 0x0006
16:33:06:331 Bind response success for 0x0cae5ffffe5f097f ep: 0x01 cluster: 0x0000
16:33:06:331 Poll APS confirm 134 status: 0x00
16:33:06:332 Erase task req-id: 134, type: 19 zcl seqno: 58 send time 0, profileId: 0x0104, clusterId: 0x0006
16:33:06:411 0x00178801083A435E: update ZCL value 0x0B/0x0006/0x0000 after 0 s
16:33:06:412 Websocket 192.168.1.5:57474 send message: {"attr":{"colorcapabilities":16,"ctmax":454,"ctmin":153,"id":"44","lastannounced":"2024-09-21T19:00:44Z","lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LTA001","name":"Sov Tak 2","swversion":"1.53.3_r27175","type":"Color temperature light","uniqueid":"00:17:88:01:08:3a:43:5e-0b"},"e":"changed","id":"44","r":"lights","t":"event","uniqueid":"00:17:88:01:08:3a:43:5e-0b"} (ret = -1524976)
16:33:06:413 Websocket 192.168.1.6:55972 send message: {"attr":{"colorcapabilities":16,"ctmax":454,"ctmin":153,"id":"44","lastannounced":"2024-09-21T19:00:44Z","lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LTA001","name":"Sov Tak 2","swversion":"1.53.3_r27175","type":"Color temperature light","uniqueid":"00:17:88:01:08:3a:43:5e-0b"},"e":"changed","id":"44","r":"lights","t":"event","uniqueid":"00:17:88:01:08:3a:43:5e-0b"} (ret = -1524976)
16:33:07:284 binding/unbinding timeout srcAddr: 0x0CAE5FFFFE5F097F, retry
16:33:07:290 poll node 00:17:88:01:09:d2:a8:29-0b
16:33:07:291 Poll light node On/Off plug-in unit 9 Bad
16:33:07:342 read attributes of 0x0017880109D2A829 cluster: 0x0006: [
16:33:07:343 0x0000
16:33:07:343 ]
16:33:07:343 add task 1985 type 19 to 0x0017880109D2A829 cluster 0x0006 req.id 143
16:33:07:343 Poll APS request 143 to 0x0017880109D2A829 cluster: 0x0006
16:33:07:498 Poll APS confirm 143 status: 0x00
16:33:07:499 Erase task req-id: 143, type: 19 zcl seqno: 59 send time 0, profileId: 0x0104, clusterId: 0x0006
16:33:07:579 0x0017880109D2A829: update ZCL value 0x0B/0x0006/0x0000 after 0 s
16:33:07:579 Websocket 192.168.1.5:57474 send message: {"attr":{"id":"9","lastannounced":"2024-02-18T18:33:52Z","lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LOM001","name":"On/Off plug-in unit 9 Bad","swversion":"1.55.10_r29112","type":"On/Off plug-in unit","uniqueid":"00:17:88:01:09:d2:a8:29-0b"},"e":"changed","id":"9","r":"lights","t":"event","uniqueid":"00:17:88:01:09:d2:a8:29-0b"} (ret = -1524976)
16:33:07:580 Websocket 192.168.1.6:55972 send message: {"attr":{"id":"9","lastannounced":"2024-02-18T18:33:52Z","lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LOM001","name":"On/Off plug-in unit 9 Bad","swversion":"1.55.10_r29112","type":"On/Off plug-in unit","uniqueid":"00:17:88:01:09:d2:a8:29-0b"},"e":"changed","id":"9","r":"lights","t":"event","uniqueid":"00:17:88:01:09:d2:a8:29-0b"} (ret = -1524976)
16:33:08:287 poll node 38:5c:fb:ff:fe:84:8f:01-01
16:33:08:288 Poll light node Dimmable light Tak Sov Oppe 60
16:33:08:330 Bind response success for 0x0cae5ffffe5f097f ep: 0x01 cluster: 0x0006
16:33:08:331 skip configure report for cluster: 0x0006 attr: 0x0000 of node 0x0CAE5FFFFE5F097F (seems to be active)
16:33:08:353 Poll APS request to 0x385CFBFFFE848F01 cluster: 0x0006 dropped, values are fresh enough
16:33:08:641 Poll APS request to 0x385CFBFFFE848F01 cluster: 0x0008 dropped, values are fresh enough
16:33:09:180 node 0x0CAE5FFFFE5F097F leave wait state
16:33:09:307 poll node 90:fd:9f:ff:fe:90:e2:7e-01
16:33:09:308 Poll light node Kjøkken tak
16:33:09:360 Poll APS request to 0x90FD9FFFFE90E27E cluster: 0x0006 dropped, values are fresh enough
16:33:09:980 APS-DATA.request id: 158, addrmode: 0x03, addr: 0x7CC6B6FFFE14235C, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 0 len: 2 tx.options 0x00
16:33:09:980 asdu (length: 2): AB00
16:33:10:041 APS-DATA.confirm id: 158, status: 0x00 SUCCESS
16:33:10:170 APS-DATA.indication srcAddr: 0x997E, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 255, rssi: -52
16:33:10:171 asdu: ab00130003852c02ffff2e2100852c02ffff2e210000002402005c852c02ffff2e210094c72e0601881700141b25020f76852c02ffff2e210033b807feff9ffd90311d25020f62
16:33:10:172 APS-DATA.indication request id: 158 -> finished
16:33:10:173 APS-DATA.request id: 158 erase from queue
16:33:10:407 poll node 00:17:88:01:08:3a:43:5e-0b
16:33:10:407 Poll light node Sov Tak 2
16:33:10:459 read attributes of 0x00178801083A435E cluster: 0x0006: [
16:33:10:460 0x0000
16:33:10:460 ]
16:33:10:460 add task 1998 type 19 to 0x00178801083A435E cluster 0x0006 req.id 161
16:33:10:461 Poll APS request 161 to 0x00178801083A435E cluster: 0x0006
16:33:10:512 APS-DATA.request id: 161, addrmode: 0x03, addr: 0x00178801083A435E, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0x0B queue: 0 len: 5 tx.options 0x00
16:33:10:513 asdu (length: 5): 103D000000
16:33:10:585 Poll APS confirm 161 status: 0x00
16:33:10:586 Erase task req-id: 161, type: 19 zcl seqno: 61 send time 0, profileId: 0x0104, clusterId: 0x0006
16:33:10:587 APS-DATA.confirm id: 161, status: 0x00 SUCCESS
16:33:10:587 APS-DATA.confirm request id: 161 -> erase from queue
16:33:10:620 aps request id: 161 finished, erase from queue
16:33:10:633 APS-DATA.indication srcAddr: 0xF91F, srcEp: 0x0B dstAddrMode: 2, profile: 0x0104, cluster: 0x0006, lqi: 255, rssi: -42
16:33:10:634 asdu: 183d010000001000
16:33:10:634 0x00178801083A435E: update ZCL value 0x0B/0x0006/0x0000 after 0 s
16:33:10:712 DEV Poll Busy /devices/0x50325FFFFE47A1F8 timeout seq: 55, cluster: 0x0001
16:33:10:716 DEV Poll Idle enter /devices/0x50325FFFFE47A1F8
16:33:11:636 poll node 68:0a:e2:ff:fe:6e:83:5f-01
16:33:11:637 Poll light node Bokhylle 5
16:33:11:689 Poll APS request to 0x680AE2FFFE6E835F cluster: 0x0006 dropped, values are fresh enough
16:33:12:787 poll node 00:17:88:01:09:d2:a8:29-0b
16:33:12:787 Poll light node On/Off plug-in unit 9 Bad
Turning group off here ...
16:33:12:812 add task 2010 type 14 to group 0x0004 cluster 0x0006 req.id 174
16:33:12:812 APS-DATA.request id: 174, addrmode: 0x01, addr: 0x0004, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0xFF queue: 0 len: 3 tx.options 0x00
16:33:12:813 asdu (length: 3): 113E00
16:33:12:816 Websocket 192.168.1.5:57474 send message: {"e":"changed","id":"60","r":"lights","state":{"alert":"none","bri":184,"on":false,"reachable":true},"t":"event","uniqueid":"38:5c:fb:ff:fe:84:8f:01-01"} (ret = -1439544832)
16:33:12:817 Websocket 192.168.1.6:55972 send message: {"e":"changed","id":"60","r":"lights","state":{"alert":"none","bri":184,"on":false,"reachable":true},"t":"event","uniqueid":"38:5c:fb:ff:fe:84:8f:01-01"} (ret = -1439544832)
16:33:12:820 Websocket 192.168.1.5:57474 send message: {"e":"changed","id":"65520","r":"groups","state":{"all_on":false,"any_on":false},"t":"event"} (ret = -1522336)
16:33:12:821 Websocket 192.168.1.6:55972 send message: {"e":"changed","id":"65520","r":"groups","state":{"all_on":false,"any_on":false},"t":"event"} (ret = -1522336)
16:33:12:822 Websocket 192.168.1.5:57474 send message: {"e":"changed","id":"5","r":"groups","state":{"all_on":false,"any_on":false},"t":"event"} (ret = -1522336)
16:33:12:823 Websocket 192.168.1.6:55972 send message: {"e":"changed","id":"5","r":"groups","state":{"all_on":false,"any_on":false},"t":"event"} (ret = -1522336)
16:33:12:824 Websocket 192.168.1.5:57474 send message: {"e":"changed","id":"20","r":"groups","state":{"all_on":false,"any_on":false},"t":"event"} (ret = -1522336)
16:33:12:825 Websocket 192.168.1.6:55972 send message: {"e":"changed","id":"20","r":"groups","state":{"all_on":false,"any_on":false},"t":"event"} (ret = -1522336)
16:33:12:826 Websocket 192.168.1.5:57474 send message: {"e":"changed","id":"24116","r":"groups","state":{"all_on":false,"any_on":false},"t":"event"} (ret = -1522336)
16:33:12:826 Websocket 192.168.1.6:55972 send message: {"e":"changed","id":"24116","r":"groups","state":{"all_on":false,"any_on":false},"t":"event"} (ret = -1522336)
16:33:12:835 Websocket 192.168.1.5:57474 send message: {"e":"changed","id":"20014","r":"groups","state":{"all_on":false,"any_on":false},"t":"event"} (ret = -1522336)
16:33:12:836 Websocket 192.168.1.6:55972 send message: {"e":"changed","id":"20014","r":"groups","state":{"all_on":false,"any_on":false},"t":"event"} (ret = -1522336)
16:33:12:837 Websocket 192.168.1.5:57474 send message: {"e":"changed","id":"4","r":"groups","state":{"all_on":false,"any_on":false},"t":"event"} (ret = -1522336)
16:33:12:838 Websocket 192.168.1.6:55972 send message: {"e":"changed","id":"4","r":"groups","state":{"all_on":false,"any_on":false},"t":"event"} (ret = -1522336)
16:33:12:857 read attributes of 0x0017880109D2A829 cluster: 0x0006: [
16:33:12:858 0x0000
16:33:12:858 ]
16:33:12:859 add task 2011 type 19 to 0x0017880109D2A829 cluster 0x0006 req.id 175
16:33:12:859 Poll APS request 175 to 0x0017880109D2A829 cluster: 0x0006
16:33:12:912 APS-DATA.request id: 175, addrmode: 0x03, addr: 0x0017880109D2A829, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0x0B queue: 1 len: 5 tx.options 0x00
16:33:12:913 asdu (length: 5): 103F000000
16:33:12:000 Poll APS confirm 175 status: 0x00
16:33:12:001 Erase task req-id: 175, type: 19 zcl seqno: 63 send time 0, profileId: 0x0104, clusterId: 0x0006
16:33:12:002 APS-DATA.confirm id: 175, status: 0x00 SUCCESS
16:33:12:002 APS-DATA.confirm request id: 175 -> erase from queue
16:33:13:021 aps request id: 175 finished, erase from queue
16:33:13:048 APS-DATA.indication srcAddr: 0xFF8D, srcEp: 0x0B dstAddrMode: 2, profile: 0x0104, cluster: 0x0006, lqi: 255, rssi: -38
16:33:13:049 asdu: 183f010000001000
16:33:13:050 0x0017880109D2A829: update ZCL value 0x0B/0x0006/0x0000 after 0 s
16:33:13:096 0x00178801084A9859 force poll
16:33:13:097 0x00178801062EC794 force poll
16:33:13:097 0x00178801089DAD6D force poll
16:33:13:098 0x00178801083424C3 force poll
16:33:13:098 0x0017880103CDF08F force poll
16:33:13:098 0x000B57FFFE233734 force poll
16:33:13:098 0x385CFBFFFE848F01 force poll
16:33:13:098 0x00178801084419C6 force poll
16:33:13:099 0x0017880108394705 force poll
16:33:13:099 0x001788010844149C force poll
16:33:13:099 0x00178801084AAFF8 force poll
16:33:13:099 0xD0CF5EFFFE3F01CE force poll
16:33:13:100 0x0017880109D2F56E force poll
16:33:13:100 0x0017880103F7A444 force poll
16:33:13:100 0x000B57FFFE13DE3D force poll
16:33:13:101 0x00178801083A435E force poll
16:33:13:101 0x0017880109D2A829 force poll
16:33:13:101 0x90FD9FFFFE517712 force poll
16:33:13:101 0x90FD9FFFFE07B833 force poll
16:33:13:101 0x086BD7FFFE056EF1 force poll
16:33:13:102 0x000D6FFFFEFC04D7 force poll
16:33:13:102 0x000B57FFFEEFBB4A force poll
16:33:13:102 0x90FD9FFFFE083DB1 force poll
16:33:13:102 0x086BD7FFFE382EFF force poll
16:33:13:103 0x086BD7FFFE03DDE7 force poll
16:33:13:103 0x086BD7FFFE370674 force poll
16:33:13:103 0x086BD7FFFE0214A6 force poll
16:33:13:103 0x000B57FFFEBC1039 force poll
16:33:13:104 0x000D6FFFFEFC0BC9 force poll
16:33:13:104 0x000B57FFFEEFC30E force poll
16:33:13:104 0xCCCCCCFFFE89CD83 force poll
16:33:13:104 0x000B57FFFED2DCE4 force poll
16:33:13:105 Erase task req-id: 174, type: 14 zcl seqno: 62 send time 0, profileId: 0x0104, clusterId: 0x0006
16:33:13:105 APS-DATA.confirm id: 174, status: 0x00 SUCCESS
16:33:13:116 aps request id: 174 finished, erase from queue
16:33:13:117 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x01 dstAddrMode: 1, profile: 0x0104, cluster: 0x0006, lqi: 255, rssi: -38
16:33:13:118 asdu: 113e00
16:33:13:787 poll node 00:17:88:01:08:4a:98:59-0b
16:33:13:788 Poll light node Bad Tak 48
16:33:13:820 APS-DATA.request id: 182, addrmode: 0x03, addr: 0x7CC6B6FFFE14235C, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 0 len: 2 tx.options 0x00
16:33:13:820 asdu (length: 2): AC03
16:33:13:839 read attributes of 0x00178801084A9859 cluster: 0x0006: [
16:33:13:840 0x0000
16:33:13:840 ]
16:33:13:840 add task 2016 type 19 to 0x00178801084A9859 cluster 0x0006 req.id 183
16:33:13:840 Poll APS request 183 to 0x00178801084A9859 cluster: 0x0006
16:33:13:880 APS-DATA.confirm id: 182, status: 0x00 SUCCESS
16:33:13:912 APS-DATA.request id: 183, addrmode: 0x03, addr: 0x00178801084A9859, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0x0B queue: 1 len: 5 tx.options 0x00
16:33:13:913 asdu (length: 5): 1040000000
16:33:13:960 Poll APS confirm 183 status: 0x00
16:33:13:961 Erase task req-id: 183, type: 19 zcl seqno: 64 send time 0, profileId: 0x0104, clusterId: 0x0006
16:33:13:961 APS-DATA.confirm id: 183, status: 0x00 SUCCESS
16:33:13:961 APS-DATA.confirm request id: 183 -> erase from queue
16:33:13:981 aps request id: 183 finished, erase from queue
16:33:14:008 APS-DATA.indication srcAddr: 0x997E, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 255, rssi: -52
16:33:14:009 asdu: ac00130303852c02ffff2e21007f095ffeff5fae0c952225020fff852c02ffff2e21006dad9d0801881700892925020f68852c02ffff2e2100c324340801881700e52e25020f60
16:33:14:009 APS-DATA.indication request id: 182 -> finished
16:33:14:009 APS-DATA.request id: 182 erase from queue
16:33:14:056 APS-DATA.indication srcAddr: 0x1788, srcEp: 0x0B dstAddrMode: 2, profile: 0x0104, cluster: 0x0006, lqi: 255, rssi: -52
16:33:14:057 asdu: 1840010000001000
16:33:14:057 0x00178801084A9859: update ZCL value 0x0B/0x0006/0x0000 after 0 s
16:33:14:058 Websocket 192.168.1.5:57474 send message: {"attr":{"colorcapabilities":16,"ctmax":454,"ctmin":153,"id":"48","lastannounced":null,"lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LTG002","name":"Bad Tak 48","swversion":"1.55.7_r28193","type":"Color temperature light","uniqueid":"00:17:88:01:08:4a:98:59-0b"},"e":"changed","id":"48","r":"lights","t":"event","uniqueid":"00:17:88:01:08:4a:98:59-0b"} (ret = -1524976)
16:33:14:059 Websocket 192.168.1.6:55972 send message: {"attr":{"colorcapabilities":16,"ctmax":454,"ctmin":153,"id":"48","lastannounced":null,"lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LTG002","name":"Bad Tak 48","swversion":"1.55.7_r28193","type":"Color temperature light","uniqueid":"00:17:88:01:08:4a:98:59-0b"},"e":"changed","id":"48","r":"lights","t":"event","uniqueid":"00:17:88:01:08:4a:98:59-0b"} (ret = -1524976)
16:33:15:024 poll node 00:17:88:01:06:2e:c7:94-0b
16:33:15:025 Poll light node Uplight 1 Philips
16:33:15:072 read attributes of 0x00178801062EC794 cluster: 0x0006: [
16:33:15:072 0x0000
16:33:15:073 ]
16:33:15:073 add task 2022 type 19 to 0x00178801062EC794 cluster 0x0006 req.id 191
16:33:15:073 Poll APS request 191 to 0x00178801062EC794 cluster: 0x0006
16:33:15:112 APS-DATA.request id: 191, addrmode: 0x03, addr: 0x00178801062EC794, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0x0B queue: 0 len: 5 tx.options 0x00
16:33:15:113 asdu (length: 5): 1041000000
16:33:15:160 Poll APS confirm 191 status: 0x00
16:33:15:160 Erase task req-id: 191, type: 19 zcl seqno: 65 send time 0, profileId: 0x0104, clusterId: 0x0006
16:33:15:161 APS-DATA.confirm id: 191, status: 0x00 SUCCESS
16:33:15:161 APS-DATA.confirm request id: 191 -> erase from queue
16:33:15:180 aps request id: 191 finished, erase from queue
16:33:15:208 APS-DATA.indication srcAddr: 0x1B14, srcEp: 0x0B dstAddrMode: 2, profile: 0x0104, cluster: 0x0006, lqi: 255, rssi: -54
16:33:15:208 asdu: 1841010000001000
16:33:15:209 0x00178801062EC794: update ZCL value 0x0B/0x0006/0x0000 after 0 s
16:33:15:209 Websocket 192.168.1.5:57474 send message: {"attr":{"colorcapabilities":16,"ctmax":454,"ctmin":153,"id":"1","lastannounced":null,"lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LTA001","name":"Uplight 1 Philips","swversion":"1.53.3_r27175","type":"Color temperature light","uniqueid":"00:17:88:01:06:2e:c7:94-0b"},"e":"changed","id":"1","r":"lights","t":"event","uniqueid":"00:17:88:01:06:2e:c7:94-0b"} (ret = -1524976)
16:33:15:210 Websocket 192.168.1.6:55972 send message: {"attr":{"colorcapabilities":16,"ctmax":454,"ctmin":153,"id":"1","lastannounced":null,"lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LTA001","name":"Uplight 1 Philips","swversion":"1.53.3_r27175","type":"Color temperature light","uniqueid":"00:17:88:01:06:2e:c7:94-0b"},"e":"changed","id":"1","r":"lights","t":"event","uniqueid":"00:17:88:01:06:2e:c7:94-0b"} (ret = -1524976)
16:33:15:713 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
16:33:16:212 poll node 00:17:88:01:08:9d:ad:6d-0b
16:33:16:213 Poll light node On/Off plug-in unit 42 Sov Lampe
16:33:16:262 read attributes of 0x00178801089DAD6D cluster: 0x0006: [
16:33:16:263 0x0000
16:33:16:263 ]
16:33:16:264 add task 2028 type 19 to 0x00178801089DAD6D cluster 0x0006 req.id 198
16:33:16:264 Poll APS request 198 to 0x00178801089DAD6D cluster: 0x0006
16:33:16:375 Poll APS confirm 198 status: 0x00
16:33:16:376 Erase task req-id: 198, type: 19 zcl seqno: 66 send time 0, profileId: 0x0104, clusterId: 0x0006
16:33:16:408 0x00178801089DAD6D: update ZCL value 0x0B/0x0006/0x0000 after 0 s
16:33:16:408 Websocket 192.168.1.5:57474 send message: {"attr":{"id":"42","lastannounced":"2024-09-14T03:18:21Z","lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LOM001","name":"On/Off plug-in unit 42 Sov Lampe","swversion":"1.55.10_r29112","type":"On/Off plug-in unit","uniqueid":"00:17:88:01:08:9d:ad:6d-0b"},"e":"changed","id":"42","r":"lights","t":"event","uniqueid":"00:17:88:01:08:9d:ad:6d-0b"} (ret = -1524976)
16:33:16:409 Websocket 192.168.1.6:55972 send message: {"attr":{"id":"42","lastannounced":"2024-09-14T03:18:21Z","lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LOM001","name":"On/Off plug-in unit 42 Sov Lampe","swversion":"1.55.10_r29112","type":"On/Off plug-in unit","uniqueid":"00:17:88:01:08:9d:ad:6d-0b"},"e":"changed","id":"42","r":"lights","t":"event","uniqueid":"00:17:88:01:08:9d:ad:6d-0b"} (ret = -1524976)
16:33:17:212 poll node 00:17:88:01:08:34:24:c3-0b
16:33:17:213 Poll light node Sov Tak 1
16:33:17:262 read attributes of 0x00178801083424C3 cluster: 0x0006: [
16:33:17:263 0x0000
16:33:17:263 ]
16:33:17:263 add task 2033 type 19 to 0x00178801083424C3 cluster 0x0006 req.id 204
16:33:17:264 Poll APS request 204 to 0x00178801083424C3 cluster: 0x0006
16:33:17:367 Poll APS confirm 204 status: 0x00
16:33:17:367 Erase task req-id: 204, type: 19 zcl seqno: 67 send time 0, profileId: 0x0104, clusterId: 0x0006
16:33:17:399 0x00178801083424C3: update ZCL value 0x0B/0x0006/0x0000 after 0 s
16:33:17:400 Websocket 192.168.1.5:57474 send message: {"attr":{"colorcapabilities":16,"ctmax":454,"ctmin":153,"id":"43","lastannounced":"2024-09-21T19:00:45Z","lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LTA001","name":"Sov Tak 1","swversion":"1.53.3_r27175","type":"Color temperature light","uniqueid":"00:17:88:01:08:34:24:c3-0b"},"e":"changed","id":"43","r":"lights","t":"event","uniqueid":"00:17:88:01:08:34:24:c3-0b"} (ret = -1524976)
16:33:17:401 Websocket 192.168.1.6:55972 send message: {"attr":{"colorcapabilities":16,"ctmax":454,"ctmin":153,"id":"43","lastannounced":"2024-09-21T19:00:45Z","lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LTA001","name":"Sov Tak 1","swversion":"1.53.3_r27175","type":"Color temperature light","uniqueid":"00:17:88:01:08:34:24:c3-0b"},"e":"changed","id":"43","r":"lights","t":"event","uniqueid":"00:17:88:01:08:34:24:c3-0b"} (ret = -1524976)
16:33:18:377 poll node 00:17:88:01:03:cd:f0:8f-0b
16:33:18:378 Poll light node TV baklys
16:33:18:425 read attributes of 0x0017880103CDF08F cluster: 0x0006: [
16:33:18:426 0x0000
16:33:18:426 ]
16:33:18:426 add task 2038 type 19 to 0x0017880103CDF08F cluster 0x0006 req.id 212
16:33:18:426 Poll APS request 212 to 0x0017880103CDF08F cluster: 0x0006
16:33:18:567 Poll APS confirm 212 status: 0x00
16:33:18:567 Erase task req-id: 212, type: 19 zcl seqno: 68 send time 0, profileId: 0x0104, clusterId: 0x0006
16:33:18:599 0x0017880103CDF08F: update ZCL value 0x0B/0x0006/0x0000 after 0 s
16:33:18:600 Websocket 192.168.1.5:57474 send message: {"attr":{"colorcapabilities":31,"ctmax":500,"ctmin":153,"id":"33","lastannounced":null,"lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LST002","name":"TV baklys","swversion":"1.24.0_r20239","type":"Extended color light","uniqueid":"00:17:88:01:03:cd:f0:8f-0b"},"e":"changed","id":"33","r":"lights","t":"event","uniqueid":"00:17:88:01:03:cd:f0:8f-0b"} (ret = -1524976)
16:33:18:600 Websocket 192.168.1.6:55972 send message: {"attr":{"colorcapabilities":31,"ctmax":500,"ctmin":153,"id":"33","lastannounced":null,"lastseen":"2024-09-29T14:33Z","manufacturername":"Philips","modelid":"LST002","name":"TV baklys","swversion":"1.24.0_r20239","type":"Extended color light","uniqueid":"00:17:88:01:03:cd:f0:8f-0b"},"e":"changed","id":"33","r":"lights","t":"event","uniqueid":"00:17:88:01:03:cd:f0:8f-0b"} (ret = -1524976)
16:33:19:213 ZDP get active endpoints for 0x1B8D
