New conbee2 usb stick reconnect every time
Hi!
I try to setup my new conbee2 stick. But it have a strange behavior. When I connect the stick to one of my systems, the stick connect and de-connect every 10 seconds!
I see this on:
  • Banana PI M5 (Ubuntu 20.04.5 LTS (GNU/Linux 4.9.312-BPI-M5 aarch64))
  • Thinkpad T450s ArchLinux (Linux augustus 5.19.10-arch1-1 #1 SMP PREEMPT_DYNAMIC Tue, 20 Sep 2022 15:17:59 +0000 x86_64 GNU/Linux)
  • Thinpad T14 Windows10
The lsusb show the stick while connection established.
I readed some solutions to update the firmware. But I don’t think, this will work in 10 secounds.
I’ve no idea whats going wrong!
Is the stick booting every time? Is there a hardwareproblem?
Many thanks!
Regards from Cologne
Thomas
Kernellog from ArchLinux:
Okt 10 17:49:02 augustus kernel: usb 2-1: new full-speed USB device number 30 using xhci_hcd
Okt 10 17:49:02 augustus kernel: usb 2-1: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Okt 10 17:49:02 augustus kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Okt 10 17:49:02 augustus kernel: usb 2-1: Product: ConBee II
Okt 10 17:49:02 augustus kernel: usb 2-1: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Okt 10 17:49:02 augustus kernel: usb 2-1: SerialNumber: DE2481484
Okt 10 17:49:02 augustus kernel: cdc_acm 2-1:1.0: ttyACM0: USB ACM device
Okt 10 17:49:05 augustus kernel: usb 2-1: USB disconnect, device number 30
Okt 10 17:49:14 augustus kernel: usb 2-1: new full-speed USB device number 31 using xhci_hcd
Okt 10 17:49:14 augustus kernel: usb 2-1: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Okt 10 17:49:14 augustus kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Okt 10 17:49:14 augustus kernel: usb 2-1: Product: ConBee II
Okt 10 17:49:14 augustus kernel: usb 2-1: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Okt 10 17:49:14 augustus kernel: usb 2-1: SerialNumber: DE2481484
Okt 10 17:49:14 augustus kernel: cdc_acm 2-1:1.0: ttyACM0: USB ACM device
Okt 10 17:49:17 augustus kernel: usb 2-1: USB disconnect, device number 31
Okt 10 17:49:26 augustus kernel: usb 2-1: new full-speed USB device number 32 using xhci_hcd
Okt 10 17:49:26 augustus kernel: usb 2-1: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Okt 10 17:49:26 augustus kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Okt 10 17:49:26 augustus kernel: usb 2-1: Product: ConBee II
Okt 10 17:49:26 augustus kernel: usb 2-1: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Okt 10 17:49:26 augustus kernel: usb 2-1: SerialNumber: DE2481484
Okt 10 17:49:26 augustus kernel: cdc_acm 2-1:1.0: ttyACM0: USB ACM device
Have you already done a search on this forum ? There are several posts for this kind of issue, ie https://forum.phoscon.de/t/conbee-ii-periodically-disconnecting/510
Thank you for your reply!
Yes, I have found these entries. But for me, it looks a little different.
There it is recommended to update the firmware. But my stick is not connected for so long! So it is not accessible to reflash it.
I also tried with and without extension cable. No change.
The Banana Pi also has only USB3 ports. There is no change in behavior to my Thinkpad with USB2.
Regards
Thomas
Just try to update the firmware. Your best off using windows for this. In that 10 seconds, it should take it.
Success!! At the end, i had 5 secounds. I had not thought! But it works!!
Many thanks! Now the stick is still available.
Regards
Thomas
