Homematic 141378A0
Hi!
Is the Homematic 141378A0 compatible with deconz/RaspBee II?
https://www.eq-3.de/produkte/homematic/detail/homematic-funk-schaltaktor-1-fach-hutschienenmontage.html
What does it take to make it happen?
Thanks for your feedback!
PS:
Ihr könnt auch gerne in Deutsch antworten. :wink:
Not sure. Do you own one?
Have you searched the github?
No. I wanted to know before I buy it.:wink: And yes, I looked around in several resources but so far could not find any hints for support of this DIN rail (“Hutschiene”) Zigbee relay.
There is a 2- channel and a 1- channel relay from Ubisys, the S2-R (1168) or S1-R (1151), that could serve as alternative, but they cost over 100€.
Are you aware of any other DIN rail (“Hutschiene”) Zigbee relays that are supported by deconz?
Nochmals herzlichen Dank für die Rückmeldung, thanks so much for your feedback! :slight_smile:
PS @Mimiix and everybody:
Oh my bad! If I red the initial finding of this relay thoroughly enough, I would have immediately understood that a CCU is needed and that this does not work with zigbee. My sincerest apologies!
Please close this. Thank you!
I opened a new topic with a more general question about DIN rail relays:
I only know one from Develco Smart Relay 16A DIN with built-in power metering functionality
They are cheaper, but therefore also harder to get around here. Only know cozfiy shop from Finnland offering them so far.
Hi!
More than a year later I still have not found a ZigBee device for the DIN rail that is compatible with deconz. :frowning:
Has anybody of you found something that works and is available (in Germany)?
These are quiet easy to implement with a DDF tho. Perhaps work out of the box as it’s a simple turn on or off.
What’s a DDF?
https://dresden-elektronik.github.io/deconz-dev-doc/modules/ddf/
Sorry, but I have no idea how this would solve my problems, i.e. finding and using a DIN ray ZigBee/deconz-compatible relais to switch a 230 V device. What have I overlooked?
That you can ignore compatible. If it isn’t supported, you can easily add support.
