DIN rail ("Hutschiene") Zigbee relay?
Hi!
Are you aware of any DIN rail (“Hutschiene”) Zigbee relays that are supported by deconz?
Thanks so much for your feedback (English or German)! :slight_smile:
Moved to #advice
You have the brand “Legrand” in Germany ?
I assume that that I could order items from Legrand, but I could not find a zigbee relay for the DIN rail. What have I missed? Thanks for your help! :slight_smile:
They have a gamme called drivia, only rail din devices, there is a relay, a teleruptor, power measurement, ect …
You have the french version here Découvrez Drivia with Netatmo, le premier tableau électrique connecté de Legrand - Espace Pro | Legrand
https://www.ubisys.de/produkte/produkte-licht-verbraucher/produkte-licht-verbraucher-s1-r/
I have a few Ubisys devices running and they work usually without problems. OTA update is possible too. The only drawback is the price tag :wink:
Hi!
More than a year later I still have not found a ZigBee device for the DIN rail that is compatible with deconz. :frowning:
I was not able to find the linked device from Legrand to buy in Germany.
Has anybody of you found something that works and is available?
Add DDF for Tuya / TONGOU TO-Q-SV1-ZT by BabaIsYou · Pull Request #6842 · dresden-elektronik/deconz-rest-plugin · GitHub ?
There is also a version with metering not implemented for now, but may be not so difficult with DDF.
For exemple
Or on amazon
https://www.amazon.de/Smart-Contactor-Legrand-412171-Estándar/dp/B09H7RFDDK/ref=sr_1_5?__mk_de_DE=ÅMÅŽÕÑ&crid=225T5AJSL60OA&keywords=legrand+netatmo+412171&qid=1683125248&sprefix=legrand+netatmo+4121+71%2Caps%2C417&sr=8-5
There is too a DIN realy on Casa.ia and perhaps 3/4 on tuya clones.
Just type the word you are searching on google.
Erm, thank you, but I do not want or need Netatmo. Maybe I misunderstood something about it, though. The simpler it is, the better, so a plain ZigBee/deconz-compatible DIN rail device without any ado would be great. :wink:
Have you seen the link I gave earlier to already supported Tongou device ?
May be it’s not what you are searching for ? Have a look at Products - TONGOU Electrical
Thank you both for the links, I will (again) look into and sorry in case I misunderstood you.
@Mimiix and other experts:
Are these DIN rail interrupters meant as replacement of the classic interrupters (called “FI-Schalter” or “Sicherung” in German, I believe), or should they be used in addition? If the latter, should they be placed before or after the classic interrupter?
I have no idea. Best to ask a electrician of your area.
However, If you want to use them as safety devices, i strongly to purchase a good brand.
Well, I already have all the safety interrupters installed but am not sure if I want to remotely switch a (garden) device (which even has its own “FI-Schalter”), where the “intelligent” ZigBee interrupter should be looped in. But your advice to ask an electrician is good, of course; even better to have it installed by one. :slight_smile:
Im using Ubisys DINrail with Deconz. These work out of the box.
They are also sold as BEGA rebrands.
They are not intended to replace the FI - place them behind as a power switch.
@jensflorian
Thank you so much, this looks very promising! :smiley:
The S2-R can provide 2 devices, with 500VA max. each, whereas the S1-R is for one device with 3680VA max. (16A @230V).
I plan to control my garden pump (1050W), so it seems I need the S1-R.
The S2 (500 W) was too weak for my garden pump, and the S1 is either not available or very expensive (>175 €).
Now I’m back to zero and still searching…
I could not find something from Legrand that I could order in Germany, and I’m not willing to buy via A’Express.
Is the “LUPUSEC - DIN2”* compatible with deCONZ?
*Amazon.de
Any other advice?
But my previous link was for germany ?
My bad, of course!
