FLS-M Philips Hue scenes
I have an LED lightstrip connected to a FLS-M controller which I have divided up into 5 separate segments. The Light appears in the hue app and I can change the colour of segments.
However, if you select a scene for the room the FLS-M briefly turns the LEDs off, then comes back on again but they are the same colour. I have tried with simple single colour scenes such as ‘relax’ but it never changes the lightstrip.
It seems that you can only control the FLS-M lightstrip as an individual light.
Any ideas?
I am using the latest firmware.
I asked the firmware developer about it, there is an ongoing investigation due a bug in the SDK:
“This is related to a bug in the espressif zigbee-sdk. We have a ongoing git issue about this (ColorControl Cluster Group Commands are only forwarded to one Endpoint (TZ-1450) · Issue #528 · espressif/esp-zigbee-sdk · GitHub) and we will implement the fix once it is available.”
