HI,
I recently purchased a Raspbee2 and am trying to flash it to latest firmware, however seems to be failing.
Running on Pi 4b 8gb with raspbian
Deconz version is: 2.12.06-raspbian-buster-stable
Firmware is: deCONZ_RaspBeeII_0x26720700.bin.GCF
Output from GCFFlasher_internal is as follows:
/dev/ttyS0 | 0x0000 | 0x0000 | | RaspBee
sudo GCFFlasher_internal -t 30 -x 3 -f /tmp/deCONZ_RaspBeeII_0x26720700.bin.GCF
20:34:45:584 using firmware file: /tmp/deCONZ_RaspBeeII_0x26720700.bin.GCF
20:34:45:659 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
20:34:45:659 check symlink /dev/ttyAMA0 (/dev/ttyS0)
20:34:45:659 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
20:34:45:659 check symlink /dev/ttyS0 (/dev/ttyS0)
20:34:45:659 dev /dev/ttyS0 (/dev/ttyS0)
20:34:45:660 query bootloader v1 ID after 0 ms
20:34:47:162 query bootloader v1 ID after 1501 ms
20:34:47:663 query deCONZ firmware version
20:34:49:666 uart reset failed, try RaspBee reset
action: reset device RaspBee
wiringPi 2.52 initialized
20:34:49:870 query bootloader v1 ID after 0 ms
20:34:49:881 RX 1 bytes ASCII ▒ after 12 ms
20:34:49:881 RX ff after 12 ms
20:34:50:882 query bootloader v1 ID after 1013 ms
20:34:52:384 query bootloader v3 ID after 2515 ms
20:34:52:384 TX c081027dffc0
20:34:52:886 retry, elapsed 7 seconds
20:34:52:981 parse commands: /usr/bin/GCFFlasher_internal.bin -t 30 -x 3 -f /tmp/deCONZ_RaspBeeII_0x26720700.bin.GCF
20:34:52:981 using firmware file: /tmp/deCONZ_RaspBeeII_0x26720700.bin.GCF
20:34:53:093 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
20:34:53:093 check symlink /dev/ttyAMA0 (/dev/ttyS0)
20:34:53:093 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
20:34:53:093 check symlink /dev/ttyS0 (/dev/ttyS0)
20:34:53:093 dev /dev/ttyS0 (/dev/ttyS0)
20:34:53:095 query bootloader v1 ID after 0 ms
20:34:54:595 query bootloader v1 ID after 1500 ms
20:34:55:096 query deCONZ firmware version
20:34:57:099 uart reset failed, try RaspBee reset
20:34:57:300 query bootloader v1 ID after 0 ms
20:34:57:311 RX 1 bytes ASCII ▒ after 12 ms
20:34:57:311 RX ff after 12 ms
20:34:58:313 query bootloader v1 ID after 1013 ms
20:34:59:814 query bootloader v3 ID after 2514 ms
20:34:59:814 TX c081027dffc0
20:35:00:316 retry, elapsed 14 seconds
20:35:00:421 parse commands: /usr/bin/GCFFlasher_internal.bin -t 30 -x 3 -f /tmp/deCONZ_RaspBeeII_0x26720700.bin.GCF
20:35:00:421 using firmware file: /tmp/deCONZ_RaspBeeII_0x26720700.bin.GCF
20:35:00:518 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
20:35:00:518 check symlink /dev/ttyAMA0 (/dev/ttyS0)
20:35:00:518 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
20:35:00:519 check symlink /dev/ttyS0 (/dev/ttyS0)
20:35:00:519 dev /dev/ttyS0 (/dev/ttyS0)
20:35:00:520 query bootloader v1 ID after 0 ms
20:35:02:022 query bootloader v1 ID after 1501 ms
20:35:02:522 query deCONZ firmware version
20:35:04:525 uart reset failed, try RaspBee reset
20:35:04:727 query bootloader v1 ID after 0 ms
20:35:06:229 query bootloader v3 ID after 1503 ms
20:35:06:230 TX c081027dffc0
20:35:06:731 retry, elapsed 21 seconds
20:35:06:837 parse commands: /usr/bin/GCFFlasher_internal.bin -t 30 -x 3 -f /tmp/deCONZ_RaspBeeII_0x26720700.bin.GCF
20:35:06:838 using firmware file: /tmp/deCONZ_RaspBeeII_0x26720700.bin.GCF
20:35:06:933 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
20:35:06:933 check symlink /dev/ttyAMA0 (/dev/ttyS0)
20:35:06:933 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
20:35:06:933 check symlink /dev/ttyS0 (/dev/ttyS0)
20:35:06:933 dev /dev/ttyS0 (/dev/ttyS0)
20:35:06:934 query bootloader v1 ID after 0 ms
20:35:08:435 query bootloader v1 ID after 1501 ms
20:35:08:936 query deCONZ firmware version
20:35:10:939 uart reset failed, try RaspBee reset
20:35:11:141 query bootloader v1 ID after 0 ms
20:35:12:642 query bootloader v3 ID after 1502 ms
20:35:12:643 TX c081027dffc0
20:35:13:144 retry, elapsed 27 seconds
20:35:13:245 parse commands: /usr/bin/GCFFlasher_internal.bin -t 30 -x 3 -f /tmp/deCONZ_RaspBeeII_0x26720700.bin.GCF
20:35:13:245 using firmware file: /tmp/deCONZ_RaspBeeII_0x26720700.bin.GCF
20:35:13:341 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
20:35:13:341 check symlink /dev/ttyAMA0 (/dev/ttyS0)
20:35:13:341 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
20:35:13:341 check symlink /dev/ttyS0 (/dev/ttyS0)
20:35:13:342 dev /dev/ttyS0 (/dev/ttyS0)
20:35:13:342 query bootloader v1 ID after 0 ms
20:35:14:844 query bootloader v1 ID after 1501 ms
20:35:15:345 query deCONZ firmware version
20:35:17:347 uart reset failed, try RaspBee reset
20:35:17:548 query bootloader v1 ID after 0 ms
20:35:19:049 query bootloader v3 ID after 1501 ms
20:35:19:049 TX c081027dffc0
retry, failed
Adding some dmesg logs:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1414 SMP Fri Apr 30 13:20:47 BST 2021
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000001ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b2fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] On node 0 totalpages: 2061056
[ 0.000000] DMA zone: 2304 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 1864448 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
[ 0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2058752
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:35:84:B6 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=tty1 root=PARTUUID=fada9955-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000014c00000-0x0000000018c00000] (64MB)
[ 0.000000] Memory: 7799064K/8244224K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183016K reserved, 262144K cma-reserved, 7457792K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 33942 entries in 67 pages
[ 0.000000] ftrace: allocated 67 pages with 3 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
[ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000026] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000086] bcm2835: system timer (irq = 25)
[ 0.000733] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000751] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000769] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000784] Switching to timer-based delay loop, resolution 18ns
[ 0.001032] Console: colour dummy device 80x30
[ 0.001097] printk: console [tty1] enabled
[ 0.001153] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.001185] pid_max: default: 32768 minimum: 301
[ 0.001352] LSM: Security Framework initializing
[ 0.001536] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001562] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003138] Disabling memory control group subsystem
[ 0.003256] CPU: Testing write buffer coherency: ok
[ 0.003707] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004903] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005100] rcu: Hierarchical SRCU implementation.
[ 0.006011] smp: Bringing up secondary CPUs …
[ 0.007198] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008538] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009811] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009968] smp: Brought up 1 node, 4 CPUs
[ 0.009988] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.010003] CPU: All CPU(s) started in HYP mode.
[ 0.010017] CPU: Virtualization extensions available.
[ 0.010909] devtmpfs: initialized
[ 0.024783] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.025002] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.025032] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.031995] pinctrl core: initialized pinctrl subsystem
[ 0.033028] NET: Registered protocol family 16
[ 0.036956] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.037728] audit: initializing netlink subsys (disabled)
[ 0.038001] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.038555] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.039293] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.039310] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.039709] Serial: AMBA PL011 UART driver
[ 0.072463] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.090844] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-30T13:45:52, variant start
[ 0.100857] raspberrypi-firmware soc:firmware: Firmware hash is d7f29d96450abfc77cd6cf011af1faf1e03e5e56
[ 0.145661] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.149762] vgaarb: loaded
[ 0.150211] SCSI subsystem initialized
[ 0.150432] usbcore: registered new interface driver usbfs
[ 0.150492] usbcore: registered new interface driver hub
[ 0.150564] usbcore: registered new device driver usb
[ 0.151251] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.153179] clocksource: Switched to clocksource arch_sys_counter
[ 1.151487] VFS: Disk quotas dquot_6.6.0
[ 1.151588] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.151747] FS-Cache: Loaded
[ 1.151935] CacheFiles: Loaded
[ 1.161984] NET: Registered protocol family 2
[ 1.162808] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.162861] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.163003] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.163070] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.163277] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.163313] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.163575] NET: Registered protocol family 1
[ 1.164306] RPC: Registered named UNIX socket transport module.
[ 1.164322] RPC: Registered udp transport module.
[ 1.164337] RPC: Registered tcp transport module.
[ 1.164351] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.164374] PCI: CLS 0 bytes, default 64
[ 1.167360] Initialise system trusted keyrings
[ 1.167593] workingset: timestamp_bits=14 max_order=21 bucket_order=7
[ 1.176135] zbud: loaded
[ 1.178072] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.178824] NFS: Registering the id_resolver key type
[ 1.178856] Key type id_resolver registered
[ 1.178872] Key type id_legacy registered
[ 1.179007] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.180013] Key type asymmetric registered
[ 1.180029] Asymmetric key parser ‘x509’ registered
[ 1.180221] bounce: pool size: 64 pages
[ 1.180264] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.180474] io scheduler mq-deadline registered
[ 1.180491] io scheduler kyber registered
[ 1.184866] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.184897] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.184977] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.185067] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x01ffffffff → 0x0400000000
[ 1.245287] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.245671] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.245691] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.245712] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.245799] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.246041] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.249513] PCI: bus0: Fast back to back transfers disabled
[ 1.249768] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.249840] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.250099] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.253495] PCI: bus1: Fast back to back transfers disabled
[ 1.253556] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.253580] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.253623] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.253649] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.254049] pcieport 0000:00:00.0: enabling device (0140 → 0142)
[ 1.254274] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
[ 1.259895] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 1.260847] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
[ 1.263373] iproc-rng200 fe104000.rng: hwrng registered
[ 1.263684] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
[ 1.264544] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.276631] brd: module loaded
[ 1.288826] loop: module loaded
[ 1.290453] Loading iSCSI transport class v2.0-870.
[ 1.292883] libphy: Fixed MDIO Bus: probed
[ 1.294606] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.313226] libphy: bcmgenet MII bus: probed
[ 1.393348] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.394463] usbcore: registered new interface driver r8152
[ 1.394529] usbcore: registered new interface driver lan78xx
[ 1.394607] usbcore: registered new interface driver smsc95xx
[ 1.440691] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.440728] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.443933] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
[ 1.445263] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.445282] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.445299] usb usb1: Product: xHCI Host Controller
[ 1.445316] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
[ 1.445332] usb usb1: SerialNumber: 0000:01:00.0
[ 1.446057] hub 1-0:1.0: USB hub found
[ 1.446169] hub 1-0:1.0: 1 port detected
[ 1.446856] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.446883] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.446909] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.447407] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.447425] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.447442] usb usb2: Product: xHCI Host Controller
[ 1.447458] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
[ 1.447474] usb usb2: SerialNumber: 0000:01:00.0
[ 1.448189] hub 2-0:1.0: USB hub found
[ 1.448263] hub 2-0:1.0: 4 ports detected
[ 1.449908] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.450219] dwc_otg: FIQ enabled
[ 1.450234] dwc_otg: NAK holdoff enabled
[ 1.450248] dwc_otg: FIQ split-transaction FSM enabled
[ 1.450265] Module dwc_common_port init
[ 1.450699] usbcore: registered new interface driver uas
[ 1.450805] usbcore: registered new interface driver usb-storage
[ 1.451007] mousedev: PS/2 mouse device common for all mice
[ 1.452673] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.456116] sdhci: Secure Digital Host Controller Interface driver
[ 1.456132] sdhci: Copyright(c) Pierre Ossman
[ 1.456843] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.457510] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.461561] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.461900] hid: raw HID events driver (C) Jiri Kosina
[ 1.462107] usbcore: registered new interface driver usbhid
[ 1.462122] usbhid: USB HID core driver
[ 1.467438] Initializing XFRM netlink socket
[ 1.467479] NET: Registered protocol family 17
[ 1.467599] Key type dns_resolver registered
[ 1.468018] Registering SWP/SWPB emulation handler
[ 1.468201] registered taskstats version 1
[ 1.468231] Loading compiled-in X.509 certificates
[ 1.469066] Key type ._fscrypt registered
[ 1.469082] Key type .fscrypt registered
[ 1.469097] Key type fscrypt-provisioning registered
[ 1.480405] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.480654] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.480727] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.487197] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
[ 1.488110] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550
[ 1.489096] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.490146] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.490164] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.518007] of_cfs_init
[ 1.518264] of_cfs_init: OK
[ 1.537312] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.539001] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.540688] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.543709] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.545392] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.553508] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.554183] Waiting for root device PARTUUID=fada9955-02…
[ 1.589240] random: fast init done
[ 1.612670] mmc1: new high speed SDIO card at address 0001
[ 1.813221] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.995839] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.995859] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.995877] usb 1-1: Product: USB2.0 Hub
[ 1.997625] hub 1-1:1.0: USB hub found
[ 1.997947] hub 1-1:1.0: 4 ports detected
[ 2.143560] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 2.175604] usb 2-1: New USB device found, idVendor=0951, idProduct=1666, bcdDevice= 1.10
[ 2.175623] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.175640] usb 2-1: Product: DataTraveler 3.0
[ 2.175657] usb 2-1: Manufacturer: Kingston
[ 2.175674] usb 2-1: SerialNumber: 08606E6B655BE37027217FF5
[ 2.178029] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 2.178831] scsi host0: usb-storage 2-1:1.0
[ 3.194219] scsi 0:0:0:0: Direct-Access Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[ 3.195308] sd 0:0:0:0: [sda] 60604416 512-byte logical blocks: (31.0 GB/28.9 GiB)
[ 3.195656] sd 0:0:0:0: [sda] Write Protect is off
[ 3.195676] sd 0:0:0:0: [sda] Mode Sense: 45 00 00 00
[ 3.196133] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 3.229685] sda: sda1 sda2
[ 3.232318] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 3.240682] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.240745] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
[ 3.241391] devtmpfs: mounted
[ 3.250296] Freeing unused kernel memory: 2048K
[ 3.283547] Run /sbin/init as init process
[ 3.283561] with arguments:
[ 3.283576] /sbin/init
[ 3.283590] splash
[ 3.283604] with environment:
[ 3.283619] HOME=/
[ 3.283633] TERM=linux
[ 3.524751] systemd[1]: System time before build time, advancing clock.
[ 3.597146] NET: Registered protocol family 10
[ 3.598521] Segment Routing with IPv6
[ 3.642858] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.643897] systemd[1]: Detected architecture arm.
[ 3.714263] systemd[1]: Set hostname to .
[ 4.353914] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.364004] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.364707] systemd[1]: Listening on Syslog Socket.
[ 4.365197] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.365536] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.366236] systemd[1]: Listening on udev Kernel Socket.
[ 4.369462] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.370143] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 4.370830] systemd[1]: Listening on udev Control Socket.
[ 4.371218] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.465940] i2c /dev entries driver
[ 4.975270] EXT4-fs (sda2): re-mounted. Opts: (null)
[ 5.091692] systemd-journald[114]: Received request to flush runtime journal from PID 1
[ 5.684938] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 5.685518] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 5.686027] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 5.686541] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 5.770007] mc: Linux media interface: v0.10
[ 5.795851] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.797571] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.798220] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.798244] [vc_sm_connected_init]: start
[ 5.799376] videodev: Linux video capture interface: v2.00
[ 5.808006] [vc_sm_connected_init]: installed successfully
[ 5.808286] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 5.831155] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.838061] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.838972] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.844285] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.844329] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.846648] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.846691] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.849280] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.849877] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.849917] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.887076] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.887474] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.887904] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.888384] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.888420] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.888454] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.888530] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.888563] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.888831] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 6.056608] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.139433] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 6.268807] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 6.284733] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.285181] usbcore: registered new interface driver brcmfmac
[ 6.290802] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 6.300064] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 6.471383] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[ 6.471524] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 6.472439] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 6.543947] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.553571] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 6.567746] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 8.100120] random: crng init done
[ 8.100144] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.952141] 8021q: 802.1Q VLAN Support v1.8
[ 24.563233] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k FS
[ 29.994914] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 29.995334] bcmgenet fd580000.ethernet eth0: Link is Down
[ 34.153506] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 34.153557] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 105.155254] broken atomic modeset userspace detected, disabling atomic
[ 105.761784] broken atomic modeset userspace detected, disabling atomic
[ 114.203386] broken atomic modeset userspace detected, disabling atomic
[ 129.453029] broken atomic modeset userspace detected, disabling atomic
[ 139.741918] broken atomic modeset userspace detected, disabling atomic
[ 149.884170] broken atomic modeset userspace detected, disabling atomic
[ 165.177189] broken atomic modeset userspace detected, disabling atomic
[ 188.140674] broken atomic modeset userspace detected, disabling atomic
[ 203.366676] broken atomic modeset userspace detected, disabling atomic
[ 216.132805] broken atomic modeset userspace detected, disabling atomic
[ 221.253289] broken atomic modeset userspace detected, disabling atomic
[ 236.459127] broken atomic modeset userspace detected, disabling atomic
[ 249.240610] broken atomic modeset userspace detected, disabling atomic
[ 249.865087] broken atomic modeset userspace detected, disabling atomic
[ 252.424940] broken atomic modeset userspace detected, disabling atomic
[ 253.017919] broken atomic modeset userspace detected, disabling atomic
[ 263.218830] broken atomic modeset userspace detected, disabling atomic
[ 278.472565] broken atomic modeset userspace detected, disabling atomic
[ 286.104261] broken atomic modeset userspace detected, disabling atomic
[ 291.197701] broken atomic modeset userspace detected, disabling atomic
[ 296.298511] broken atomic modeset userspace detected, disabling atomic
[ 309.021717] broken atomic modeset userspace detected, disabling atomic
[ 321.698364] broken atomic modeset userspace detected, disabling atomic
[ 326.812261] broken atomic modeset userspace detected, disabling atomic
[ 357.374189] broken atomic modeset userspace detected, disabling atomic
[ 370.117359] broken atomic modeset userspace detected, disabling atomic
[ 382.804891] broken atomic modeset userspace detected, disabling atomic
[ 392.989124] broken atomic modeset userspace detected, disabling atomic
[ 405.798256] broken atomic modeset userspace detected, disabling atomic
[ 433.774890] broken atomic modeset userspace detected, disabling atomic
[ 454.161947] broken atomic modeset userspace detected, disabling atomic
[ 461.758352] broken atomic modeset userspace detected, disabling atomic
[ 477.060065] broken atomic modeset userspace detected, disabling atomic
[ 477.630487] broken atomic modeset userspace detected, disabling atomic
[ 478.638134] broken atomic modeset userspace detected, disabling atomic
[ 479.271058] broken atomic modeset userspace detected, disabling atomic
[ 507.868388] broken atomic modeset userspace detected, disabling atomic
[ 515.464264] broken atomic modeset userspace detected, disabling atomic
[ 518.056898] broken atomic modeset userspace detected, disabling atomic
[ 525.662776] broken atomic modeset userspace detected, disabling atomic
[ 528.262677] broken atomic modeset userspace detected, disabling atomic
[ 532.803947] uart-pl011 fe201000.serial: no DMA platform data
