Disk write very hight
Lool, sorry, I thought you preferred anonymity
No problem. For me it’s doesn’t really impact my prod just use my ssd.
In jeedom I can activate or deactivate an element in their configuration. When I do that it don’t appears in the log.
But I don’t know if jeedom write or not in the database. I think I ll be better to talk with the dev. I just use the web interface.
There clearly an issue with jeedom, other users have the same like me. But why ? Mystery ^^
Ok so for information I m ATM on deconz 2.12.0 on a dev network with some various devices
Have started to count all websocket event at 2021-09-03 20:29:02.244
In 24h I will install the version v2.12.6 to compare.
Hopping for the change have not happen before the version 2.12.0 …
Thanks for your action.
Ok so my test results
deconz 2.12.0
Starting at 2021-09-03 20:29:02, finished at 2021-09-04 20:34:03 > Websocket count : 14 700
deconz 2.12.6
Starting at 2021-09-04 20:34:03 finished at 2021-09-05 19:27:50 > Websocket count : 19 100
(for 23 h so will take 19 920 for 24h)
So for the same network with only 15 nodes, the version 2.12.6 have 30% mores notifications.
We are far away from your 300% increase IO, but I can’t explain it (if someone have an idea ?), and it can depend of devices in the network.
Jeedom devs have found something ? On my side I m using filtering on websocket notifications, I check the device, if the state is the same, I give up the notification, I give up too all “attr” notifications.
I have some personal problem ATM, so not a lot of time, but Tomorrow, I will make a code with more statistics, useless notification/usefull notification/ignored one, ect …
Because I don’t think 15 devices need 20k notification to update their states on a complete day. I think the solution is on the filtering.
Thank you for your reply!
I’ve no news from geekdom developers unfortunately. Do you want the link to jeedom discord subject ?
You have 30% more notification. I’ve jeedom and deconz on the same virtual machine so 30% * 2 and maybe more if jeedom made some treatment if the value are the same.
30% more notification don’t provoke 30% disk write increase.
I m using a code by curiosty, it s just the start but on my plugin
2021-09-06 18:09:26.717 Status: (deCONZ) Websocket count:100 Used:9 ignored:34 useless:80
On 100 notification 34 are not used at all, and 80 haven’t an impact on the code. So only 9 have changed something on the device database on the third app. And only thoses 9 can hve an impact on the SQL database used by my third app.
Yeah I know the total don’t make 100 ^^, but It s just a test (some notification can be threated 2 times config + state), to explain the role of the filtering.
Thoses stats are not precises, I have too a plug off that send a power = 0 reporting that is counted in useless notification, and no for plugs this notification is usefull
Ok so what can I do for help ?
Can ask to jeedom dev if they are filtering the notifications too, or if they write something in the database for ALL notifications ?
2021-09-07 18:51:04.137 Status: (deCONZ) Websocket count:18400 Used:394 ignored:6254 useless:11891
As sample for me on 18400 notifications received I have used only 394 of them (I don’t use “lastupdated”)
Edit:
Nothing to see, but If I take 300 bytes by notifications, it make 5M of data in 24h for 15 devices, I m curious of how much data are used for network > 150 devices, with lots of plugs ^^.
There is nothing to do here by deCONZ i guess.
Ok so the jeedom team tell my they filter nothing.
Every thing in analyse by jeedom.
So can be the problem.
Just to try, say them to ignore “attr” report, to compare. IDK if they use it.
It’s personal, but I m not sure the “lastupdated” field need to be written on the database.
Ok thank you. I transmit the message.
Thanks for your work. The jeedom dev team made a new version with your advice et it works very well.
They are just ignoring “attr” report ?
There is badly no way to disable them, and it s the bigger part of notifications, but they are not realy usefull at all.
I don’t know what they do. But my disk writting came back to the normal.
And by curiosity, you can’t ask to them ? If i s not “secret defense” ^^
He just ignore every attribut update.
So “attr” request, I do same. too much chatting for nothing usefull.
