I use deconz with jeedom. Since the last update 2.16.4 and last firmware update, my ssd write a lot.
After it use 400\500 ko the it near 2 MO !
When I stop deconz everything become OK again.
I juste made the update on my configuration. I run on a VM in proxmox debian buster (with the last update). I don’t know what can I do in order to stop it.
The small little detail to note here is that deconz does not use mysql leading to the conclusion that it’s system specific and an induced dependency, if any.
The last change made on deconz using its DB was that the disk writes have significantly decreased by raising the write interval from 5 to 60 seconds as I recall.
“It is Jeedom which uses MySQL but the concern must come from their application which must have a problem at the level of the websocket which sends the events of the modules. They have to buckle up or something and that overloads Jeedom.” (it’s a google traduction).
To check websocket you can use jeedom logs, or phoscon beta http://phoscon.de/pwabeta in help / api information / Event
But It still a mystery for me, there is no more websockets events added recently for me.
It have increase when we have added “lastseen” and “lastannounced” with the “attr” notification, but it s not something recent …
