Describe the bug
See also:
My environment is different in terms of lights and switches compared to ones described above, but the situation is identical. However, lights, LED Strip controllers etc. turn on randomly. The period of “silence” (normal behavior without touching switches or any other action in Phoscon) can be between 10 to 15 minutes or 24 hours and in rare cases days. No lights and switches have bindings, hence pure coordinator mode.
If a lamp turns on randomly it is shown in Phoscon as “on”. deCONZ has connectivity to the specific lamp and clusters are normal read and writeable. The lamp can be turned “off” either in Phoscon or via a configures hardware switch – I my case a Busch & Jaeger RM01 switch.
I run several installations with RaspBee II and all have similar problems. Installations with only a couple of lamps e.g., 2 and switches e.g., 2 are more stable, but even in such a scenario a lamp turn on randomly from time to time. The problem escalates with more devices within the network. I have networks with 4, 40 and 80+ nodes. All behave the same. I observe this behavior across all software and firmware version and had the problem even with the RaspBee I gateway years ago. It is not predicable which device turn on (never had a device turn “off” randomly) and it happens over all vendors and ZigBee versions, stacks, and builds. Namely Paul Neuhaus lamps ZCL 1, AV 1, SV 2 and ZCL 3, AV 1, SV 1; dresden elektronik FLS-CT ZCL 1, AV 2, SV 3; dresden elektronik FLS-PP3 ZCL 1, AV 2, SV 3 and so on. Important to note it never happened with ubisys S2 actors regardless of the ZigBee version and Signify lamps ZCL 2, AV 2, SV 1 also regardless of the zigbee version. All hardware switches involved are Busch-Jaeger RM01 ZCL 1, AV 1, SV 1 (powered devices and routers). WLAN and ZigBee channels well defined. Zigbee network is sitting between 11 and 15, but the channel makes no difference in terms of behavior. The WLAN is sitting on channel 11 faraway from channel WLAN 1 where the 11 to 15 ZigBee channels overlap. RSSI is between -45 and -80 on some devices (rare). LQI is almost 255 on most devices. A few reports a LQI of 160. Debug ERROR and ERROR_L2 showed no errors at all. Hence radio seems to be OK.
Environment
Raspberry PI 4 with RaspBee II 8G on GE LAN (antenna not shielded)
deCONZ 2.18.02 downgraded due to the group problem of 2.20.00
Rasbee II with Firmware 0x26780700 (tested with different hardware / firmware > same behavior)
However, I can confirm that the “light turn on” problem is identical in 2.20.00 (verified). Did a clean installation of 2.20.00 without powered off devices in deCONZ and group management worked. See: Changing group lights has no effect anymore
Raspbian GNU/Linux version 10 patched as of 12.01.2023 (OS version has no impact at all)
Screenshots Parameters
Logs
Logs will come, but will see how i can capture usefull information. Please let me know.
