I’m having trouble with my ConBee II stick. It is attached to a Rasperry running Raspian and FHEM. It was working fine for several month. Now I’m not able to access the ZigBee devices any further.
I run update and upgrade without any effect
lsusb recognizes the stick
the serial ( ls -l /dev/ttyACM* ) ttyACM0 is available
with systemctl I see deconz-init.service failed
sudo systemctl start deconz-init.service failed
restart the raspberry failed
sudo systemctl status deconz-init.service says:
● deconz-init.service - deCONZ: ZigBee gateway – Initialisation
Loaded: loaded (/lib/systemd/system/deconz-init.service; disabled; vendor preset: enabled)
Active: inactive (dead) since Sat 2022-01-08 22:42:10 CET; 24s ago
Process: 10809 ExecStart=/usr/bin/deCONZ-init.sh (code=exited, status=0/SUCCESS)
Main PID: 10809 (code=exited, status=0/SUCCESS)
When I run journalctl -xe here are some lines of the result:
Jan 08 22:43:43 raspberrypi systemd[1]: deconz-init.service: Start request repeated too quickly.
Jan 08 22:43:43 raspberrypi systemd[1]: Failed to start deCONZ: ZigBee gateway – Initialisation.
– Subject: Unit deconz-init.service has failed
– Defined-By: systemd
– Support: Debian -- Support
Jan 08 22:46:54 raspberrypi systemd[1]: deconz-init.service: Failed with result ‘start-limit-hit’.
Jan 08 22:47:26 raspberrypi deCONZ[19808]: This plugin does not support propagateSizeHints()
Jan 08 22:47:56 raspberrypi systemd[1]: deconz.service: Service hold-off time over, scheduling restart.
Q
Jan 08 22:47:57 raspberrypi systemd[1]: deconz.service: Main process exited, code=exited, status=127/n/a
Jan 08 22:47:57 raspberrypi systemd[1]: deconz.service: Unit entered failed state.
Jan 08 22:47:57 raspberrypi systemd[1]: deconz.service: Failed with result ‘exit-code’.
Any ideas, why this service isn’t running any more? What can I do further to get it started?
i’m using the headless version. I upgraded from Sketch to Buster yesterday, but that didn’t help eather.
pi@raspberrypi:~ $ /usr/bin/deCONZ --dbg-error=2 --dbg-info=2 -platform minimal
/usr/bin/deCONZ: relocation error: /usr/bin/deCONZ: symbol _ZNK12QFontMetrics17horizontalAdvanceERK7QStringi, version Qt_5 not defined in file libQt5Gui.so.5 with link time reference
Raspbian says the latest version is already installed. So I uninstalled deconz and did a fresh install. But withour any result:
pi@raspberrypi:~ $ systemctl status deconz-init.service
Active: failed (Result: start-limit-hit) since Sun 2022-01-09 16:41:22 CET; 1min 22s ago
Process: 2417 ExecStart=/usr/bin/deCONZ-init.sh (code=exited, status=0/SUCCESS)
Main PID: 2417 (code=exited, status=0/SUCCESS)
Jan 09 16:41:53 raspberrypi systemd[1]: deconz-init.service: Failed with result ‘start-limit-hit’.
Jan 09 16:41:55 raspberrypi systemd[1]: deconz-init.service: Start request repeated too quickly.
Jan 09 16:41:55 raspberrypi systemd[1]: Failed to start deCONZ: ZigBee gateway – Initialisation.
Jan 09 16:41:55 raspberrypi systemd[1]: deconz-init.service: Failed with result ‘start-limit-hit’.
Jan 09 16:42:25 raspberrypi systemd[1]: deconz-init.service: Start request repeated too quickly.
Jan 09 16:42:25 raspberrypi systemd[1]: Failed to start deCONZ: ZigBee gateway – Initialisation.
Jan 09 16:42:25 raspberrypi systemd[1]: deconz-init.service: Failed with result ‘start-limit-hit’.
Jan 09 16:42:26 raspberrypi systemd[1]: deconz-init.service: Start request repeated too quickly.
Jan 09 16:42:26 raspberrypi systemd[1]: Failed to start deCONZ: ZigBee gateway – Initialisation.
Jan 09 16:42:26 raspberrypi systemd[1]: deconz-init.service: Failed with result ‘start-limit-hit’.
