Conbee Disconnecting
Hello, I have the problem that my Conbee 2 is always deactivated and then is not recognized by deconz for about 30-90 minutes before it is automatically detected again.
Environment:
Raspberry Pi 4 with “Raspbian GNU/Linux 11 (bullseye)”. All packages are up to date.
deconz version 2.17.01 / 1.7.2022 (docker container).
Conbee 2 Firmware: 26780700
No usb extension. I’ve tried several USB ports, always the same problem.
cat docker-compose.yml
version: "3"
services:
  deconz:
    image: deconzcommunity/deconz:latest
    container_name: deconz
    privileged: true
    restart: always
    volumes:
      - /root/compose/deconz/opt/deconz:/opt/deCONZ
    devices:
      - /dev/ttyACM0
    environment:
      - DECONZ_DEVICE=/dev/ttyACM0
      - DECONZ_WEB_PORT=50180
      - DECONZ_WS_PORT=50143
      - DECONZ_VNC_MODE=1
      - DECONZ_VNC_PASSWORD=<secret!>
      - DEBUG_INFO=1
      - DEBUG_APS=0
      - DEBUG_ZCL=0
      - DEBUG_ZDP=0
      - DEBUG_OTAU=0
    networks:
      macvlan0:
        ipv4_address: 192.168.2.201
networks:
  macvlan0:
    external:
ls -al /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432062-if00
lrwxrwxrwx 1 root root 13 26. Jul 20:12 /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432062-if00 → …/…/ttyACM0
Every hour these messages appear in /var/log/messages
Jul 27 09:13:02 raspi4 kernel: [3241226.735491] usb 1-1.2: USB disconnect, device number 50
Jul 27 09:13:02 raspi4 kernel: [3241227.031411] usb 1-1.2: new full-speed USB device number 51 using xhci_hcd
Jul 27 09:13:02 raspi4 kernel: [3241227.170425] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 27 09:13:02 raspi4 kernel: [3241227.170440] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 27 09:13:02 raspi4 kernel: [3241227.170447] usb 1-1.2: Product: ConBee II
Jul 27 09:13:02 raspi4 kernel: [3241227.170453] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 27 09:13:02 raspi4 kernel: [3241227.170459] usb 1-1.2: SerialNumber: DE24320xx
Jul 27 09:13:02 raspi4 kernel: [3241227.175802] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
Jul 27 09:13:02 raspi4 mtp-probe: checking bus 1, device 51: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
Jul 27 09:13:02 raspi4 mtp-probe: bus: 1, device: 51 was not an MTP device
Jul 27 09:13:03 raspi4 mtp-probe: checking bus 1, device 51: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
Jul 27 09:13:03 raspi4 mtp-probe: bus: 1, device: 51 was not an MTP device
Jul 27 09:13:07 raspi4 kernel: [3241231.856127] usb 1-1.2: USB disconnect, device number 51
Jul 27 09:13:07 raspi4 kernel: [3241232.161529] usb 1-1.2: new full-speed USB device number 52 using xhci_hcd
Jul 27 09:13:08 raspi4 kernel: [3241232.310554] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 27 09:13:08 raspi4 kernel: [3241232.310580] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 27 09:13:08 raspi4 kernel: [3241232.310596] usb 1-1.2: Product: ConBee II
Jul 27 09:13:08 raspi4 kernel: [3241232.310610] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 27 09:13:08 raspi4 kernel: [3241232.310625] usb 1-1.2: SerialNumber: DE24320xx
Jul 27 09:13:08 raspi4 kernel: [3241232.318041] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
Jul 27 09:13:08 raspi4 mtp-probe: checking bus 1, device 52: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
Jul 27 09:13:08 raspi4 mtp-probe: bus: 1, device: 52 was not an MTP device
Jul 27 10:13:07 raspi4 kernel: [3244831.215418] usb 1-1.2: USB disconnect, device number 52
Jul 27 10:13:07 raspi4 kernel: [3244831.512756] usb 1-1.2: new full-speed USB device number 53 using xhci_hcd
Jul 27 10:13:07 raspi4 kernel: [3244831.661844] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 27 10:13:07 raspi4 kernel: [3244831.661859] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 27 10:13:07 raspi4 kernel: [3244831.661867] usb 1-1.2: Product: ConBee II
Jul 27 10:13:07 raspi4 kernel: [3244831.661873] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 27 10:13:07 raspi4 kernel: [3244831.661880] usb 1-1.2: SerialNumber: DE24320xx
Jul 27 10:13:07 raspi4 kernel: [3244831.667260] cdc_acm 1-1.2:1.0: ttyACM1: USB ACM device
Jul 27 10:13:07 raspi4 mtp-probe: checking bus 1, device 53: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
Jul 27 10:13:07 raspi4 mtp-probe: bus: 1, device: 53 was not an MTP device
Jul 27 10:13:10 raspi4 kernel: [3244835.056005] usb 1-1.2: USB disconnect, device number 53
Jul 27 10:13:11 raspi4 kernel: [3244835.402784] usb 1-1.2: new full-speed USB device number 54 using xhci_hcd
Jul 27 10:13:11 raspi4 kernel: [3244835.542336] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 27 10:13:11 raspi4 kernel: [3244835.542363] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 27 10:13:11 raspi4 kernel: [3244835.542415] usb 1-1.2: Product: ConBee II
Jul 27 10:13:11 raspi4 kernel: [3244835.542429] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 27 10:13:11 raspi4 kernel: [3244835.542467] usb 1-1.2: SerialNumber: DE24320xx
Jul 27 10:13:11 raspi4 kernel: [3244835.550054] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
Jul 27 10:13:11 raspi4 mtp-probe: checking bus 1, device 54: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
Jul 27 10:13:11 raspi4 mtp-probe: bus: 1, device: 54 was not an MTP device
The Conbee 2 stick becomes active automatically after some time without any manual interaction.
When I remove the stick from the Raspi and plug it back in, it is immediately recognized by deconz again. Same after restarting the whole Pi.
Does anyone have any ideas on how to avoid these regular outages?
THANKS for your support!
Created a new topic as it is slightly different.
Can you please provide deconz logs? You can find out how to make them in #deconz
Post them in pastebin please.
Thanks for opening the new topic.
I’ve posted the logs here: deconz_ß1 - Pastebin.com
Your network config seems broken.
In deCONZ, click “leave” on the top (in green)
Under “Edit” - open Network Settings
Under TC Adress, put 0x00212EFFFF07386D
Under APS Ext Pan ID use 0x0000000000000000
Click “Save” and “done”
Where you clicked “leave” click “join”.
See what happens now.
Did you, by any chance, have Zigbee Home Automation or Zigbee2Mqtt running before?
Ok thanks, seems to work for now. I’ll keep watching it.
Good guess, I had Zigbee2Mqtt running about one year ago. But not on this Pi and only with some of the connected items.
That might be the reason the network settings changed.
keep me posted :slight_smile:
Since the configuration change yesterday there has not been a single abort, so looks very good so far. Thanks for the support!
Hi everyone,
I had the same periodic reconnects making conbee unusable and I’ve been searching for months for a reason.
My logs looked exactly the same way as mentioned above:
On my system (Ubuntu Server) there was tuned installed. An application for power saving. Tuned was presumably out-of-the-box configured to suspend USB ports.
I was able to fix the reconnect problem by disabling Tuned.
Just wanted to add this hint, because Conbee is now working great again without disconnects for at least 3 months.
Conclusion:
Look for power saving tools on your system, even if you think you don’t have them installed.
For Linux the following tools are likely to cause problems (depending on configuration):
  • powertop
  • tuned
  • auto-cpufreq
  • cpufrequtils
  • upower
Good luck!
