Conbee 3 pairing devices using devices does not work
Hey,
I’m not sure if this is a ZHA problem or a firmware/device problem with the Conbee 3. When I pair a device in Home Assistant using ZHA I can connect devices without any problem using the latest firmware. However devices that are too far for the stick itself, I use hardwired devices (IE: hue GU10 spots or other hue lamps) to try pair devices in that neighborhood. When doing so, the Conbee stick does not find any devices (even when resetting the devices I try to pair).
So in HA using “add zigbee device” works but using “adding device through device” does not work.
Can anyone from Deconz confirm if this might be a ZHA problem or a firmware problem? In case ZHA, maybe work together with the ZHA team (zigpy) to solve this problem. So far the Conbee 3 inside ZHA has been rock solid… only this minor problem plagues my setup.
Logging from HA can be found in the ticket down below.
Home Assistant ticket: [ZHA] [Conbee 3] Eurotronic Spirit Zigbee does not pair · Issue #105394 · home-assistant/core (github.com)
Using firmware 0x26500900
Device: Conbee 3
Home Assistant version: 2024.2.0
Devices I try to pair: Hue motion, Aqara window/door sensors (again both work great when directly pairing)
I have similar problem with Conbee3 and same firmware version: TRVZB SONOFF problem via repeater
Good to know I’m not the only one.
@manup can you help us? Let us know if we need to provide anything for debugging.
Hi, i am the Firmware Developer for the CB3.
I can’t really recreate your Bug. For me the Pairing via a specific Parent works flawlessly. Could you provide us with a Debug-Log when trying to pair your device ?
For this go to http://HA-HOSTNAME:PORT/config/integrations/integration/zha click on “enable debug logging” and try to pair the device. After ~3Min disable the the Debug Logging. This should trigger the download of a debug file. Please send us this file via support@dresden-elektronik.de (Mail is necessary for privacy reasons, the debug-file could contain sensible Data about your Network).
Best Regards,
Eric
Please see the linked github page in the original post. There you can find logging including zha logging in debug modus.
@Haerteleric or use this link directly: [ZHA] [Conbee 3] Eurotronic Spirit Zigbee does not pair · Issue #105394 · home-assistant/core · GitHub
@Haerteleric I send an email to support@dresden-elektronik.de with loggings and diagnostics. I tried to pair a Philips Hue LTG002 with another Philips Hue LTG002 and it just does not seem to pair.
Hello, there was an issue on philips Philips Hue Wall Switch does not work since update to v2.27.0 · Issue #7785 · dresden-elektronik/deconz-rest-plugin · GitHub
It’s corrected ATM, but I think if you are on HA, you are using an old deconz version ?
I don’t use Deconz. I use ZHA.
@Haerteleric did you receive the email with the logging? Any luck finding anything?
Hi, yes im working on a fix. But im quite busy atm.
Could you try if this firmware makes things better ?
firmware52_PreRelease2.gcf.ota (177.9 KB)
you have to remove the .ota postfix to make it work with GCFFlasher.
Best Regrads
Eric
No worries. Thanks for the help!
I tried the update, the firmware was successfully applied but no luck pairing the same devices I tried before. Got logging if you need it, let me know and I’ll mail it.
@Haerteleric: Any update or ETA regarding this issue or any new pre-releases I can try? Thanks!
I think that should be following version:
https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_ConBeeIII_0x26530900.bin.GCF
More details can be found in Firmware Changelog · dresden-elektronik/deconz-rest-plugin Wiki · GitHub
No luck. I upgraded successfully and tried pairing a hue spot. I couldn’t pair.
