Conbee 2 Ikea Fyrtur with Switch
Hello, I am using the Conbee 2 Stick on an Raspberry application with DECONZ. I want to drive my IKEA Fyrtur Blends togehter with the original switches included. I can connect the Fyrtur Blends and the switches seperated but can not connect them via “Schalterteditor”. Is there a way to control the Blends via the Conbee and via the Switches?
THXaLOT
You can bind the switch directly to the blind, but might need to do it in the deConz GUI:
Tried it this way. Always get Information „failed: timeout“ when I press BIND. Any ideas?
And with using the old web app ?
On phoscon/help/old web app.
Edit:
I m seing the old webb app is disabled now ? Try with http://deconzip:deconzport/login.html
Shortly after pressing Bind you need to wake up the device, usually pressing the button does the trick. Otherwise the command will timeout.
