Hi
I have aquired my first Phillips Hue devices, a couble of Hue Play lamps, I am running a Conbee stick and Deconz/Phoscon.
When I try to add the Play lamps the are discovered right away, and they look like all my other lamps/bulbs in here.
I can add them to my groups also, but I cant control them, nothing happens when I try to change color, turn on and off or change the saturation or brightnes.
After a while they are grayed out, like the Lamps where turned off. Even if the lamps are still turned on.
Can anyone help me here, what can I do to investigate further or is there a fix.
Running version 2.05.79 Firmware 260B0500!
The Lamps apear as:
Vendor Philips
Model 440400982841
Version 1.56.7_r29434
Regards Jens
