Aqara cube T1 pro (again)
I read all the postings from last year regarding Aqara cube T1 pro, but no news from 2023.
So, let´s ask again what the status is.
I try to connect the cube with the help of the Phoscon app. What happens?
  • the switch is detected as “lumi.remote.cagl02”. Seems to be correct.
  • I cannot configure a cube, I can only configure a normal switch.
Under /user/share/deCONZ/devices/xiaomi I find this file “xiaomi_mfkzq12lm_t1_pro_cube.json”. So, I assume it should work.
This is the configuration under “API information”
“config”: {
“battery”: 0,
“devicemode”: “action”,
“on”: true,
“reachable”: true
“ep”: 3,
“etag”: “f70031997e6ef8634d283f4bc4414804”,
“lastannounced”: null,
“lastseen”: “2023-11-19T16:49Z”,
“manufacturername”: “LUMI”,
“mode”: 1,
“modelid”: “lumi.remote.cagl02”,
“name”: “lumi.remote.cagl02”,
“state”: {
“buttonevent”: null,
“gesture”: null,
“lastupdated”: “none”
“type”: “ZHASwitch”,
“uniqueid”: “54:ef:44:10:00:7a:27:55-03-000c”
“config”: {
“battery”: 0,
“on”: true,
“reachable”: true
“ep”: 2,
“etag”: “9b8772a8ae3d60f7695a07ba8accc630”,
“mode”: 1,
“state”: {
“buttonevent”: 7000,
“gesture”: 0,
“lastupdated”: “2023-11-19T16:49:08.355”
“uniqueid”: “54:ef:44:10:00:7a:27:55-02-0012”
DDF
“00:21:2e:ff:ff:09:aa:c1”,
“d0:cf:5e:ff:fe:13:c6:08”,
“90:fd:9f:ff:fe:d8:92:99”,
“d0:cf:5e:ff:fe:07:fe:5e”,
“90:fd:9f:ff:fe:20:db:84”,
“54:ef:44:10:00:7a:27:55”
What should I do to us the cube T1 pro configuration as described under devices?
My configuration
  • RasPi
  • Conbee II
  • Gateway version 2.24.1
  • Firmware 26720700
Best regards,
Stephan
I’m afraid I cannot follow you. Do you want to say the cube doesn’t work with deconz? It actually does and that’s also the reason why there’s not further communication around it in Github.
This is exactly my point. It doesn´t work.
The device was detected (lumi.remote.cagl02) but not as cube (simple switch)
In Phoscon you mean?
Yes in Phoscon App
Today, I received my Black Friday delivery. Aqara smart switch, vibration sensor, motion sensor.
All integrated in no time. Perfect.
Only the cube doesn´t work.
Any idea?
@de_employees has to answer that.
I was not aware of that new modelid of the cube. Because I see in the Phoscon App is only the last version of the cube with modelid “…cagl01”.
So the cube is just recognized as some general zigbee switch. Which does not work for the cube because it is something special with all that buttonevents and rotary events.
So I will add it to the Phoscon App and hope nothing more changed so it will just work in the App as the other cubes.
Thats why we have changelogs in deCONZ :wink:
Thanks Christian,
What does it mean for me? How and when will I receive the update?
Best regards,
Stephan
@ChrisHae You might want to also consider the other Cube versions/models out there, we got a few by now :slight_smile:
Yeah, I guess I have to take a look what models are out there and I think I will order a T1 Pro cube to see what it does.
@Rudi I think the update will be in the next Android and iOS Phoscon App update next week. And for PC perhaps in the next beta version of deCONZ.
… it would be great if you could give us a hint once the update is available …
Due to illness of our android/ios developer the release of these versions will probably postponed until next week.
The next deCONZ beta release is scheduled for end of this week or next week.
I will update you when they are released.
