@Smanar i have the issue again (and already removed all osram routers), so that was not the issue.
I am connecting to my deconz via vuilt in VNC throught home assistant gui. Activated all four info and error but how can i copy the log out of it!? right click and copy doent pass the log to my client and i cant paste it ionto notepad or similiar.
I now have copied it from the home assistant settings → addon → deconz → log, but it’s rather short.
here it is:
07:19:17:581 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":51,"ledindication":false,"on":true,"reachable":true,"tholddark":19515,"tholdoffset":7000,"usertest":false},"e":"changed","id":"52","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:89:a3-02-0400"} (ret = 238)
07:19:17:582 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":51,"ledindication":false,"offset":0,"on":true,"reachable":true,"usertest":false},"e":"changed","id":"51","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:89:a3-02-0402"} (ret = 212)
07:19:17:606 APS-DATA.indication from child 0x721F
07:19:17:607 0x000d6ffffebe3dcd found group 0xFFF0
07:19:17:608 0x000d6ffffebe3dcd found group 0x000C
07:19:17:624 poll node 00:17:88:01:04:a4:72:7c-0b
07:19:17:624 Poll light node Arbeitszimmer 2
07:19:17:625 rule event /config/localtime: 07:19:16.631 -> 07:19:17.623 (992ms)
07:19:17:778 No presence sensor found for 0x0017880104B6169E, endpoint: 0x02
07:19:17:779 ZCL attribute report 0x0017880104B6169E for cluster: 0x0406, ep: 0x02, frame control: 0x18, mfcode: 0x0000
07:19:17:779 payload: 00001800
07:19:17:780 Websocket 172.30.32.1:51432 send message: {"e":"changed","id":"27","r":"sensors","state":{"lastupdated":"2022-10-21T05:19:17.778","presence":false},"t":"event","uniqueid":"00:17:88:01:04:b6:16:9e-02-0406"} (ret = 163)
07:19:17:781 read attributes of 0x0017880104A4727C cluster: 0x0006: [ 07:19:17:782 0x0000 07:19:17:782 ]
07:19:17:783 add task 3482285 type 19 to 0x0017880104A4727C cluster 0x0006 req.id 222
07:19:17:783 Poll APS request 222 to 0x0017880104A4727C cluster: 0x0006
07:19:17:919 Poll APS confirm 222 status: 0x00
07:19:17:921 Erase task req-id: 222, type: 19 zcl seqno: 190 send time 0, profileId: 0x0104, clusterId: 0x0006
07:19:17:952 Node data 0x0017880104a4727c profileId: 0x0104, clusterId: 0x0006
07:19:17:955 0x0017880104A4727C: update ZCL value 0x0B/0x0006/0x0000 after 0 s
07:19:17:957 Websocket 172.30.32.1:51432 send message: {"attr":{"id":"12","lastannounced":"2022-06-01T03:04:10Z","lastseen":"2022-10-21T05:19Z","manufacturername":"Philips","modelid":"LWB010","name":"Arbeitszimmer 2","swversion":"1.88.1","type":"Dimmable light","uniqueid":"00:17:88:01:04:a4:72:7c-0b"},"e":"changed","id":"12","r":"lights","t":"event","uniqueid":"00:17:88:01:04:a4:72:7c-0b"} (ret = 337)
07:19:18:095 DB save zll database items 0x00000081
07:19:18:096 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('120', 'Fenster Arbeitszimmer geöffnet', 'ZHAOpenClose', 'lumi.sensor_magnet.aq2', 'LUMI', '00:15:8d:00:05:4d:98:82-01-0006', '20161128', '{"lastupdated":"2022-10-21T05:19:02.981","open":false}', '{"battery":95,"on":true,"reachable":true,"temperature":3000}', '{"d":24321,"ep":1,"in":[6],"p":260}', 'normal', '1', '2022-10-21T05:19Z', '2022-09-21T06:38:11Z')
07:19:18:098 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('110', 'Türkontaktsensor Kasten VR_L', 'ZHAOpenClose', 'lumi.sensor_magnet.aq2', 'LUMI', '00:15:8d:00:04:ab:c7:fc-01-0006', '20161128', '{"lastupdated":"2022-10-21T05:18:17.881","open":false}', '{"battery":100,"on":true,"reachable":true,"temperature":3200}', '{"d":24321,"ep":1,"in":[6],"p":260}', 'normal', '1', '2022-10-21T05:18Z', '2022-06-11T18:57:45Z')
07:19:18:099 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('141', 'Türkontaktsensor Kasten Julian', 'ZHAOpenClose', 'lumi.sensor_magnet.aq2', 'LUMI', '00:15:8d:00:05:40:3a:26-01-0006', '20161128', '{"lastupdated":"2022-10-21T05:18:38.089","open":false}', '{"battery":100,"on":true,"reachable":true,"temperature":3000}', '{"d":24321,"ep":1,"in":[6],"p":260}', 'normal', '1', '2022-10-21T05:18Z', '2022-06-11T19:03:21Z')
07:19:18:100 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('191', 'Bewegungsmelder Buero Tür', 'ZHALightLevel', 'SML003', 'Philips', '00:17:88:01:0b:ce:5b:ad-02-0400', '2.53.6', '{"dark":true,"daylight":false,"lastupdated":"2022-10-21T05:19:15.654","lightlevel":0,"lux":0}', '{"battery":100,"on":true,"reachable":true,"tholddark":17427,"tholdoffset":7000}', '{"d":263,"ep":2,"in":[0,1,1024],"p":260}', 'normal', '1', '2022-10-21T05:19Z', '2022-10-15T23:41:22Z')
07:19:18:108 DB saved in 12 ms
07:19:18:641 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":24,"delay":0,"ledindication":false,"on":true,"reachable":true,"sensitivity":2,"sensitivitymax":2,"usertest":false},"e":"changed","id":"47","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:92:b9-02-0406"} (ret = 246)
07:19:18:643 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":24,"ledindication":false,"on":true,"reachable":true,"tholddark":17427,"tholdoffset":7000,"usertest":false},"e":"changed","id":"49","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:92:b9-02-0400"} (ret = 238)
07:19:18:644 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":24,"ledindication":false,"offset":0,"on":true,"reachable":true,"usertest":false},"e":"changed","id":"48","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:92:b9-02-0402"} (ret = 212)
07:19:18:664 rule event /config/localtime: 07:19:17.623 -> 07:19:18.653 (1030ms)
07:19:19:126 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":32,"delay":0,"ledindication":false,"on":true,"reachable":true,"sensitivity":2,"sensitivitymax":2,"usertest":false},"e":"changed","id":"27","r":"sensors","t":"event","uniqueid":"00:17:88:01:04:b6:16:9e-02-0406"} (ret = 246)
07:19:19:127 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":32,"ledindication":false,"on":true,"reachable":true,"tholddark":10881,"tholdoffset":7000,"usertest":false},"e":"changed","id":"29","r":"sensors","t":"event","uniqueid":"00:17:88:01:04:b6:16:9e-02-0400"} (ret = 238)
07:19:19:129 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":32,"ledindication":false,"offset":0,"on":true,"reachable":true,"usertest":false},"e":"changed","id":"28","r":"sensors","t":"event","uniqueid":"00:17:88:01:04:b6:16:9e-02-0402"} (ret = 212)
07:19:19:137 Websocket 172.30.32.1:51432 send message: {"attr":{"id":"88","lastannounced":"2022-10-15T10:06:58Z","lastseen":"2022-10-21T05:19Z","manufacturername":"IKEA of Sweden","modelid":"KADRILJ roller blind","name":"KADRILJ roller blind ","swversion":"2.3.088","type":"ZHABattery","uniqueid":"00:0d:6f:ff:fe:be:3d:cd-01-0001"},"e":"changed","id":"88","r":"sensors","t":"event","uniqueid":"00:0d:6f:ff:fe:be:3d:cd-01-0001"} (ret = 372)
07:19:19:171 Incr. ZDP retry count 2636 on item 2
07:19:19:618 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":51,"delay":0,"ledindication":false,"on":true,"reachable":true,"sensitivity":2,"sensitivitymax":2,"usertest":false},"e":"changed","id":"50","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:89:a3-02-0406"} (ret = 246)
07:19:19:620 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":51,"ledindication":false,"on":true,"reachable":true,"tholddark":19515,"tholdoffset":7000,"usertest":false},"e":"changed","id":"52","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:89:a3-02-0400"} (ret = 238)
07:19:19:622 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":51,"ledindication":false,"offset":0,"on":true,"reachable":true,"usertest":false},"e":"changed","id":"51","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:89:a3-02-0402"} (ret = 212)
07:19:19:630 poll node 00:17:88:01:03:9f:38:ad-0b
07:19:19:631 Poll light node Wohnzimmer Stehlampe oben
07:19:19:632 Idle timer triggered
07:19:19:632 Force binding of attribute reporting for node Bad Alibert Mitte
07:19:19:632 Force read attributes for ZHATemperature SensorNode Bewegungsmelder Kammerl
07:19:19:633 Force binding of attribute reporting for node Bewegungsmelder Kammerl
07:19:20:100 rule event /config/localtime: 07:19:18.653 -> 07:19:19.630 (977ms)
07:19:20:104 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":24,"delay":0,"ledindication":false,"on":true,"reachable":true,"sensitivity":2,"sensitivitymax":2,"usertest":false},"e":"changed","id":"47","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:92:b9-02-0406"} (ret = 246)
07:19:20:105 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":24,"ledindication":false,"on":true,"reachable":true,"tholddark":17427,"tholdoffset":7000,"usertest":false},"e":"changed","id":"49","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:92:b9-02-0400"} (ret = 238)
07:19:20:107 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":24,"ledindication":false,"offset":0,"on":true,"reachable":true,"usertest":false},"e":"changed","id":"48","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:92:b9-02-0402"} (ret = 212)
07:19:20:109 read attributes of 0x00178801039F38AD cluster: 0x0006: [ 07:19:20:109 0x0000 07:19:20:110 ]
07:19:20:110 add task 3482291 type 19 to 0x00178801039F38AD cluster 0x0006 req.id 240
07:19:20:110 Poll APS request 240 to 0x00178801039F38AD cluster: 0x0006
07:19:20:111 Daylight now: dawn, status: 130, daylight: 0, dark: 1
07:19:20:138 APS-DATA.indication from child 0x721F
07:19:20:139 Bind response success for 0x000d6ffffebe3dcd ep: 0x01 cluster: 0x0006
07:19:20:140 skip configure report for cluster: 0x0006 attr: 0x0000 of node 0x000D6FFFFEBE3DCD (wait reading or unsupported)
07:19:20:201 Poll APS confirm 240 status: 0x00
07:19:20:202 Erase task req-id: 240, type: 19 zcl seqno: 195 send time 0, profileId: 0x0104, clusterId: 0x0006
07:19:20:206 Node data 0x00178801039f38ad profileId: 0x0104, clusterId: 0x0006
07:19:20:207 0x00178801039F38AD: update ZCL value 0x0B/0x0006/0x0000 after 0 s
07:19:20:208 Websocket 172.30.32.1:51432 send message: {"attr":{"colorcapabilities":16,"ctmax":454,"ctmin":153,"id":"16","lastannounced":"2022-09-11T18:37:06Z","lastseen":"2022-10-21T05:19Z","manufacturername":"Philips","modelid":"LTW012","name":"Wohnzimmer Stehlampe oben","swversion":"1.88.1","type":"Color temperature light","uniqueid":"00:17:88:01:03:9f:38:ad-0b"},"e":"changed","id":"16","r":"lights","t":"event","uniqueid":"00:17:88:01:03:9f:38:ad-0b"} (ret = 403)
07:19:20:300 read attributes of 0x00178801039F38AD cluster: 0x0000: [ 07:19:20:301 0x4000 07:19:20:301 ]
07:19:20:302 add task 3482293 type 19 to 0x00178801039F38AD cluster 0x0000 req.id 244
07:19:20:302 Poll APS request 244 to 0x00178801039F38AD cluster: 0x0000
07:19:20:407 Poll APS confirm 244 status: 0x00
07:19:20:408 Erase task req-id: 244, type: 19 zcl seqno: 197 send time 0, profileId: 0x0104, clusterId: 0x0000
07:19:20:411 read attributes of 0x00178801039F38AD cluster: 0x0008: [ 07:19:20:412 0x0000 07:19:20:412 ]
07:19:20:413 add task 3482295 type 19 to 0x00178801039F38AD cluster 0x0008 req.id 246
07:19:20:413 Poll APS request 246 to 0x00178801039F38AD cluster: 0x0008
07:19:20:418 Node data 0x00178801039f38ad profileId: 0x0104, clusterId: 0x0000
07:19:20:419 0x00178801039F38AD: update ZCL value 0x0B/0x0000/0x4000 after 0 s
07:19:20:568 Websocket 172.30.32.1:51432 send message: {"attr":{"colorcapabilities":16,"ctmax":454,"ctmin":153,"id":"16","lastannounced":"2022-09-11T18:37:06Z","lastseen":"2022-10-21T05:19Z","manufacturername":"Philips","modelid":"LTW012","name":"Wohnzimmer Stehlampe oben","swversion":"1.88.1","type":"Color temperature light","uniqueid":"00:17:88:01:03:9f:38:ad-0b"},"e":"changed","id":"16","r":"lights","t":"event","uniqueid":"00:17:88:01:03:9f:38:ad-0b"} (ret = 403)
07:19:21:023 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":32,"delay":0,"ledindication":false,"on":true,"reachable":true,"sensitivity":2,"sensitivitymax":2,"usertest":false},"e":"changed","id":"27","r":"sensors","t":"event","uniqueid":"00:17:88:01:04:b6:16:9e-02-0406"} (ret = 246)
07:19:21:025 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":32,"ledindication":false,"on":true,"reachable":true,"tholddark":10881,"tholdoffset":7000,"usertest":false},"e":"changed","id":"29","r":"sensors","t":"event","uniqueid":"00:17:88:01:04:b6:16:9e-02-0400"} (ret = 238)
07:19:21:026 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":32,"ledindication":false,"offset":0,"on":true,"reachable":true,"usertest":false},"e":"changed","id":"28","r":"sensors","t":"event","uniqueid":"00:17:88:01:04:b6:16:9e-02-0402"} (ret = 212)
07:19:21:050 rule event /config/localtime: 07:19:19.630 -> 07:19:21.033 (1403ms)
07:19:21:502 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":51,"delay":0,"ledindication":false,"on":true,"reachable":true,"sensitivity":2,"sensitivitymax":2,"usertest":false},"e":"changed","id":"50","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:89:a3-02-0406"} (ret = 246)
07:19:21:504 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":51,"ledindication":false,"on":true,"reachable":true,"tholddark":19515,"tholdoffset":7000,"usertest":false},"e":"changed","id":"52","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:89:a3-02-0400"} (ret = 238)
07:19:21:505 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":51,"ledindication":false,"offset":0,"on":true,"reachable":true,"usertest":false},"e":"changed","id":"51","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:89:a3-02-0402"} (ret = 212)
07:19:21:969 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":24,"delay":0,"ledindication":false,"on":true,"reachable":true,"sensitivity":2,"sensitivitymax":2,"usertest":false},"e":"changed","id":"47","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:92:b9-02-0406"} (ret = 246)
07:19:21:971 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":24,"ledindication":false,"on":true,"reachable":true,"tholddark":17427,"tholdoffset":7000,"usertest":false},"e":"changed","id":"49","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:92:b9-02-0400"} (ret = 238)
07:19:21:972 Websocket 172.30.32.1:51432 send message: {"config":{"alert":"none","battery":24,"ledindication":false,"offset":0,"on":true,"reachable":true,"usertest":false},"e":"changed","id":"48","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:28:92:b9-02-0402"} (ret = 212)
07:19:21:981 Skip idle timer callback, too early: elapsed 947 msec
07:19:22:460 [INFO] - No button map for: ZHEMI101, unicast to: 0x0000, endpoint: 0x02, cluster: 0x0702, command: 0x0A, payload: 000025FF5B0900000000042A3D020000021800000125FFFFFFFFFFFF020125FFFFFFFFFFFF, zclSeq: 132
07:19:22:461 ZCL attribute report 0x0015BC001B022144 for cluster: 0x0702, ep: 0x02, frame control: 0x18, mfcode: 0x0000
07:19:22:461 payload: 000025ff5b0900000000042a3d020000021800000125ffffffffffff020125ffffffffffff
07:19:22:462 Websocket 172.30.32.1:51432 send message: {"attr":{"id":"229","lastannounced":"2022-10-20T02:10:35Z","lastseen":"2022-10-21T05:19Z","manufacturername":"Develco Products A/S","modelid":"ZHEMI101","name":"Consumption 229","swversion":"3.3.3","type":"ZHAConsumption","uniqueid":"00:15:bc:00:1b:02:21:44-02-0702"},"e":"changed","id":"229","r":"sensors","t":"event","uniqueid":"00:15:bc:00:1b:02:21:44-02-0702"} (ret = 364)
07:19:22:463 Websocket 172.30.32.1:51432 send message: {"e":"changed","id":"229","r":"sensors","state":{"consumption":613,"lastupdated":"2022-10-21T05:19:22.161","lowbattery":false,"power":573},"t":"event","uniqueid":"00:15:bc:00:1b:02:21:44-02-0702"} (ret = 196)
07:19:22:494 Poll APS confirm 246 status: 0x00
07:19:22:495 Erase task req-id: 246, type: 19 zcl seqno: 198 send time 1, profileId: 0x0104, clusterId: 0x0008
07:19:22:509 read attributes of 0x00178801039F38AD cluster: 0x0300: [ 07:19:22:510 0x0007 07:19:22:510 0x0008 07:19:22:511 0x4001 07:19:22:511 ]
07:19:22:511 add task 3482300 type 19 to 0x00178801039F38AD cluster 0x0300 req.id 4
07:19:22:512 Poll APS request 4 to 0x00178801039F38AD cluster: 0x0300
07:19:22:532 Node data 0x00178801039f38ad profileId: 0x0104, clusterId: 0x0008
07:19:22:532 0x00178801039F38AD: update ZCL value 0x0B/0x0008/0x0000 after 0 s
07:19:22:713 ZCL attribute report 0x00178801032BC8BB for cluster: 0x0400, ep: 0x02, frame control: 0x08, mfcode: 0x0000
07:19:22:714 payload: 0000210f24
07:19:22:715 Websocket 172.30.32.1:51432 send message: {"attr":{"id":"66","lastannounced":"2022-10-20T14:17:32Z","lastseen":"2022-10-21T05:19Z","manufacturername":"Philips","modelid":"SML001","name":"Bewegungsmelder Bad Tür","swversion":"6.1.1.27575","type":"ZHAPresence","uniqueid":"00:17:88:01:03:2b:c8:bb-02-0406"},"e":"changed","id":"66","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:2b:c8:bb-02-0406"} (ret = 359)
07:19:22:716 Websocket 172.30.32.1:51432 send message: {"attr":{"id":"68","lastannounced":"2022-10-20T14:17:32Z","lastseen":"2022-10-21T05:19Z","manufacturername":"Philips","modelid":"SML001","name":"Bewegungsmelder Bad Tür","swversion":"6.1.1.27575","type":"ZHALightLevel","uniqueid":"00:17:88:01:03:2b:c8:bb-02-0400"},"e":"changed","id":"68","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:2b:c8:bb-02-0400"} (ret = 361)
07:19:22:717 Websocket 172.30.32.1:51432 send message: {"e":"changed","id":"68","r":"sensors","state":{"dark":true,"daylight":false,"lastupdated":"2022-10-21T05:19:22.703","lightlevel":9231,"lux":8},"t":"event","uniqueid":"00:17:88:01:03:2b:c8:bb-02-0400"} (ret = 201)
07:19:22:719 Websocket 172.30.32.1:51432 send message: {"attr":{"id":"67","lastannounced":"2022-10-20T14:17:32Z","lastseen":"2022-10-21T05:19Z","manufacturername":"Philips","modelid":"SML001","name":"Bewegungsmelder Bad Tür","swversion":"6.1.1.27575","type":"ZHATemperature","uniqueid":"00:17:88:01:03:2b:c8:bb-02-0402"},"e":"changed","id":"67","r":"sensors","t":"event","uniqueid":"00:17:88:01:03:2b:c8:bb-02-0402"} (ret = 362)
hope you can see something.
i will not restart the addon until advised to.
thx
