Do you think deconz can be able to control this kind of product ?
It seems to be ok with zigbee2MQTT.
Regards ,
Regards ,
Unfortunately there are no entries here for the device with the designation HS2IRC. If you own the device, you can support the compatibility work with the help of screenshots as described here.
My question concerns the possibility for deCONZ to support infrared remote controls that can be controlled via Zigbee. I don’t see this type of device in the available elements. If so, I’ll try to find one and declare the device. However, this remote must also be able to learn the signals.
I made a github issue : HEIMAN IR control HS2IRC · Issue #7814 · dresden-elektronik/deconz-rest-plugin · GitHub
