Xiaomi Mi Smart Plug connection issues
My Xiaomi Mi Smart Plug loses connection after a certain time. Even over night where the plug is turned off I can see that it loses for several hours the connection.
Is that currently a common issue with latest deCONZ version?
Screenshot:
deCONZ logs:
15:28:05:206 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 163 seconds ago
15:28:08:085 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 166 seconds ago
15:28:10:965 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 169 seconds ago
15:28:13:845 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 171 seconds ago
15:28:16:725 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 174 seconds ago
15:28:19:606 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 177 seconds ago
15:28:22:485 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 180 seconds ago
15:28:25:365 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 183 seconds ago
15:28:28:246 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 186 seconds ago
15:28:31:126 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 189 seconds ago
15:28:34:005 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 192 seconds ago
15:28:36:886 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 195 seconds ago
15:28:39:234 Device TTL 4919 s flags: 0x7
15:28:39:766 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 197 seconds ago
15:29:39:232 Device TTL 4859 s flags: 0x7
15:30:39:231 Device TTL 4799 s flags: 0x7
15:30:55:126 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 333 seconds ago
15:30:58:006 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 336 seconds ago
15:31:00:885 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 339 seconds ago
15:31:02:226 GW firmware version: 0x26660700
15:31:02:226 GW firmware version is up to date: 0x26660700
15:31:03:765 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 341 seconds ago
15:31:06:646 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 344 seconds ago
15:31:09:525 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 347 seconds ago
15:31:12:405 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 350 seconds ago
15:31:15:286 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 353 seconds ago
15:31:18:166 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 356 seconds ago
15:31:21:045 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 359 seconds ago
15:31:23:925 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 362 seconds ago
15:31:26:805 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 364 seconds ago
15:31:29:686 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 367 seconds ago
15:31:32:566 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 370 seconds ago
15:31:35:445 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 373 seconds ago
15:31:38:326 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 376 seconds ago
15:31:39:233 Device TTL 4739 s flags: 0x7
15:31:41:205 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 379 seconds ago
15:31:44:085 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 382 seconds ago
15:31:46:965 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 385 seconds ago
15:31:49:846 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 387 seconds ago
15:31:51:098 LightNode 1: Justin Station updated
15:31:51:101 ZCL attribute report 0x04CF8CDF3C8A38B7 for cluster: 0x000C, ep: 0x15, frame control: 0x18, mfcode: 0x0000
15:31:51:845 reuse dead link (dead link container size now 0)
15:31:58:168 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:32:00:871 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:32:03:475 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:32:06:164 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:32:08:871 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:32:08:872 max transmit errors for node 0x04CF8CDF3C8A38B7, last seen by neighbors 1 s
15:32:11:474 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:32:11:475 max transmit errors for node 0x04CF8CDF3C8A38B7, last seen by neighbors 0 s
15:32:12:510 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:32:12:512 max transmit errors for node 0x04CF8CDF3C8A38B7, last seen by neighbors 2 s
15:32:12:769 max transmit errors for node 0x04CF8CDF3C8A38B7, last seen by neighbors 2 s
15:32:14:174 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:32:14:176 max transmit errors for node 0x04CF8CDF3C8A38B7, last seen by neighbors 0 s
15:32:14:566 0x9320 seems to be a zombie recv errors 10
15:32:14:568 Node zombie state changed 0x04cf8cdf3c8a38b7
15:32:14:569 SensorNode id: 3 (Consumption 3) no longer available
15:32:14:573 SensorNode id: 2 (Power 2) no longer available
15:32:16:245 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 19 seconds ago
15:32:19:125 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 22 seconds ago
15:32:22:005 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 25 seconds ago
15:32:24:886 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 28 seconds ago
15:32:27:765 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 30 seconds ago
15:32:30:646 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 33 seconds ago
15:32:33:525 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 36 seconds ago
15:32:36:406 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 39 seconds ago
15:32:39:234 Device TTL 4678 s flags: 0x7
15:32:39:286 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 42 seconds ago
15:32:42:165 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 45 seconds ago
15:32:45:046 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 48 seconds ago
15:32:47:925 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 51 seconds ago
15:32:50:805 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 53 seconds ago
15:32:53:686 discovery for zombie 0x04cf8cdf3c8a38b7 dropped, last try was 56 seconds ago
15:33:39:234 Device TTL 4618 s flags: 0x7
15:34:32:409 LightNode 1: Justin Station updated
15:34:32:411 ZCL attribute report 0x04CF8CDF3C8A38B7 for cluster: 0x000C, ep: 0x15, frame control: 0x18, mfcode: 0x0000
15:34:33:467 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:34:36:169 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:34:38:868 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:34:39:233 Device TTL 4558 s flags: 0x7
15:34:41:474 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:34:44:172 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:34:46:865 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:34:46:866 max transmit errors for node 0x04CF8CDF3C8A38B7, last seen by neighbors 113 s
15:34:49:468 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:34:49:470 max transmit errors for node 0x04CF8CDF3C8A38B7, last seen by neighbors 116 s
15:34:52:174 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:34:52:175 max transmit errors for node 0x04CF8CDF3C8A38B7, last seen by neighbors 118 s
15:34:53:767 0x04CF8CDF3C8A38B7 error APSDE-DATA.confirm: 0xE9 on task
15:34:53:768 max transmit errors for node 0x04CF8CDF3C8A38B7, last seen by neighbors 120 s
15:34:54:070 max transmit errors for node 0x04CF8CDF3C8A38B7, last seen by neighbors 120 s
15:34:54:406 0x9320 seems to be a zombie recv errors 10
15:34:54:407 Node zombie state changed 0x04cf8cdf3c8a38b7
15:34:54:408 SensorNode id: 3 (Consumption 3) no longer available
15:34:54:409 SensorNode id: 2 (Power 2) no longer available
15:35:02:226 GW firmware version: 0x26660700
15:35:02:227 GW firmware version is up to date: 0x26660700
15:35:39:232 Device TTL 4498 s flags: 0x7
15:36:39:232 Device TTL 4438 s flags: 0x7
My Setup:
  • Host system: Raspberry Pi 4
  • Running method: Home Assistent deCONZ Add-on
  • Firmware version: 26660700
  • deCONZ version: 2.12.06
  • Device: ConBee II
  • Is there any other USB or serial devices connected to the host system? If so: SSD
Can you add some logs with info, INFO_L2, ERROR, ERROR_L2, APS, APS_L2?
And also a screen of your deconz gui
Do you know from where I can get those logs?
I saw the real-time output in deCONZ itself but was not able to copy and paste it out of it
There’s a post on the forum.
Screenshot:
I’m currently starting with my zigbee network - that’s why I only have one devide :slight_smile:
Logs:
20:36:13:396 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:14:133 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:14:134 Poll ZHAPower sensor node Power 4
20:36:14:226 Idle timer triggered
20:36:14:228 don’t create binding for attribute reporting of sensor Power 4
20:36:14:230 Force binding of attribute reporting for node Power 4
20:36:14:394 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:15:131 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:15:133 Poll light node Justin-Station
20:36:15:180 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:15:226 Idle timer triggered
20:36:15:227 don’t create binding for attribute reporting of sensor Power 4
20:36:15:229 Force binding of attribute reporting for node Power 4
20:36:15:381 APS-DATA.request id: 77, addrmode: 0x03, addr: 0x00212effff07897f, profile: 0x0000, cluster: 0x0031, ep: 0x00 → 0x00 queue: 0 len: 2 tx.options 0x00
20:36:15:393 APS-DATA.confirm id: 77, status: 0x00 SUCCESS
20:36:15:395 APS-DATA.confirm request id: 77 → confirmed, timeout 103121157
20:36:15:404 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 117, rssi: 32
20:36:15:406 asdu: d7000100017f8907ffff2e2100b7388a3cdf8ccf044110250101a9
20:36:15:406 APS-DATA.indication request id: 77 → finished
20:36:15:407 APS-DATA.request id: 77 erase from queue
20:36:15:407 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
20:36:16:127 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:16:129 Poll ZHAConsumption sensor node Consumption 5
20:36:16:226 Idle timer triggered
20:36:16:228 don’t create binding for attribute reporting of sensor Power 4
20:36:16:229 Force binding of attribute reporting for node Power 4
20:36:16:386 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:17:125 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:17:126 Poll ZHAPower sensor node Power 4
20:36:17:226 Idle timer triggered
20:36:17:228 don’t create binding for attribute reporting of sensor Power 4
20:36:17:230 Force binding of attribute reporting for node Power 4
20:36:17:385 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:18:123 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:18:124 Poll light node Justin-Station
20:36:18:175 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:18:226 Idle timer triggered
20:36:18:227 don’t create binding for attribute reporting of sensor Power 4
20:36:18:228 Force binding of attribute reporting for node Power 4
20:36:19:122 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:19:123 Poll ZHAConsumption sensor node Consumption 5
20:36:19:225 Idle timer triggered
20:36:19:227 don’t create binding for attribute reporting of sensor Power 4
20:36:19:228 Force binding of attribute reporting for node Power 4
20:36:19:365 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:20:081 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:20:082 Poll ZHAPower sensor node Power 4
20:36:20:226 Idle timer triggered
20:36:20:228 don’t create binding for attribute reporting of sensor Power 4
20:36:20:229 Force binding of attribute reporting for node Power 4
20:36:20:325 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:21:051 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:21:052 Poll light node Justin-Station
20:36:21:103 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:21:225 Idle timer triggered
20:36:21:228 don’t create binding for attribute reporting of sensor Power 4
20:36:21:230 Force binding of attribute reporting for node Power 4
20:36:22:049 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:22:051 Poll ZHAConsumption sensor node Consumption 5
20:36:22:226 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
20:36:22:228 Idle timer triggered
20:36:22:229 don’t create binding for attribute reporting of sensor Power 4
20:36:22:230 Force binding of attribute reporting for node Power 4
20:36:22:309 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:23:047 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:23:048 Poll ZHAPower sensor node Power 4
20:36:23:225 Idle timer triggered
20:36:23:227 don’t create binding for attribute reporting of sensor Power 4
20:36:23:228 Force binding of attribute reporting for node Power 4
20:36:23:306 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:24:044 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:24:045 Poll light node Justin-Station
20:36:24:093 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:24:226 Idle timer triggered
20:36:24:227 don’t create binding for attribute reporting of sensor Power 4
20:36:24:228 Force binding of attribute reporting for node Power 4
20:36:25:039 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:25:041 Poll ZHAConsumption sensor node Consumption 5
20:36:25:225 Idle timer triggered
20:36:25:227 don’t create binding for attribute reporting of sensor Power 4
20:36:25:228 Force binding of attribute reporting for node Power 4
20:36:25:298 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:26:036 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:26:037 Poll ZHAPower sensor node Power 4
20:36:26:226 Idle timer triggered
20:36:26:228 don’t create binding for attribute reporting of sensor Power 4
20:36:26:230 Force binding of attribute reporting for node Power 4
20:36:26:294 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:27:033 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:27:035 Poll light node Justin-Station
20:36:27:081 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:27:226 Idle timer triggered
20:36:27:227 don’t create binding for attribute reporting of sensor Power 4
20:36:27:228 Force binding of attribute reporting for node Power 4
20:36:28:028 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:28:029 Poll ZHAConsumption sensor node Consumption 5
20:36:28:226 Idle timer triggered
20:36:28:228 don’t create binding for attribute reporting of sensor Power 4
20:36:28:229 Force binding of attribute reporting for node Power 4
20:36:28:287 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:29:024 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:29:025 Poll ZHAPower sensor node Power 4
20:36:29:226 Idle timer triggered
20:36:29:227 don’t create binding for attribute reporting of sensor Power 4
20:36:29:229 Force binding of attribute reporting for node Power 4
20:36:29:286 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:30:023 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:30:024 Poll light node Justin-Station
20:36:30:075 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:30:225 Idle timer triggered
20:36:30:227 don’t create binding for attribute reporting of sensor Power 4
20:36:30:229 Force binding of attribute reporting for node Power 4
20:36:30:742 APS-DATA.request id: 162, addrmode: 0x03, addr: 0x04cf8cdf3c8a38b7, profile: 0x0000, cluster: 0x0031, ep: 0x00 → 0x00 queue: 0 len: 2 tx.options 0x00
20:36:30:764 APS-DATA.confirm id: 162, status: 0x00 SUCCESS
20:36:30:765 APS-DATA.confirm request id: 162 → confirmed, timeout 103136518
20:36:30:776 APS-DATA.indication srcAddr: 0x1041, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 159, rssi: -74
20:36:30:777 asdu: ed000100017f8907ffff2e21007f8907ffff2e210000000402003d
20:36:30:778 APS-DATA.indication request id: 162 → finished
20:36:30:778 APS-DATA.request id: 162 erase from queue
20:36:30:779 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x1041
20:36:31:022 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:31:024 Poll ZHAConsumption sensor node Consumption 5
20:36:31:225 Idle timer triggered
20:36:31:227 don’t create binding for attribute reporting of sensor Power 4
20:36:31:227 Force binding of attribute reporting for node Power 4
20:36:31:266 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:31:932 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:31:934 Poll ZHAPower sensor node Power 4
20:36:32:189 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:32:226 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
20:36:32:227 Idle timer triggered
20:36:32:228 don’t create binding for attribute reporting of sensor Power 4
20:36:32:231 Force binding of attribute reporting for node Power 4
20:36:32:876 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:32:878 Poll light node Justin-Station
20:36:32:926 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:33:226 Idle timer triggered
20:36:33:228 don’t create binding for attribute reporting of sensor Power 4
20:36:33:229 Force binding of attribute reporting for node Power 4
20:36:33:801 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:33:803 Poll ZHAConsumption sensor node Consumption 5
20:36:34:044 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:34:226 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:34:227 Poll ZHAPower sensor node Power 4
20:36:34:228 Idle timer triggered
20:36:34:230 don’t create binding for attribute reporting of sensor Power 4
20:36:34:231 Force binding of attribute reporting for node Power 4
20:36:34:433 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:35:150 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:35:152 Poll light node Justin-Station
20:36:35:202 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:35:225 Idle timer triggered
20:36:35:226 don’t create binding for attribute reporting of sensor Power 4
20:36:35:227 Force binding of attribute reporting for node Power 4
20:36:36:150 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:36:152 Poll ZHAConsumption sensor node Consumption 5
20:36:36:225 Idle timer triggered
20:36:36:227 don’t create binding for attribute reporting of sensor Power 4
20:36:36:228 Force binding of attribute reporting for node Power 4
20:36:36:414 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:37:151 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:37:152 Poll ZHAPower sensor node Power 4
20:36:37:226 Idle timer triggered
20:36:37:227 don’t create binding for attribute reporting of sensor Power 4
20:36:37:229 Force binding of attribute reporting for node Power 4
20:36:37:414 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:38:150 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:38:152 Poll light node Justin-Station
20:36:38:202 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:38:225 Idle timer triggered
20:36:38:227 don’t create binding for attribute reporting of sensor Power 4
20:36:38:227 Force binding of attribute reporting for node Power 4
20:36:39:149 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:39:150 Poll ZHAConsumption sensor node Consumption 5
20:36:39:226 Idle timer triggered
20:36:39:227 don’t create binding for attribute reporting of sensor Power 4
20:36:39:227 Force binding of attribute reporting for node Power 4
20:36:39:238 Master: read param with arg 0x19
20:36:39:248 Device TTL 6239 s flags: 0x7
20:36:39:408 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:40:146 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:40:148 Poll ZHAPower sensor node Power 4
20:36:40:225 Idle timer triggered
20:36:40:227 don’t create binding for attribute reporting of sensor Power 4
20:36:40:229 Force binding of attribute reporting for node Power 4
20:36:40:406 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:41:143 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:41:145 Poll light node Justin-Station
20:36:41:193 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:41:225 Idle timer triggered
20:36:41:226 don’t create binding for attribute reporting of sensor Power 4
20:36:41:227 Force binding of attribute reporting for node Power 4
20:36:42:141 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:42:143 Poll ZHAConsumption sensor node Consumption 5
20:36:42:226 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
20:36:42:228 Idle timer triggered
20:36:42:229 don’t create binding for attribute reporting of sensor Power 4
20:36:42:230 Force binding of attribute reporting for node Power 4
20:36:42:399 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:43:137 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:43:139 Poll ZHAPower sensor node Power 4
20:36:43:226 Idle timer triggered
20:36:43:228 don’t create binding for attribute reporting of sensor Power 4
20:36:43:229 Force binding of attribute reporting for node Power 4
20:36:43:396 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:44:132 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:44:134 Poll light node Justin-Station
20:36:44:180 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:44:226 DB save zll database items 0x00000001
20:36:44:228 DB sql exec REPLACE INTO nodes (id, state, mac, name, groups, endpoint, modelid, manufacturername, swbuildid, ritems) VALUES (‘2’, ‘normal’, ‘00:21:2e:ff:ff:07:89:7f-01’, ‘Configuration tool 2’, ‘65520’, ‘1’, ‘ConBee II’, ‘dresden elektronik’, ‘0x26660700’, ‘{“attr/id”:“2”,“attr/lastannounced”:null,“attr/lastseen”:“2021-11-13T19:35Z”,“attr/manufacturername”:“dresden elektronik”,“attr/modelid”:“ConBee II”,“attr/name”:“Configuration tool 2”,“attr/swversion”:“0x26660700”,“attr/type”:“Configuration tool”,“attr/uniqueid”:“00:21:2e:ff:ff:07:89:7f-01”,“state/reachable”:true}’)
20:36:44:232 DB sql exec REPLACE INTO nodes (id, state, mac, name, groups, endpoint, modelid, manufacturername, swbuildid, ritems) VALUES (‘3’, ‘normal’, ‘04:cf:8c:df:3c:8a:38:b7-01’, ‘Justin-Station’, ‘65520,1’, ‘1’, ‘lumi.plug.mmeu01’, ‘LUMI’, ‘09-06-2019’, ‘{“attr/id”:“3”,“attr/lastannounced”:null,“attr/lastseen”:“2021-11-13T19:36Z”,“attr/manufacturername”:“LUMI”,“attr/modelid”:“lumi.plug.mmeu01”,“attr/name”:“Justin-Station”,“attr/swversion”:“09-06-2019”,“attr/type”:“Smart plug”,“attr/uniqueid”:“04:cf:8c:df:3c:8a:38:b7-01”,“state/alert”:null,“state/on”:true,“state/reachable”:true}’)
20:36:44:243 DB saved in 16 ms
20:36:44:244 Idle timer triggered
20:36:44:244 don’t create binding for attribute reporting of sensor Power 4
20:36:44:245 Force binding of attribute reporting for node Power 4
20:36:45:128 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:45:130 Poll ZHAConsumption sensor node Consumption 5
20:36:45:226 Idle timer triggered
20:36:45:227 don’t create binding for attribute reporting of sensor Power 4
20:36:45:227 Force binding of attribute reporting for node Power 4
20:36:45:387 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:46:102 APS-DATA.request id: 246, addrmode: 0x03, addr: 0x00212effff07897f, profile: 0x0000, cluster: 0x0031, ep: 0x00 → 0x00 queue: 0 len: 2 tx.options 0x00
20:36:46:115 APS-DATA.confirm id: 246, status: 0x00 SUCCESS
20:36:46:116 APS-DATA.confirm request id: 246 → confirmed, timeout 103151878
20:36:46:124 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:46:125 Poll ZHAPower sensor node Power 4
20:36:46:131 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 195, rssi: 0
20:36:46:133 asdu: 03000100017f8907ffff2e2100b7388a3cdf8ccf044110250101a5
20:36:46:133 APS-DATA.indication request id: 246 → finished
20:36:46:134 APS-DATA.request id: 246 erase from queue
20:36:46:135 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
20:36:46:146 Websocket 172.30.32.1:57682 send message: {“attr”:{“id”:“2”,“lastannounced”:null,“lastseen”:“2021-11-13T19:36Z”,“manufacturername”:“dresden elektronik”,“modelid”:“ConBee II”,“name”:“Configuration tool 2”,“swversion”:“0x26660700”,“type”:“Configuration tool”,“uniqueid”:“00:21:2e:ff:ff:07:89:7f-01”},“e”:“changed”,“id”:“2”,“r”:“lights”,“t”:“event”,“uniqueid”:“00:21:2e:ff:ff:07:89:7f-01”} (ret = 344)
20:36:46:226 Idle timer triggered
20:36:46:228 don’t create binding for attribute reporting of sensor Power 4
20:36:46:230 Force binding of attribute reporting for node Power 4
20:36:46:387 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:47:125 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:47:126 Poll light node Justin-Station
20:36:47:176 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:47:226 Idle timer triggered
20:36:47:227 don’t create binding for attribute reporting of sensor Power 4
20:36:47:228 Force binding of attribute reporting for node Power 4
20:36:48:122 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:48:124 Poll ZHAConsumption sensor node Consumption 5
20:36:48:225 Idle timer triggered
20:36:48:226 don’t create binding for attribute reporting of sensor Power 4
20:36:48:227 Force binding of attribute reporting for node Power 4
20:36:48:385 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:49:122 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:49:123 Poll ZHAPower sensor node Power 4
20:36:49:226 Idle timer triggered
20:36:49:227 don’t create binding for attribute reporting of sensor Power 4
20:36:49:229 Force binding of attribute reporting for node Power 4
20:36:49:386 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:50:126 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:50:127 Poll light node Justin-Station
20:36:50:176 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:50:225 Idle timer triggered
20:36:50:227 don’t create binding for attribute reporting of sensor Power 4
20:36:50:228 Force binding of attribute reporting for node Power 4
20:36:51:124 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:51:126 Poll ZHAConsumption sensor node Consumption 5
20:36:51:225 Idle timer triggered
20:36:51:227 don’t create binding for attribute reporting of sensor Power 4
20:36:51:228 Force binding of attribute reporting for node Power 4
20:36:51:385 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:52:123 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:52:125 Poll ZHAPower sensor node Power 4
20:36:52:226 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
20:36:52:228 Idle timer triggered
20:36:52:229 don’t create binding for attribute reporting of sensor Power 4
20:36:52:230 Force binding of attribute reporting for node Power 4
20:36:52:385 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:53:122 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:53:123 Poll light node Justin-Station
20:36:53:174 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:53:225 Idle timer triggered
20:36:53:227 don’t create binding for attribute reporting of sensor Power 4
20:36:53:228 Force binding of attribute reporting for node Power 4
20:36:54:120 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:54:122 Poll ZHAConsumption sensor node Consumption 5
20:36:54:225 Idle timer triggered
20:36:54:227 don’t create binding for attribute reporting of sensor Power 4
20:36:54:228 Force binding of attribute reporting for node Power 4
20:36:54:364 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:55:080 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:55:082 Poll ZHAPower sensor node Power 4
20:36:55:226 Idle timer triggered
20:36:55:227 don’t create binding for attribute reporting of sensor Power 4
20:36:55:227 Force binding of attribute reporting for node Power 4
20:36:55:326 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:56:050 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:56:052 Poll light node Justin-Station
20:36:56:103 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:56:225 Idle timer triggered
20:36:56:227 don’t create binding for attribute reporting of sensor Power 4
20:36:56:228 Force binding of attribute reporting for node Power 4
20:36:57:050 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:36:57:052 Poll ZHAConsumption sensor node Consumption 5
20:36:57:225 Idle timer triggered
20:36:57:227 don’t create binding for attribute reporting of sensor Power 4
20:36:57:229 Force binding of attribute reporting for node Power 4
20:36:57:315 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:36:58:050 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:36:58:052 Poll ZHAPower sensor node Power 4
20:36:58:226 Idle timer triggered
20:36:58:228 don’t create binding for attribute reporting of sensor Power 4
20:36:58:229 Force binding of attribute reporting for node Power 4
20:36:58:312 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:36:59:050 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:36:59:051 Poll light node Justin-Station
20:36:59:097 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:36:59:226 sql exec SELECT conf FROM zbconf ORDER BY rowid desc limit 1
20:36:59:228 Idle timer triggered
20:36:59:229 don’t create binding for attribute reporting of sensor Power 4
20:36:59:230 Force binding of attribute reporting for node Power 4
20:37:00:046 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:37:00:048 Poll ZHAConsumption sensor node Consumption 5
20:37:00:226 Idle timer triggered
20:37:00:227 don’t create binding for attribute reporting of sensor Power 4
20:37:00:229 Force binding of attribute reporting for node Power 4
20:37:00:304 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:37:01:041 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:37:01:042 Poll ZHAPower sensor node Power 4
20:37:01:226 Idle timer triggered
20:37:01:228 don’t create binding for attribute reporting of sensor Power 4
20:37:01:230 Force binding of attribute reporting for node Power 4
20:37:01:300 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:37:01:461 APS-DATA.request id: 75, addrmode: 0x03, addr: 0x04cf8cdf3c8a38b7, profile: 0x0000, cluster: 0x0031, ep: 0x00 → 0x00 queue: 0 len: 2 tx.options 0x00
20:37:01:482 APS-DATA.confirm id: 75, status: 0x00 SUCCESS
20:37:01:483 APS-DATA.confirm request id: 75 → confirmed, timeout 103167238
20:37:01:515 APS-DATA.indication srcAddr: 0x1041, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 175, rssi: -72
20:37:01:517 asdu: 1a000100017f8907ffff2e21007f8907ffff2e210000000402003d
20:37:01:519 APS-DATA.indication request id: 75 → finished
20:37:01:520 APS-DATA.request id: 75 erase from queue
20:37:01:521 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x1041
20:37:01:535 Websocket 172.30.32.1:57682 send message: {“attr”:{“id”:“3”,“lastannounced”:null,“lastseen”:“2021-11-13T19:37Z”,“manufacturername”:“LUMI”,“modelid”:“lumi.plug.mmeu01”,“name”:“Justin-Station”,“swversion”:“09-06-2019”,“type”:“Smart plug”,“uniqueid”:“04:cf:8c:df:3c:8a:38:b7-01”},“e”:“changed”,“id”:“3”,“r”:“lights”,“t”:“event”,“uniqueid”:“04:cf:8c:df:3c:8a:38:b7-01”} (ret = 323)
20:37:02:039 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:37:02:042 Poll light node Justin-Station
20:37:02:086 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:37:02:226 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
20:37:02:227 Idle timer triggered
20:37:02:228 don’t create binding for attribute reporting of sensor Power 4
20:37:02:229 Force binding of attribute reporting for node Power 4
20:37:03:034 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:37:03:036 Poll ZHAConsumption sensor node Consumption 5
20:37:03:225 Idle timer triggered
20:37:03:227 don’t create binding for attribute reporting of sensor Power 4
20:37:03:228 Force binding of attribute reporting for node Power 4
20:37:03:294 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:37:04:034 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:37:04:036 Poll ZHAPower sensor node Power 4
20:37:04:225 Idle timer triggered
20:37:04:227 don’t create binding for attribute reporting of sensor Power 4
20:37:04:228 Force binding of attribute reporting for node Power 4
20:37:04:294 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:37:05:031 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:37:05:032 Poll light node Justin-Station
20:37:05:078 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:37:05:225 Idle timer triggered
20:37:05:227 don’t create binding for attribute reporting of sensor Power 4
20:37:05:228 Force binding of attribute reporting for node Power 4
20:37:06:025 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:37:06:027 Poll ZHAConsumption sensor node Consumption 5
20:37:06:226 Idle timer triggered
20:37:06:228 don’t create binding for attribute reporting of sensor Power 4
20:37:06:230 Force binding of attribute reporting for node Power 4
20:37:06:285 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:37:07:023 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:37:07:024 Poll ZHAPower sensor node Power 4
20:37:07:226 Idle timer triggered
20:37:07:228 don’t create binding for attribute reporting of sensor Power 4
20:37:07:229 Force binding of attribute reporting for node Power 4
20:37:07:264 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:37:07:932 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:37:07:934 Poll light node Justin-Station
20:37:07:981 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:37:08:226 Idle timer triggered
20:37:08:227 don’t create binding for attribute reporting of sensor Power 4
20:37:08:229 Force binding of attribute reporting for node Power 4
20:37:08:877 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:37:08:880 Poll ZHAConsumption sensor node Consumption 5
20:37:09:125 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:37:09:225 Idle timer triggered
20:37:09:227 don’t create binding for attribute reporting of sensor Power 4
20:37:09:228 Force binding of attribute reporting for node Power 4
20:37:09:801 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:37:09:802 Poll ZHAPower sensor node Power 4
20:37:10:043 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:37:10:226 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:37:10:227 Poll light node Justin-Station
20:37:10:229 Idle timer triggered
20:37:10:230 don’t create binding for attribute reporting of sensor Power 4
20:37:10:231 Force binding of attribute reporting for node Power 4
20:37:10:244 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:37:11:152 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:37:11:153 Poll ZHAConsumption sensor node Consumption 5
20:37:11:225 Idle timer triggered
20:37:11:227 don’t create binding for attribute reporting of sensor Power 4
20:37:11:228 Force binding of attribute reporting for node Power 4
20:37:11:416 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:37:12:151 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:37:12:157 Poll light node Justin-Station
20:37:12:204 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:37:12:225 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
20:37:12:226 Idle timer triggered
20:37:12:227 don’t create binding for attribute reporting of sensor Power 4
20:37:12:228 Force binding of attribute reporting for node Power 4
20:37:13:151 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:37:13:152 Poll ZHAPower sensor node Power 4
20:37:13:225 Idle timer triggered
20:37:13:227 don’t create binding for attribute reporting of sensor Power 4
20:37:13:228 Force binding of attribute reporting for node Power 4
20:37:13:414 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:37:14:150 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:37:14:151 Poll ZHAConsumption sensor node Consumption 5
20:37:14:226 Idle timer triggered
20:37:14:227 don’t create binding for attribute reporting of sensor Power 4
20:37:14:229 Force binding of attribute reporting for node Power 4
20:37:14:412 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:37:15:149 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:37:15:151 Poll light node Justin-Station
20:37:15:196 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:37:15:226 Idle timer triggered
20:37:15:227 don’t create binding for attribute reporting of sensor Power 4
20:37:15:228 Force binding of attribute reporting for node Power 4
20:37:16:145 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:37:16:147 Poll ZHAPower sensor node Power 4
20:37:16:226 Idle timer triggered
20:37:16:227 don’t create binding for attribute reporting of sensor Power 4
20:37:16:227 Force binding of attribute reporting for node Power 4
20:37:16:405 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:37:16:822 APS-DATA.request id: 160, addrmode: 0x03, addr: 0x00212effff07897f, profile: 0x0000, cluster: 0x0031, ep: 0x00 → 0x00 queue: 0 len: 2 tx.options 0x00
20:37:16:837 APS-DATA.confirm id: 160, status: 0x00 SUCCESS
20:37:16:838 APS-DATA.confirm request id: 160 → confirmed, timeout 103182599
20:37:16:849 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 195, rssi: 0
20:37:16:851 asdu: 30000100017f8907ffff2e2100b7388a3cdf8ccf044110250101a8
20:37:16:853 APS-DATA.indication request id: 160 → finished
20:37:16:854 APS-DATA.request id: 160 erase from queue
20:37:16:854 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
20:37:17:142 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:37:17:143 Poll ZHAConsumption sensor node Consumption 5
20:37:17:225 Idle timer triggered
20:37:17:227 don’t create binding for attribute reporting of sensor Power 4
20:37:17:228 Force binding of attribute reporting for node Power 4
20:37:17:401 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:37:18:139 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:37:18:141 Poll light node Justin-Station
20:37:18:187 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:37:18:226 Idle timer triggered
20:37:18:227 don’t create binding for attribute reporting of sensor Power 4
20:37:18:228 Force binding of attribute reporting for node Power 4
20:37:19:135 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:37:19:137 Poll ZHAPower sensor node Power 4
20:37:19:225 Idle timer triggered
20:37:19:227 don’t create binding for attribute reporting of sensor Power 4
20:37:19:228 Force binding of attribute reporting for node Power 4
20:37:19:393 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:37:20:129 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:37:20:131 Poll ZHAConsumption sensor node Consumption 5
20:37:20:228 Idle timer triggered
20:37:20:230 don’t create binding for attribute reporting of sensor Power 4
20:37:20:231 Force binding of attribute reporting for node Power 4
20:37:20:389 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:37:21:127 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:37:21:128 Poll light node Justin-Station
20:37:21:175 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:37:21:225 Idle timer triggered
20:37:21:227 don’t create binding for attribute reporting of sensor Power 4
20:37:21:227 Force binding of attribute reporting for node Power 4
20:37:22:121 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:37:22:123 Poll ZHAPower sensor node Power 4
20:37:22:226 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
20:37:22:227 Idle timer triggered
20:37:22:228 don’t create binding for attribute reporting of sensor Power 4
20:37:22:229 Force binding of attribute reporting for node Power 4
20:37:22:365 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:37:23:081 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:37:23:083 Poll ZHAConsumption sensor node Consumption 5
20:37:23:225 Idle timer triggered
20:37:23:227 don’t create binding for attribute reporting of sensor Power 4
20:37:23:228 Force binding of attribute reporting for node Power 4
20:37:23:326 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
20:37:24:051 poll node 04:cf:8c:df:3c:8a:38:b7-01
20:37:24:052 Poll light node Justin-Station
20:37:24:103 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0006 dropped, values are fresh enough
20:37:24:225 Idle timer triggered
20:37:24:227 don’t create binding for attribute reporting of sensor Power 4
20:37:24:228 Force binding of attribute reporting for node Power 4
20:37:25:079 poll node 04:cf:8c:df:3c:8a:38:b7-15-000c
20:37:25:081 Poll ZHAPower sensor node Power 4
20:37:25:226 Idle timer triggered
20:37:25:227 don’t create binding for attribute reporting of sensor Power 4
20:37:25:228 Force binding of attribute reporting for node Power 4
20:37:25:326 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0B04 dropped, cluster doesn’t exist
20:37:26:051 poll node 04:cf:8c:df:3c:8a:38:b7-16-000c
20:37:26:052 Poll ZHAConsumption sensor node Consumption 5
20:37:26:225 Idle timer triggered
20:37:26:228 don’t create binding for attribute reporting of sensor Power 4
20:37:26:229 Force binding of attribute reporting for node Power 4
20:37:26:312 Poll APS request to 0x04CF8CDF3C8A38B7 cluster: 0x0702 dropped, cluster doesn’t exist
after I powered on my Xiaomi plug manually it is currently working - but I think if I turn it off it will look kinda different.
that is also what HA says:
@Swoop Can you say something useful on this?
Tldr;
The recommended conbee/raspbee firmware version to run the device is 0x26720700. If that was not the case while first pairing the device, the firmware should be updated and the devices reset and re-paired. Additionally, with the upcoming stable release, I added a respective DDF to hopefully force the device into some more sane behavior (I suspect the plug’s firmware to be buggy, as it behaves differently then all other devices).
