I have connected the three Aquara Smart Plug via the ConBee II (universal Zigbee USB-Gateway) on a RasPi4.
- ConBee II Firmware: 26780700
- deCONZ Version: 2.19.03 / 19.9.2022
Within Phoscon App/Webpage I only see the model and the manufacturer (=LUMI) as light. Under sensors or so I see nothing.
In IoBroker, I use the deConz ZigBee adapter in version 1.3.21, I see three entries:
- Light, to switch on or off, availability and light intensity
- Sensor-Consumption
- Sensor-Power
Switching on and off via Light-on works without any problems. I also recognize very quickly whether the device is available or not.
I only see no changes in Consumption and Power, or partly only with a long delay.
Power in watts used to be displayed but has not been for quite some time now. No matter what I have as a consumer, not even with a heater.
Current milli Ampere or voltage changes sometimes, but if then only with a delay of greater than 3-4 minutes. But if I look at the timestamps of the respective objects, all are not older than 3-5 seconds.
Now the plug is about 20 cm away from the gateway.
