I have a few of the Xiaomi light sensors lumi.sen_ill_mgl01. They work well, but the battery state is not shown in deCONZ (see picture). I wonder why, because in the API, battery level is reported correctly with 100% (also in Phoscon App). I thought the reason could be maybe the DDF which comes with the current deCONZ version because it uses Xiaomi special reporting, although there is a Power Configuration cluster available. I changed the DDF to use cluster 0001 instead and re-paired the device, but in deCONZ there is still no icon visible - in the API it works. Any idea what is going on here?
"battery": 100,
"reachable": true,
"tholddark": 12000,
"tholdoffset": 7000
"etag": "4dbd861e7605640c0650d27abc7c4f3b",
"lastannounced": null,
"lastseen": "2022-10-04T11:58Z",
"manufacturername": "XIAOMI",
"modelid": "lumi.sen_ill.mgl01",
"name": "Light Sensor Work",
"dark": false,
"daylight": true,
"lastupdated": "2022-10-04T11:56:30.045",
"lightlevel": 19191,
"lux": 82
"swversion": "0.0.0_0027",
"type": "ZHALightLevel",
"uniqueid": "54:ef:44:10:00:0c:3d:f3-01-0400"
