!!!!! READ THIS FIRST: https://forum.phoscon.de/t/read-me-device-request…-read-me/23/2 !!!!!!
## Device
- Product name: Scene Switch (Powered by Tuya)
- Manufacturer: _TZ3000_w8jwkczz
- Model identifier: TS0043
- Device type :
- Switch
Front:
Back:
## Screenshots
Required screenshots:
- Node Info panel
## Switch 01
### Basic
### Power Configuration
### On/Off
### OTAU (Grey)
### Time (Grey)
Shows nothing.
### On/Off (Grey)
## Switch 02
### On/Off
### On/Off (Grey)
## Switch 03
### On/Off
### On/Off (Grey)
## Attempt
I have attempted to imitate other code changes, such as this PR [here](https://github.com/dresden-elektronik/deconz-rest-plugin/pull/4756/files) and compiled, tested and prepared a commit [here](https://github.com/kvnnap/deconz-rest-plugin/commit/9e4d97cbf4cab1f5e0ca8b9244179f7254d3f657). The device buttons work. I see the correct codes when a call to the REST API is made. However, I still see 3 On/Off entries under Lights in Phoscon. The resulting json and screenshots are below:
Correct switch addition:
```json
"3": {
"battery": null,
"reachable": true
"etag": "7b783e20cf59c61f25ff3e2841af53a2",
"lastannounced": "2021-12-04T10:01:50Z",
"lastseen": "2021-12-04T10:01Z",
"manufacturername": "_TZ3000_w8jwkczz",
"mode": 1,
"modelid": "TS0043",
"name": "Switch",
"buttonevent": 3002,
"lastupdated": "2021-12-04T09:56:12.904"
"type": "ZHASwitch",
"uniqueid": "80:4b:50:ff:fe:06:9a:e6-01-0006"
Incorrect light additions:
```json
"8": {
"etag": "0f4db69999cf0585054066ba8287affb",
"hascolor": false,
"name": "On/Off light 8",
"alert": "none",
"on": false,
"reachable": true
"swversion": null,
"type": "On/Off light",
"uniqueid": "80:4b:50:ff:fe:06:9a:e6-01"
"9": {
"etag": "e3443691a63e2147e780d80e469dc850",
"hascolor": false,
"name": "On/Off light 9",
"alert": "none",
"on": false,
"reachable": true
"swversion": null,
"uniqueid": "80:4b:50:ff:fe:06:9a:e6-02"
"10": {
"etag": "0555947fec87e0ea2599a6ad5d17e405",
"hascolor": false,
"name": "On/Off light 10",
"alert": "none",
"on": false,
"reachable": true
"swversion": null,
"uniqueid": "80:4b:50:ff:fe:06:9a:e6-03"
## Environment and Other
The software runs on a Rasperry Pi 4b inside a docker container. To compile the change, the following Dockerfile was produced:
```dockerfile
FROM debian:10.11-slim
ARG MYUSER=deconz
RUN apt-get update && export DEBIAN_FRONTEND=noninteractive \
&& apt-get -y dist-upgrade \
&& apt-get -y install wget gnupg2 g++ make qtdeclarative5-dev \
&& wget -O - http://phoscon.de/apt/deconz.pub.key | apt-key add - \
&& echo "deb http://phoscon.de/apt/deconz $(cat /etc/os-release | grep -oP \
'(?<=VERSION_CODENAME\=).*')-beta main" > /etc/apt/sources.list.d/deconz.list \
&& apt-get update \
&& apt-get -y install deconz-dev \
&& useradd -ms /bin/bash $MYUSER \
&& apt-get -y install --no-install-recommends sudo \
&& echo $MYUSER ALL=\(root\) NOPASSWD:ALL > /etc/sudoers.d/$MYUSER \
&& chmod 0440 /etc/sudoers.d/$MYUSER
USER $MYUSER
WORKDIR /home/$MYUSER
and this Dockerfile was used to test the change after libde_rest_plugin.so was compiled:
```dockerfile
FROM deconzcommunity/deconz:latest
COPY libde_rest_plugin.so /usr/share/deCONZ/plugins
COPY button_maps.json /usr/share/deCONZ/devices
