Webserver unreachable after some time
Debian 13
Deconz 2.32.4-beta
Webserver port 80
When I restart deconz in systemctl I can reach the webserver without a problem and even commands via Alexa are executed instantly.
But after some time, maybe one hour, the webserver gets less and less reachable i.e. loading slowly until it doesn’t load at all anymore and showing “This is not the page you are looking for. The file /pwa/login2.html couldn’t be found.”
At this point Alexa voice commands are executed with some delay and with the response that the device is not reachable.
But I don’t know, if this is connected to the previous issue that 2.32.4-beta should have fixed.
I tried some more things:
Resetting the gateway in Phoscon didn’t seem to cause further drops of the webserver in 2 hours, but restoring my settings the problem reoccured.
Changing the port to 81 looked promising first, but the problem quickly came back after an hour.
But the strange thing is that at the moment (after 3 hours) the main page is working but the lights page isn’t found (The file /pwa/devices-lights.html couldn’t be found.)
The file /usr/share/deCONZ/webapp/pwa/devices-lights.html is there, so why can’t the webserver find it?
Can you check the cpu use ? to see if the application is not hanging ?
Or logs to see if something is “spamming” ?
Ok, I activated logging and tried to reach the webserver after 2 hours.
The logs are quite big (8MB) so I had to upload them:
https://www.xup.in/dl,20851514/log_deconz.txt/
Additionally I monitored the process with top and tried to reach the webserver again and control lights via Alexa:
top - 21:15:07 up  4:02,  2 users,  load average: 1,29, 1,08, 1,03
Tasks:   1 total,   1 running,   0 sleeping,   0 stopped,   0 zombie
%CPU(s):  9,5 us,  4,8 sy,  0,0 ni, 85,7 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Spch:  15866,8 total,   8068,7 free,   4086,0 used,   4873,1 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11780,8 avail Spch
    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
  11397 nuc       20   0 1038260 139472  70392 R 100,0   0,9  58:08.29 deCONZ
top - 21:15:10 up  4:02,  2 users,  load average: 1,34, 1,10, 1,04
%CPU(s): 10,1 us,  4,7 sy,  0,0 ni, 85,2 id,  0,0 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8050,8 free,   4103,9 used,   4873,2 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11762,8 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 101,0   0,9  58:11.32 deCONZ
top - 21:15:13 up  4:02,  2 users,  load average: 1,40, 1,11, 1,04
%CPU(s): 10,2 us,  4,5 sy,  0,0 ni, 85,0 id,  0,0 wa,  0,0 hi,  0,2 si,  0,0 st
MiB Spch:  15866,8 total,   8053,5 free,   4101,2 used,   4873,2 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11765,6 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 100,7   0,9  58:14.34 deCONZ
top - 21:15:16 up  4:02,  2 users,  load average: 1,40, 1,11, 1,04
Tasks:   1 total,   0 running,   1 sleeping,   0 stopped,   0 zombie
%CPU(s):  4,8 us,  1,0 sy,  0,0 ni, 94,0 id,  0,0 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8052,8 free,   4101,9 used,   4873,2 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11764,8 avail Spch
  11397 nuc       20   0 1038260 139472  70392 S   7,0   0,9  58:14.55 deCONZ
top - 21:15:19 up  4:02,  2 users,  load average: 1,36, 1,11, 1,04
%CPU(s):  5,4 us,  1,1 sy,  0,2 ni, 93,1 id,  0,0 wa,  0,0 hi,  0,3 si,  0,0 st
MiB Spch:  15866,8 total,   8052,3 free,   4102,4 used,   4873,3 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11764,4 avail Spch
  11397 nuc       20   0 1038260 139472  70392 S   3,0   0,9  58:14.64 deCONZ
top - 21:15:22 up  4:02,  2 users,  load average: 1,36, 1,11, 1,04
%CPU(s):  5,1 us,  1,1 sy,  0,1 ni, 93,5 id,  0,0 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8051,4 free,   4103,3 used,   4873,3 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11763,4 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R   7,3   0,9  58:14.86 deCONZ
top - 21:15:25 up  4:02,  2 users,  load average: 1,33, 1,11, 1,04
%CPU(s):  9,9 us,  4,5 sy,  0,0 ni, 85,5 id,  0,0 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8051,3 free,   4103,4 used,   4873,3 buff/cache
  11397 nuc       20   0 1038260 139472  70392 R 100,3   0,9  58:17.88 deCONZ
top - 21:15:28 up  4:02,  2 users,  load average: 1,31, 1,10, 1,04
%CPU(s): 10,1 us,  4,3 sy,  0,0 ni, 85,6 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Spch:  15866,8 total,   8051,1 free,   4103,6 used,   4873,3 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11763,2 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 100,3   0,9  58:20.89 deCONZ
top - 21:15:31 up  4:02,  2 users,  load average: 1,31, 1,10, 1,04
%CPU(s): 10,7 us,  4,5 sy,  0,4 ni, 84,2 id,  0,2 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8036,5 free,   4115,0 used,   4876,4 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11751,8 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 100,7   0,9  58:23.91 deCONZ
top - 21:15:34 up  4:02,  2 users,  load average: 1,28, 1,10, 1,04
%CPU(s): 10,0 us,  4,4 sy,  0,0 ni, 85,5 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Spch:  15866,8 total,   8037,3 free,   4114,0 used,   4876,6 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11752,7 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R  99,7   0,9  58:26.90 deCONZ
top - 21:15:37 up  4:02,  2 users,  load average: 1,28, 1,10, 1,04
%CPU(s): 11,7 us,  4,8 sy,  0,1 ni, 83,4 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Spch:  15866,8 total,   8034,9 free,   4116,4 used,   4876,7 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11750,3 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 100,7   0,9  58:29.92 deCONZ
top - 21:15:40 up  4:02,  2 users,  load average: 1,26, 1,10, 1,04
%CPU(s): 10,7 us,  4,0 sy,  0,0 ni, 85,1 id,  0,1 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11750,4 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 100,3   0,9  58:32.94 deCONZ
top - 21:15:43 up  4:03,  2 users,  load average: 1,24, 1,10, 1,04
%CPU(s):  8,1 us,  3,6 sy,  0,0 ni, 88,3 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
  11397 nuc       20   0 1038260 139472  70392 S  70,0   0,9  58:35.04 deCONZ
top - 21:15:46 up  4:03,  2 users,  load average: 1,24, 1,10, 1,04
%CPU(s):  5,2 us,  0,9 sy,  0,1 ni, 93,8 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Spch:  15866,8 total,   8034,7 free,   4116,6 used,   4876,7 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11750,1 avail Spch
  11397 nuc       20   0 1038260 139472  70392 S   4,0   0,9  58:35.16 deCONZ
top - 21:15:49 up  4:03,  2 users,  load average: 1,14, 1,08, 1,03
%CPU(s):  5,5 us,  0,8 sy,  0,2 ni, 93,3 id,  0,0 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8034,7 free,   4116,6 used,   4876,6 buff/cache
  11397 nuc       20   0 1038260 139472  70392 S   3,0   0,9  58:35.25 deCONZ
top - 21:15:52 up  4:03,  2 users,  load average: 1,14, 1,08, 1,03
%CPU(s):  8,0 us,  3,2 sy,  0,1 ni, 88,6 id,  0,0 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8034,5 free,   4116,9 used,   4876,6 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11749,9 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R  61,0   0,9  58:37.08 deCONZ
top - 21:15:55 up  4:03,  2 users,  load average: 1,13, 1,08, 1,03
%CPU(s): 10,0 us,  4,4 sy,  0,0 ni, 85,5 id,  0,0 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8034,5 free,   4116,8 used,   4876,6 buff/cache
  11397 nuc       20   0 1038260 139472  70392 R  99,7   0,9  58:40.07 deCONZ
top - 21:15:58 up  4:03,  2 users,  load average: 1,20, 1,09, 1,04
%CPU(s): 10,0 us,  4,1 sy,  0,0 ni, 85,8 id,  0,0 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8034,5 free,   4116,7 used,   4876,8 buff/cache
  11397 nuc       20   0 1038260 139472  70392 R 100,0   0,9  58:43.08 deCONZ
top - 21:16:01 up  4:03,  2 users,  load average: 1,20, 1,09, 1,04
%CPU(s): 10,3 us,  5,0 sy,  0,4 ni, 84,1 id,  0,1 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8007,2 free,   4141,1 used,   4879,8 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11725,7 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 101,0   0,9  58:46.11 deCONZ
top - 21:16:04 up  4:03,  2 users,  load average: 1,18, 1,09, 1,04
%CPU(s):  9,4 us,  4,3 sy,  0,0 ni, 86,2 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Spch:  15866,8 total,   8013,7 free,   4134,6 used,   4879,7 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11732,2 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R  96,0   0,9  58:48.99 deCONZ
top - 21:16:07 up  4:03,  2 users,  load average: 1,18, 1,09, 1,04
%CPU(s):  9,8 us,  4,5 sy,  0,1 ni, 85,4 id,  0,0 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8015,9 free,   4132,4 used,   4879,7 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11734,3 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 100,3   0,9  58:52.01 deCONZ
top - 21:16:10 up  4:03,  2 users,  load average: 1,17, 1,09, 1,04
%CPU(s):  9,6 us,  4,3 sy,  0,0 ni, 86,1 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Spch:  15866,8 total,   8023,1 free,   4125,2 used,   4879,6 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11741,5 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 100,7   0,9  58:55.03 deCONZ
top - 21:16:13 up  4:03,  2 users,  load average: 1,23, 1,11, 1,04
%CPU(s):  9,4 us,  4,4 sy,  0,0 ni, 86,0 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Spch:  15866,8 total,   8026,9 free,   4121,4 used,   4879,6 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11745,3 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 100,7   0,9  58:58.05 deCONZ
top - 21:16:16 up  4:03,  2 users,  load average: 1,23, 1,11, 1,04
%CPU(s): 10,4 us,  3,9 sy,  0,0 ni, 85,7 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11745,4 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 101,0   0,9  59:01.08 deCONZ
top - 21:16:19 up  4:03,  2 users,  load average: 1,22, 1,10, 1,04
%CPU(s):  9,7 us,  4,9 sy,  0,0 ni, 85,3 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Spch:  15866,8 total,   8027,2 free,   4120,9 used,   4879,8 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11745,9 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 100,0   0,9  59:04.09 deCONZ
top - 21:16:22 up  4:03,  2 users,  load average: 1,22, 1,10, 1,04
%CPU(s):  9,9 us,  4,6 sy,  0,0 ni, 85,4 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Spch:  15866,8 total,   8027,5 free,   4120,7 used,   4879,9 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11746,1 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 100,7   0,9  59:07.11 deCONZ
top - 21:16:25 up  4:03,  2 users,  load average: 1,20, 1,10, 1,04
%CPU(s):  9,8 us,  4,2 sy,  0,0 ni, 85,9 id,  0,0 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8027,5 free,   4120,6 used,   4879,9 buff/cache
  11397 nuc       20   0 1038260 139472  70392 R  98,3   0,9  59:10.06 deCONZ
top - 21:16:28 up  4:03,  2 users,  load average: 1,26, 1,12, 1,05
%CPU(s): 10,1 us,  4,7 sy,  0,0 ni, 85,0 id,  0,0 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8027,2 free,   4120,9 used,   4880,0 buff/cache
  11397 nuc       20   0 1038260 139472  70392 R 100,7   0,9  59:13.08 deCONZ
top - 21:16:31 up  4:03,  2 users,  load average: 1,26, 1,12, 1,05
%CPU(s): 13,6 us,  6,6 sy,  0,3 ni, 79,3 id,  0,2 wa,  0,0 hi,  0,0 si,  0,0 st
MiB Spch:  15866,8 total,   7994,6 free,   4150,7 used,   4882,9 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11716,1 avail Spch
  11397 nuc       20   0 1038260 139472  70392 R 100,3   0,9  59:16.09 deCONZ
top - 21:16:34 up  4:03,  2 users,  load average: 1,32, 1,13, 1,05
%CPU(s):  6,3 us,  2,3 sy,  0,1 ni, 91,3 id,  0,0 wa,  0,0 hi,  0,1 si,  0,0 st
MiB Spch:  15866,8 total,   8000,9 free,   4144,3 used,   4882,9 buff/cache
MiB Swap:  16251,0 total,  16251,0 free,      0,0 used.  11722,4 avail Spch
  11397 nuc       20   0 1038260 139472  70392 S  36,2   0,9  59:17.18 deCONZ
Hu % cpu = 100.7, it’s normal for you ? It’s a total ? wich one request have you usd ? On my side I have less than 2 %
I don’t see something special in your logs that can explain a hang.
You remember the last working version for you ?
Last version have modified http/ws traffic/rules, don’t need to share your logs, but just take a look on the “http” flag on logs
Make a try with Deconz alone, without alexa and other third app (that can try to use the API or websocket)
That high cpu usage isn’t normal obviously. But I don’t know why it happens.
I only have FHEM and Alexa controlling deconz as well, but I don’t think that should be the culprit as it hasn’t been a problem with Ubuntu.
As I switched to Debian 13 recently, I think there never was a working version for me with this distro. Nevertheless I tried every version from 2.32.1 in qt5 and qt6 but the cpu got hogged quickly every time.
I’m using a Pi4 additionally for deconz now instead of an Intel NUC and there hasn’t been any problem since.
Maybe I’ll do a fresh Debian 13 installation on another NUC in the next weeks to see if the problems reoccur.
IDK the impact that can have this issue, but can be interesting fd leak with https_port enabled (sockets to :80 in CLOSE_WAIT) · Issue #8494 · dresden-elektronik/deconz-rest-plugin · GitHub
It’s for that I m saying to try deconz alone, without third app trying to connect to it.
