Web access not working
Web access stoped working when upgraded to 2.27.6.
This is only phoscon, not one external browser is working after update. Vnc is working.
I have managed to access phoscon via vnc to rasbian and there via chromium, because I have to change light in group after each reboot or updgrade.
As mentioned in Web access does not work in v2.27.6 · Issue #7859 · dresden-elektronik/deconz-rest-plugin · GitHub, there seems to be a forwarding issue to a new web page.
It works for me on 2.27.6 when using /pwa/login2.html as URI (notice the 2).
Thank you for the new link, working!
Hi thanks for reporting. I found where this happens in the code and I’ll make a small fix for the next release.
Till then as workaround please use following URL:
http://<ip-address>/pwa
This resolves automatically to the correct /pwa/login2.html path. Another way to open the Phoscon App is from deCONZ itself via the Phoscon App button which also opens the /pwa/login2.html page.
Did someone also notice all the CORS and 403 errors flooding the console?
Any ETA for the next release?
I would guess that all users get affected and confused by this issue – not being able to log in (until they find this thread) – so I hope for a quick bugfix release.
