Has someone an idea, where the max. value can be edited?
best regards Paul
Moved to deconz > general support.
Can you please use the correct category next time?
The max ct values are fixed by the devices firmware, you can check the ctmax
value also via REST API.
Note ct is specified in “Mired Color Temperature” and usually is somewhere in the range from 150-600.
