V2.32.5: websocket port switched to 80 after update from 2.31.2
today I updated deconz from 2.31.2 to 2.32.5.
After that my NodeRed instance got not notified anymore and the Phoscon-GW node was regulary showing the following error:
WebSocket error: Error: connect ECONNREFUSED xxx.xxx.xxx.xxx:20877
WebSocket disconnected: 1006 -
checking the config via GET /api//config the result shows:
websocketport: 80
I tried to set the websocket port “manually” in the /lib/systemd/system/deconz-gui.service via
ExecStart=/usr/bin/deCONZ --http-port=80 --ws-port=20877
but after daemon-reload and restarting the service it is still the same in the config.
websocketport: 80
So I have two questions:
a) Is it intented, that after the update the websocket switched to 80, which is also the http port?
b) is there a different way to set it back to 20877?
Interesting the --ws-port parameter is the correct way to set the websocket port.
Are you able to check with websocat ws://127.0.0.1:20877 if the Websocket works on this port, in this case the bug seems that the port in the config isn’t updated correctly, I’ll have a look.
