I just set up an RPI with a RaspBee and got everyting working so far (well beside the RTC, bus this seems to be an issue with the latest Raspbian kernel).
Now I’m running into one issue:
I like to use the gateway via the Android app, aswell as from the HTTP interface.
In generall both works, but something is weird when setting up groups:
I set up a group “Garden” which works fine from browser, but in the android app it does not show up at all.
The way round I set up a Group “Garden XXX” in android, this shows in browser as “phoscon_room_9_on_off_group” and is not usable at all.
At the same time I set up another group “Schlafzimmer” which works fine on both ends.
Currently the Phoscon App version of the Android App and the web version shipped with deCONZ differs. There was a new development of a Dashboard that is now in the Android App.
in deCONZ it will be integrated later. There will be the old and the new version to choose when you are using deCONZ.
For now you can download the new Dashboard version for deCONZ to use in your browser on a PC from here: Index of /phoscon_app/
Just extract the newest archive from there to your deCONZ installation directory.
usually in your AppData directory:
C:\Users...\AppData\Local\Programs\deCONZ\bin\plugins\de_web\pwa
Delete the old content in the pwa folder and extract all files into that folder.
Then you have the newest version when you open the app with your PC’s IP in your browser.
Until you install a new deCONZ version. Then it is overwritten. But in one of the next deCONZ beta versions there will be the ne App integrated.
