Upgrade deConz stopped working deConz: *ERROR* Failed to allocate from GEM DMA helper
I did run the upgrade of deConz this morning but as of that the system broke.
Pi3B using a Conbee III adapter
Did restart after the upgrade:
Unpacking deconz (2.32.5) over (2.31.2) …
Setting up deconz (2.32.5) …
Processing triggers for desktop-file-utils (0.26-1) …
Processing triggers for gnome-menus (3.36.0-1.1) …
Processing triggers for mailcap (3.70+nmu1) …
Restarted (Pi3B)
But as soon as starting it fails to start on starts sending errors:
[ 334.772531] vc4-drm soc:gpu: [drm] ERROR Failed to allocate from GEM DMA helper
[ 334.772583] vc4_v3d 3fc00000.v3d: Failed to allocate memory for tile binning: -12. You may need to enable DMA or give it more memory.
Help to get this resolved is welcome…
I finally succeeded to start deConz, but only without gui .. so kind of blind.
>> sudo systemctl start deconz
Starting this way deConz mentions only several:
Interface to my H.A. is running anyway, so my Zigbee network is at least in running state.
As soon as I start deconz-gui the DMA errors are starting again.
Before the upgrade never noticed this error. gui was running fine.
Is there any reason I should move over to use the package deConz-qt6 ?
As i’m running “Debian GNU/Linux 12 (bookworm)” on my Pi3b
Getting the errror to AI it recommands to add to config:
# Allocate more memory for the GPU
gpu_mem=256 # or higher if needed
After adding GPU_MEM=512
issue of errors on the DMA is gone, but still no luck (except running without gui…)
Deconz gui still does not start. It’s looping / restarting.
what is missing in this gui that it broke in this upgrade ?
systemd Reloading.
deCONZ-init.sh stopping deconz-wifi.service
systemd Starting deconz-init.service - deCONZ: ZigBee gateway – Initialisation…
systemd deconz-gui.service: Failed with result ‘signal’.
systemd deconz-gui.service: Main process exited, code=killed, status=6/ABRT
deCONZ Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
deCONZ This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
deCONZ qt.qpa.plugin: Could not load the Qt platform plugin xcb in even though it was found.
deCONZ qt.qpa.xcb: could not connect to display :0
deCONZ Invalid MIT-MAGIC-COOKIE-1 key
systemd Finished deconz-init.service - deCONZ: ZigBee gateway – Initialisation.
systemd deconz-init.service: Deactivated successfully.
systemd /lib/systemd/system/deconz-gui.service:11: Unknown key ‘StartLimitIntervalSec’ in section [Service], ignoring.
systemd Reloading.
systemd Started deconz-gui.service - deCONZ: ZigBee gateway – GUI/REST API.
systemd Stopped deconz-gui.service - deCONZ: ZigBee gateway – GUI/REST API.
systemd deconz-gui.service: Scheduled restart job, restart counter is at 6.
systemd Reloading.
systemd Reloading.
systemd deconz-gui.service: Scheduled restart job, restart counter is at 5.
systemd Reloading.
systemd Reloading.
systemd deconz-gui.service: Scheduled restart job, restart counter is at 4.
systemd Reloading.
systemd Reloading.
systemd deconz-gui.service: Scheduled restart job, restart counter is at 3.
