Updating Conbee II
I have a Conbee WII that has been working nice for many years, but now I need to update to use a new thermostat. And then the problem has started…
My deConz is version 2.24.1. I have tried to update to a newer version, but it is stuck at this version after innstallation. I think this might be because the conbee is not updated?
The conbee is version 26650700. I have tried many versions of GCFFlasher, and tried to update to many different versions, but they all end in different crashes.
One version does nothing. Another one fail after about a minute. And another one says “retry connect bootloader com5”
Any good ideas, or will I have to give up using the new thermostatW?
Can you please try to update with the approach described in https://github.com/dresden-elektronik/deconz-rest-plugin/wiki/Update-deCONZ-manually#what-if-conbee-all-versions-still-refuses-to-flash
This should also work in harder cases, sometime switching to a different USB port may help too.
I tried all the trick that was mentioned.
Changing USB port didn’t help, and using parameter -x 3 gave no result either. They gave the same result;
Flash firmware
command reset timeout
When trying to use the serial-number, I got the result that there was an invalid argument for parameter -s.
I tried several versions of the flasher, with the same result.
What file are you trying to flash?
I am trying to flash deCONZ_ConBeeII_0x26780700.bin.GCF, which is the most recent version I have found.
I have also borroved another conbee II, but the problem is the same.
I have also found am old computer with windows 10, and installed deconz V2.30.02
I have tried flashing from this computer, but the result is the same.
If I use older versions of GCFFlasher there is no response from the flasher.
If I use v3.17 I get the message “retry,failed”
If I use newer versions of the flasher I get “retry connect bootloader com5”
I guess I am doing something wrong, since I have tried 2 computers, 2 sticks, and very many versions of flashers and software… The question is what!
I remember flashing the stick a few years ago without any problems.
It’s indeed strange if this happens on two PCs and two ConBees :thinking:
Can you please share a log when running the follwing command with GCFFlasher v4.9.0 from https://github.com/dresden-elektronik/gcfflasher/releases/tag/v4.9.0
GCFFlasher.exe -d <Your COM Port> -f deCONZ_ConBeeII_0x26780700.bin.GCF -x 3
Another idea is to download the firmware GCF file again, we had cases in the past where the file wasn’t downloaded completely or corrupt for some reason.
Like this?
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Install the latest PowerShell for new features and improvements! Migrating from Windows PowerShell 5.1 to PowerShell 7 - PowerShell | Microsoft Learn
PS C:\Users\HS4\Desktop\GCFFlasher_Win_V4_09_00> .\gcfflasher -l
Path | Serial | Type
COM5 | DE2462183 | ConBee II
PS C:\Users\HS4\Desktop\GCFFlasher_Win_V4_09_00> .\GCFFlasher.exe -d com5 -f deCONZ_ConBeeII_0x26780700.bin.GCF -x 3
read file success: deCONZ_ConBeeII_0x26780700.bin.GCF (163244 bytes)
flash firmware
The last line continues every half second…
I also tried updating to powershell 7, without any change.
Hmm I don’t get it :thinking: I’ve tried also to re create the setup and flashed my ConBee II with 0x26650700 and then upgraded again to 0x26780700 here it works.
Important: Your command uses lower case com5, it should be COM5.
Just to be sure that the file is not corrupt can you execute following command in Power Shell in the directory where the firmware is:
Get-FileHash -Path .\deCONZ_ConBeeII_0x26780700.bin.GCF
It should output following SHA256 hash:
5489590B5D2E108DBE4BA2A98D74995B2A5975CDA57CB9EDAF5EB82F5358059B
Also does the current firmware on the ConBee still work with deCONZ and can connect?
With GCFFlasher this can also be checked via:
GCFFlasher.exe -d COM5 -c -x 3
This does print some packet logs every few seconds.
It has been a while since I made this post, because of other non-related things I had to take care of. Sorry about that.
When I came back to this problem, I downloaded all the files again, and suddenly everything worked just as it should. I don’t know what it was, but of course I must have done something wrong the first time :wink:
