Describe the bug
I’ve updated my system to latest stable release and latest firmware. But with latest conbeeII firmware 26700700 or 26720700 nothing is connecting. If I go back to Firmware 26680700 then everything seems to work.
If the problem is reproducable, list the steps here:
- Update to 2.12.6
- Update conbeeII Firmware to 26700700 or 26720700
- restart the system
- After waiting minutes no connections show in deconz gui and nothing ist working
I can see in logs following entries:
11:47:04:328 apsUseExtPanid is 0x23D1DDDDDDDDCDAB but should be 0, start reconfiguration
11:47:04:328 Skip automatic channel change, TODO warn user
Do I have to change something on my configuration?
Expected behavior
Should setup connections like with firmware 26680700
Screenshots
Environment
see screenshots
- Host system: (NAS)
- Running method: (Ubuntu)
- Firmware version: (26720700)
- deCONZ version: (2.12.6)
- Device: (ConBee II)
- Do you use an USB extension cable: (yes)
- Is there any other USB or serial devices connected to the host system? If so: Which? ZWave Stick on separate powered USB extension
