Describe the bug
Update from 2.15.01 to 2.15.02 breaks two of the three philips hue motion sensors I have, one Philips hue dimmer switch, an aqara vibration sensor, a friend of hue switch, an aqara smoke sensor (3 others not) and one aqara window sensor. The devices or gone in phoscon and in the deCONZ GUI viewer.
By the way, after the update to 2.15.02 also several aqara sensors are not reachable, but I can enable them again in the deCONZ GUI viewer.
Switching back to 2.14 or 2.15.01 did not help since the sensors/switches are gone in phoscon. I can add the devices again to phoscon, but after a restart (stop/start of the docker) all these devices are gone again.
Expected behavior
Devices should still be available after the update to 2.15.02 and also remain available when restarting deconz.
Screenshots
Screenhots would not help here, the devices are just gone.
Environment
- Host system: Qnap 253be NAS
- Running method: Docker container
- Firmware version: 26720700
- deCONZ version: 2.51.01
- Device: ConBee II
- Is there any other USB or serial devices connected to the host system? If so: Which?, APC UPS and zwave usb stic
