I’ve upgraded my Rpi with Deconz install (apt-get update && apt-get dist-upgrade), and unfortunately my connection with the app Hue Essentials and remotecontrollers (Tradfri, Hue) are lost.
Status of deconz seems good, reset of Deconz won’t work. In the app Hue essentials i’ve removed the settings and reconnected, but that doesn’t work.
What can I do more than reinstall everything?
State of deconz posted below:
sudo systemctl status deconz
Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset>
Active: active (running) since Sun 2023-06-25 21:04:27 BST; 2 days ago
Main PID: 439 (deCONZ)
Tasks: 5 (limit: 3933)
CPU: 1h 18min 51.005s
└─439 /usr/bin/deCONZ -platform minimal --http-port=80
Jun 25 21:04:27 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- REST >
Jun 25 21:04:31 raspberrypi deCONZ[439]: QStandardPaths: XDG_RUNTIME_DIR not se>
Jun 25 21:04:32 raspberrypi deCONZ[439]: libpng warning: iCCP: known incorrect >
Jun 25 21:04:35 raspberrypi deCONZ[439]: This plugin does not support propagate>
Thanks for all the suggestions. Sorry for the late response. My technical knowledge of Debian/Linux is not what it used to be. After some research and testing, this (click on preview for exact solution, because there are more solutions) was the solution for me:
