Unable to pair with any devices
Problem:
After attempting to pair with lamps and plugs (which have previously paired) I can no long pair with them.
I have re-installed Home Assistant 4 times now.
Home Assistant 2021.10.6
Frontend version: 20211007.1 - latest
Virtual Environment false
Python Version 3.9.7
Operating System Family Linux
Operating System Version 5.10.17-v8
CPU Architecture aarch64
Conbee II connected to RPI 4b. usb 3 slot, 1m extension cable.
Integrations present
Google cast
HASS bridge:21064
Zigbee ZHA
Try to add devices to ZHA ‘configuration’, results in no additions, whether in pairing mode or not.
Tried with Philips Hue lamps and plugs, Osram lamps.
error log at
This forum is only providing support for deconz and phoscon. Not for ZHA.
Similar issue?
Problem:
With deCONZ 6.10.0 loaded.
deCONZ UI shows ‘in network’
Phoscon/settings/gateway is blank page?
Google cast
HASS bridge:21064
deCONZ 6.10.0
Log at deCONZ main log - Pastebin.com
Can you provide deconz logs?
https://forum.phoscon.de/t/how-to-get-logs/533/2
Please note that we do not develop the HA Addon thus do not provide support on it not functioning properly.
deCONZ log as requested
log pastebin, but I’m told I cannot post that url.
Not much help here then
Eh, try again.
Pasted deconz log as requested, sys came back reporting spam.
Link to pastebin pastebin com/G1kyXNfT
Same response
The permit join was enabled during the log ?
“The permit join was enabled during the log ?” I don’t know what that means
The action that make the gateway accept new device.
Sorry @Smanar - How to do that please?
IDK using HA but with phoscon device/light/add new lights, it s just the pairing procedure.
Not sure why that happens. Bot seems to go ape on it. Just post as you just did :slight_smile:
Either way, i don’t see anything that shows its searching for devices(the Permit Join @smanar is talking about).
In Phoscon, did you click add devices?
Also, did you add all the log levels i mentioned? It seems there’s some missing.
IIRC this was as I installed deCONZ, so no, no “Permit join” set.
I have ZHA working (partially) so please close this issue,
Shame there is no standardisation above zigbee 3, into software layers.
E.g. 4 different makers, 4 different ‘reset’ methods! Ripe for standardisation?
As you wish.
