Unable to flash Conbee 3
Hi there,
I am trying to use my (never before used) Conbee 3 for Thread, according to OpenThread documentation (sorry, German version, but I guess you get the drift). Unfortunately, I seem to be unable to flash any firmware on this stick. I tried the Online FW Updater as well as GCFFlasher. I tried both, the recent Thread as well as the recent deCONZ firmware, I tried two different PCs. I tried also the tipps from Update deCONZ manually · dresden-elektronik/deconz-rest-plugin Wiki · GitHub (that’s why the following run of GCCFlasher does not connect at first, because I plugged the Stick in after starting it). Here the output of GCFFlasher:
.\GCFFlasher.exe -d COM3 -t 60 -f .\ot-rcp-cb3_0x01000900.GCF -x 3
read file success: .\ot-rcp-cb3_0x01000900.GCF (99262 bytes)
flash firmware
connect \\.\COM3, baudrate 115200
failed to connect serial com
command reset timeout
retry connect bootloader COM3
query bootloader id V3
send: C081027DFFC0 (6)
query bootloader failed
retry: 44 seconds left
flash firmware
send uart reset
send: C00B03000C0005002602000000B9FFC0 (16)
recv_packet: 81820400010050261D1D (10)
retry: 38 seconds left
flash firmware
send uart reset
retry: 32 seconds left
flash firmware
send uart reset
retry: 25 seconds left
flash firmware
send uart reset
retry: 19 seconds left
flash firmware
send uart reset
That’s when I stopped it. Does anyone have any ideas?
BR
Markus
Update: I was able to flash the Firmware on Linux.
And your previous test on PC was on windows PC ?
Same procedure ?
