i’m having trouble pairing an IKEA Tradfri E27 806lm Bulb (IKEA-Nr. 704.391.58). I did reset the bulb according to this video, but the lamp cannot be found.
I have already paired an IKEA Tradfri E14 bulb and a Philips Hue Go lamp successfully.
My deconz is running in a docker container on a Raspberry-PI 4 with the ConBee 3 USB-Stick. The bulb is approx 5cm away from the USB-Stick.
This are the latest logs from the docker container:
10:31:06:903 [Master] config changed, read parameters
10:31:06:935 Device protocol version: 0x010C
10:31:07:159 Current channel 15
10:31:07:383 Device protocol version: 0x010C
10:31:10:138 reconnect network done
10:31:11:208 network configuration verified!
10:31:13:579 0x001788010B44187B error APSDE-DATA.confirm: 0xA7 on task
10:31:46:509 0x680AE2FFFE47C188 found group 0x0001
10:31:46:509 0x680AE2FFFE47C188 found group 0xFFF0
10:31:46:638 binding for cluster 0x0000 of 0x680AE2FFFE47C188 exists (verified by reporting)
10:31:46:823 Bind response success for 0x680ae2fffe47c188 ep: 0x01 cluster: 0x0006
10:31:46:935 ZCL configure reporting rsp seq: 200 0x680AE2FFFE47C188 for ep: 0x01 cluster: 0x0006 attr: 0x0000 status: 0x00
10:31:47:111 Bind response success for 0x680ae2fffe47c188 ep: 0x01 cluster: 0x0008
10:31:47:229 ZCL configure reporting rsp seq: 201 0x680AE2FFFE47C188 for ep: 0x01 cluster: 0x0008 attr: 0x0000 status: 0x00
10:31:47:369 Bind response success for 0x680ae2fffe47c188 ep: 0x01 cluster: 0x0300
10:31:47:511 ZCL configure reporting rsp seq: 203 0x680AE2FFFE47C188 for ep: 0x01 cluster: 0x0300 attr: 0x0008 status: 0x00
sure i can do that, but i’m not sure how? Can i get those logs from the docker-container, or do i have to use a different software (like deconz for desktop?
I saw, that there are some environment variables for the community-docker image, which i’m using. I can find a var for APS, but not the other, is that the debug var?
Yes, i did the off-on cycle 6 times, as it is shown in the IKEA video on YouTube. The bulb was previously on. After the last off-on cycle the bulb did not flash or so. The light just stayed on.
Both worked as expected. I connected them to a lamp, did the swicheroo (6x) and both bulbs started to “breath” immediately after.
Afterwards i could easily add them to my deconz via phoscon web app.
I really think, the bulb i bought had some issues. I actually bought it as a used bulb. So conclusion for me: do not buy used bulbs.
If it’s for interest for the project i’d donate this bulb for research purposes.
