Thx, that helped me a bit further. But now there is a new Problem. After startup there are 4 errors and warnings.
Logger: homeassistant.components.zha.core.gateway
Source: components/zha/core/gateway.py:152
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 22:22:46 (6 occurrences)
Last logged: 22:25:27
Couldn’t start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator
Traceback (most recent call last):
File “/usr/local/lib/python3.9/asyncio/tasks.py”, line 492, in wait_for
fut.result()
asyncio.exceptions.CancelledError
The above exception was the direct cause of the following exception:
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 152, in async_initialize
self.application_controller = await app_controller_cls.new(
File “/usr/local/lib/python3.9/site-packages/zigpy/application.py”, line 69, in new
await app.startup(auto_form)
File “/usr/local/lib/python3.9/site-packages/zigpy_deconz/zigbee/application.py”, line 67, in startup
self.version = await self._api.version()
File “/usr/local/lib/python3.9/site-packages/zigpy_deconz/api.py”, line 463, in version
(self._proto_ver,) = await self[NetworkParameter.protocol_version]
File “/usr/local/lib/python3.9/site-packages/zigpy_deconz/api.py”, line 428, in read_parameter
r = await self._command(Command.read_parameter, 1 + len(data), param, data)
File “/usr/local/lib/python3.9/site-packages/zigpy_deconz/api.py”, line 313, in _command
return await asyncio.wait_for(fut, timeout=COMMAND_TIMEOUT)
File “/usr/local/lib/python3.9/asyncio/tasks.py”, line 494, in wait_for
raise exceptions.TimeoutError() from exc
asyncio.exceptions.TimeoutError
Logger: zigpy.application
Source: /usr/local/lib/python3.9/site-packages/zigpy/application.py:73
First occurred: 22:22:46 (9 occurrences)
Last logged: 22:29:33
Couldn’t start application
Logger: zigpy_deconz.api
Source: /usr/local/lib/python3.9/site-packages/zigpy_deconz/api.py:315
No response to ‘Command.read_parameter’ command with seq id ‘0x02’
Logger: homeassistant.config_entries
Source: config_entries.py:344
First occurred: 22:22:46 (1 occurrences)
Last logged: 22:22:46
Config entry ‘ConBee II - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2478552-if00, s/n: DE2478552 - dresden elektronik ingenieurtechnik GmbH - 1CF1:0030’ for zha integration not ready yet; Retrying in background
Do you have any idea what that is about?
