weird…after restart of deconz plugin it seems to be working now. I just needed to manually remove entity and device from core.entity_registry and core.device_registry in HA and everything is fine now.
Good question, I have same issue, unfortunately I have no clue about that.
I don’t have the tuya app to see if the device have this feature and I don’t see information about this feature on others zigbee project.
And as it use tuya cluster, there is nothing in zigbee specification for it.
That’s a pity. Would it be possible to change the type of a bulb? Mine is sometimes flickering (it’s a led bulb from philips), maybe there is some config for it. This guy here is changing the bulb type Smart Dimmer Switch WIFI UNBOXING AND COMPLETE SETUP - YouTube
At least there is a screenshot from that application which is in video.
There is a possibility of setting the Select type of your lamp and then Set the minimum brightness of the dimmer with description Please set the minimu brightness of your lamp and try to dimm your lamp. If the lamp is flashing or turned off, increase the brightness until it works well
Seems like there could be some additional attribute.
No, I trust you, but I have make a search on other zigbee project no more information about this feature.
If it exist, someone with the tuya app need to use it and sniff the zigbee request to get it.
